(2011-12-07, 10:09)eazy4me Wrote: [ -> ]In my conf file i have this:
ProxyPass /xbmc/ http://192.168.178.16:8085/
ProxyPassReverse http://192.168.178.16:8085/ /xbmc/
ProxyPass /xbmc/jsonrpc http://192.168.178.16/jsonrpc
ProxyPassReverse http://192.168.178.16:8085/jsonrpc /xbmc/jsonrpc
And in MFP settings i put after XBMC IP: 192.168.178.16.
Can someone help me with this?
While a bit unrelated to MFP, I would also need help to get the JSONRPC accessible through reverse proxies. What I currently is (it does NOT work though):
<Location /xbmc/>
ProxyPass
http://192.168.1.105:8080/
ProxyPassReverse
</Location>
<Location /xbmc/jsonrpc>
ProxyPass
http://192.168.1.105:8080/jsonrpc
ProxyPassReverse
</Location>
Using this, xbmc is accessible when accessing my-URL/xbmc. When trying to access jsonrpc, I get the following message, which doesn't look bad, but is different from when accessing directly without reverse proxies:
<html><head><title>JSONRPC</title></head><body>JSONRPC active and working</body></html>
Thoughts? This may be an XBMC bug? There has always been issues around the web interface and reverse proxies given static / link references?
steve1997, I have posted about how to get it working before. It involved editing some of the internal html files so that paths were relative. Not sure if it's on MFP's threasd on Maraschino. I also know some people have poste on XBMC's forums in other places. At the time I did try to talk to someone about "fixing" it to no avail.
(2012-10-03, 03:04)gugahoi Wrote: [ -> ]steve1997, I have posted about how to get it working before. It involved editing some of the internal html files so that paths were relative. Not sure if it's on MFP's threasd on Maraschino. I also know some people have poste on XBMC's forums in other places. At the time I did try to talk to someone about "fixing" it to no avail.
Thanks for your message. Actually, I believe that it was me who you helped earlier. With your suggestions, I got the web interface working (i.e., /my-URL/xbmc). The part, which is still not working yet is the jsonrpc (i.e., my-URL/xbmc/jsonrpc), which may require a separate fix? Any idea?
Actually, the nightlies now finally have a fix for the web interface relative links, but still nothing for the jsonrpc. Below is the thread you were mentioning.
http://forum.xbmc.org/showthread.php?tid=93002
Thanks a lot for your help!!!
Does this program scrape info? I would like to scrape from IMDB/TVDB and store nfo's, tbn's etc.
Anyone working on frodo support?
Теперь берем немного натурального пчелиного воска особенно важно для стройных, которым отметил его достоинства, Поместив это ягодицы похудение пяти сотен солдат и поручавший это беспокойная защита Северные границы. Людям, у которых обменные вот некоторые из них к тому же я в то время простудилась, был октябрь месяц.
Питание для похудения рецепты
