2011-08-26, 00:46
rflores2323 Wrote:has a way been figured out how to update automatically from the application?
Yes. Settings page automatically recognises what Commit your on. If your behind, Gugahoi's update script updates MFP for you.
DejaVu Wrote:Yes. Settings page automatically recognises what Commit your on. If your behind, Gugahoi's update script updates MFP for you.
prophetizer Wrote:i know dejavu somewhere in this thread explained the different branches, but i can't find it. so what are the differences?
also, since nick8888 is MIA how come nobody started a new thread, so that the first post can be updated with all relevant information?
thanks
Quote:[Fri Aug 26 17:45:00 2011] [error] [client 192.168.2.101] File does not exist: /var/www/js/jquery.scrollTo-1.3.3-min.js, referer: http://192.168.2.99:19815/settings.php
Quote:Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /var/www/settings.php:58) in /var/www/config.php on line 432
Quote:The page isn't redirecting properlyI have added following in the apache config file on the synology NAS:
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
Quote:<Location /xbmc/>I have added these two items to the Nav Bar:
ProxyPass http://192.168.1.135:8080/
ProxyPassReverse http://192.168.1.135:8080/
<>Location>
<Location /xwmm/>
ProxyPass http://192.168.1.135:8080/XWMM/movies/
ProxyPassReverse http://192.168.1.135:8080/XWMM/movies/
<>Location>
tom101 Wrote:I found some errors in the apache log
http://pastebin.com/ZGXpbCZL
like
Is this relevant to the issue I'm having?
Oh, and another one at the top of the settings page
<script src="js/jquery.scrollTo-1.3.3-min.js" type="text/javascript"></script>
<script src="js/jquery.localscroll-1.2.5-min.js" type="text/javascript"></script>
<script src="js/jquery.serialScroll-1.2.1-min.js" type="text/javascript"></script>
<script src="js/jquery.scrollTo-1.4.2-min.js" type="text/javascript"></script>
<script src="js/jquery.localscroll-1.2.7-min.js" type="text/javascript"></script>
<script src="js/jquery.serialScroll-1.2.2-min.js" type="text/javascript"></script>
[Fri Aug 26 17:46:22 2011] [error] [client 192.168.2.101] File does not exist: /var/www/css/customcss/.css, referer: http://192.168.2.99:19815/settings.php
_Mikie_ Wrote:A while back the Crazy Layout branch was half developed. It basically meant that you could have multiple pages for widgets. Is anyone still interested in this? Would they like me to redevelop it or not?
_Mikie_ Wrote:If you look in my signature. The Master is the Master obviously and that's where all the changes once checked end up. Within that there are a couple branches which are old and I wouldn't advice using as they are so out dated.
DeJaVu's one is his own personal adaptation of mfp which has a different menu structure but ultimately has everything the Master has. Gugahoi and mine are similar to the Masters however we test out new things so they aren't always 100% working. They do however contain new features that are being looked into which might make the Master at some stage.
All the relevant info is on the wiki on the Master Repo if you are looking for it. I think a new thread hasn't been started just because its easier if everything is kept together.
Regards
@gugahoi and DeJaVu : The lengths of the widgets. Some of them are defined in the css or hard coded into the widgets. How do the others get there length?
Quote:MediaFrontPage's First post is outdated. You should now follow these (WIP) instructions to install it. We do not have contact with Nick8888 ATM to update it.
thanks
el_cabong Wrote:I would like to see some more development with this idea.
I think it will work well if/when more people begin writing widgets for this interface. Also, this design can help with multiple room htpc setups, where each room can have its own page with its own control/info widgets.
[Sat Aug 27 09:42:11 2011] [error] [client 192.168.2.101] File does not exist: /var/www/css/customcss/.css, referer: http://192.168.2.99:19815/index.php
[Sat Aug 27 09:44:09 2011] [error] [client 192.168.2.101] File does not exist: /var/www/mediafrontpage
[Sat Aug 27 10:06:02 2011] [error] [client 192.168.2.101] File does not exist: /var/www/mfp/css/footer.css, referer: http://192.168.2.99:19815/mfp/settings.php
[Sat Aug 27 10:06:03 2011] [error] [client 192.168.2.101] File does not exist: /var/www/mfp/css/footer.css, referer: http://192.168.2.99:19815/mfp/settings.php
[Sat Aug 27 10:06:07 2011] [error] [client 192.168.2.101] File does not exist: /var/www/mfp/css/.css, referer: http://192.168.2.99:19815/mfp/mediafrontpage.php
tom101 Wrote:Hi Mikie, thanks for your help. Now I get these errors in my apache logs
PHP Code:[Sat Aug 27 09:42:11 2011] [error] [client 192.168.2.101] File does not exist: /var/www/css/customcss/.css, referer: http://192.168.2.99:19815/index.php
By the way, I deleted the old contents of /var/www and have downloaded mediafrontpage anew to /var/www/mfp is it OK to do that or does everything need to live in /var/www?
<link rel="stylesheet" type="text/css" href="css/footer.css">
