2011-07-09, 07:09
Argh, wrong github on Ubuntu. Changed to the proper MediaFrontPage and have edited my config.php. Now it won't let me get off the servercheck.php page :S
guy_smiley:) Wrote:Argh, wrong github on Ubuntu. Changed to the proper MediaFrontPage and have edited my config.php. Now it won't let me get off the servercheck.php page :S
guy_smiley:) Wrote:I deleted the firstrun.php and it works... sort of. It loads the normal webpage but when loading wComingEpisodes.php it moves to this as a webpage and loads my router's login page. :S
EDIT: no it doesn't :S It now works but none of the widgets still load. ComingEpisodes is actally erroring out with a 404 Not Found.
gugahoi Wrote:I don't know if you actually read the contents of firstrun.php. You're not supposed to delete it urself. If it doesn't go past the servecheck page that means there's something wrong. Probably need to chmod the entire directory and files
guy_smiley:) Wrote:I did read it, not supposed to delete. Everything was ticked on the servercheck though :S I believe it's an issue with my router (as I have remote management enabled, I will turn it off, otherwise when I log in, it won't change to that screen.)
Still have no idea about the widgets
gugahoi Wrote:I don't understand how this has anything to do with firstrun not being deleted? Sounds like there is something wrong with your web server...
<VirtualHost *:80>
SSLProxyEngine on
ProxyRequests On
ProxyPreserveHost Off
ErrorLog logs/mfp_error_loag
TransferLog logs/mfp_access_log
DocumentRoot /var/www
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order deny,allow
</Directory>
<Location /xbmc>
order deny,allow
ProxyPass http://10.1.1.3:8085
ProxyPassReverse http://10.1.1.3:8085
</Location>
<Location /xbmc/jsonrpc>
order deny,allow
ProxyPass http://10.1.1.3:8085/jsonrpc
ProxyPassReverse http://10.1.1.3:8085/jsonrpc
</Location>
<Location /sabnzbd>
order deny,allow
ProxyPass http://localhost:8080/sabnzbd
ProxyPassReverse http://localhost:8080/sabnzbd
</Location>
<Location /tvshows>
order deny,allow
ProxyPass http://localhost:8081/tvshows
ProxyPassReverse http://localhost:8081/tvshows
</Location>
<Location /movies>
order deny,allow
ProxyPass http://10.1.1.3:5000
ProxyPassReverse http://10.1.1.3:5000
</Location>
<Location /headphones>
order deny,allow
ProxyPass http://10.1.1.3:8181
ProxyPassReverse http://10.1.1.3:8181
</Location>
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
</VirtualHost>
[Sat Jul 09 20:08:44 2011] [error] [client 192.148.117.104] PHP Notice: Undefined index: REMOTE_HOST in /var/www/widgets/wSystem.php on line 67, referer: htt
p://myurl.dyndns.org/mediafrontpage.php
[Sat Jul 09 20:08:44 2011] [error] [client 192.148.117.104] PHP Notice: Undefined variable: newlink in /var/www/widgets/wComingEpisodes.php on line 158, refe
rer: http://myurl.dyndns.org/mediafrontpage.php
[Sat Jul 09 20:08:44 2011] [error] [client 192.148.117.104] PHP Warning: Invalid argument supplied for foreach() in /var/www/widgets/libXBMCLibrary.php on li
ne 311, referer: http://myurl.dyndns.org/mediafrontpage.php
[Sat Jul 09 20:08:44 2011] [error] [client 192.148.117.104] File does not exist: /var/www/routine_data.js, referer: http://myurl.dyndns.org/widgets/wComin
gEpisodes.php?display=yes
[Sat Jul 09 20:08:44 2011] [error] [client 192.148.117.104] File does not exist: /var/www/msg.js, referer: http://myrul.dyndns.org/widgets/wComingEpisodes
.php?display=yes
[Sat Jul 09 20:08:44 2011] [error] [client 192.148.117.104] File does not exist: /var/www/widgets/util.js, referer: http://myurl.dyndns.org/widgets/wComin
[Sat Jul 09 20:08:45 2011] [error] [client 192.148.117.104] PHP Notice: Undefined variable: newlink in /var/www/widgets/wComingEpisodes.php on line 158, refe
rer: http://myurl.dyndns.org/widgets/wComingEpisodes.php?display=yes
[Sat Jul 09 20:08:45 2011] [error] [client 192.148.117.104] File does not exist: /var/www/routine_data.js, referer: http://myurl.dyndns.org/widgets/wComin
[Sat Jul 09 20:08:46 2011] [error] [client 192.148.117.104] PHP Notice: Undefined variable: newlink in /var/www/widgets/wComingEpisodes.php on line 158, refe
[Sat Jul 09 20:08:46 2011] [error] [client 192.148.117.104] File does not exist: /var/www/routine_data.js, referer: http://myurl.dyndns.org/widgets/wComin
[Sat Jul 09 20:08:47 2011] [error] [client 192.148.117.104] File does not exist: /var/www/bob_help.html, referer: http://myurl.dyndns.org/widgets/wComingE
[Sat Jul 09 20:08:47 2011] [error] [client 192.148.117.104] File does not exist: /var/www/widgets/hr.gif, referer: http://myurl.dyndns.org/widgets/wComing
<?php
if ($qs == 'SickBeard') {
echo $sickbeardurl;
} elseif($qs == 'CouchPotato') {
echo $cp_url;
} elseif($qs == 'SabNZBd') {
echo $saburl;
} elseif($qs == 'Transmission') {
echo $transmission_web;
} elseif($qs == 'uTorrent') {
echo $utorrent_url;
} elseif($qs == 'XBMC') {
echo str_replace("vfs/","",$xbmcimgpath);
} elseif($qs == 'HeadPhones') {
echo $HEADPHONES_URL;
} elseif($qs == 'JDownloader') {
echo $jd_weburl;
} elseif($qs == 'SubSonic') {
echo $subsonicurl;
guy_smiley:) Wrote:OK, I put the file back and it won't go past servercheck.php again.
This is my mfp.conf for Apache2 in ./sites-enabled
[code]
<VirtualHost *:80>
SSLProxyEngine on
ProxyRequests On
chrisuk11 Wrote:Is there a guide for setting up a secure web server for windows so I can use this software ?
The webserver would be installed on my NAS or PC? Whichever would be prefferred option?
Started looking through the thread, but 172 pages is a lot to trawl through.
I have done some research and I beelive apache could be used? The only concern I have, is setting this up incorrectly, as this would involce opening up ports etc.
Any guidance / links etc would be greatly appreciated
External website - www.server.com
Router - Only forwards port 8080 from external
<VirtualHost *:8080>
ProxyRequests Off
ProxyErrorOverride On
<Proxy *>
Order Allow,Deny
Allow from all
</Proxy>
<Location /sab/>
ProxyPass http://127.0.0.1:9002/
ProxyPassReverse http://127.0.0.1:9002/
</Location>
<Location /tv/>
ProxyPass http://127.0.0.1:9003/tv/
ProxyPassReverse http://127.0.0.1:9003/tv/
</Location>
<Location /movies/>
ProxyPass http://127.0.0.1:9004/
ProxyPassReverse http://127.0.0.1:9004/
</Location>
<Location /music/>
ProxyPass http://127.0.0.1:9005/
ProxyPassReverse http://127.0.0.1:9005/
</Location>
<Location /xbmc/>
ProxyPass http://192.168.1.5:9203/
ProxyPassReverse http://192.168.1.5:9203/
</Location>
ProxyPass http://192.168.1.5:9203/jsonrpc
ProxyPassReverse http://192.168.1.5:9203/jsonrpc
</Location>
<Location /xwmm/>
ProxyPass http://192.168.1.5:9203/XWMM/movies/
ProxyPassReverse http://192.168.1.5:9203/XWMM/movies/
</Location>
</VirtualHost>
$GLOBAL_MACHINE = false;
$GLOBAL_USER_PASS = true;
$GLOBAL_IP = $_SERVER["HTTP_HOST"];
$GLOBAL_USER = 'xxxxxxx';
$GLOBAL_PASS = 'xxxxxxx';
$REVERSE_PROXY = true;
$XBMC_WEBROOT = 'xbmc';
$SICKBEARD_WEBROOT = 'tv';
$COUCHPOTATO_WEBROOT = 'movies';
$SABNZBD_WEBROOT = 'sab';
$navlink;
$navlink["XBMC"] = '/xbmc/';
$navlink["XWMM"] = '/xwmm/';
$navlink["SabNZBd"] = '/sab/';
$navlink["Sickbeard"] = '/tv/';
$navlink["CouchPotato"] = '/movies/';
$navlink["HeadPhones"] = '/music/';
host = 0.0.0.0
port = 9004
urlbase = movies
web_port = 9003
web_host = 0.0.0.0
web_ipv6 = False
web_log = 0
web_root = /tv
[SickBeard]
host=0.0.0.0
port=9003
username=xxxxx
password=xxxxx
web_root=/tv
host = 0.0.0.0
port = 9002
Aenima99x Wrote:MFP Config
SickBeard AutoProcessTV.cfgCode:$GLOBAL_MACHINE = false;
$GLOBAL_IP = $_SERVER["HTTP_HOST"];[/quote]
2 differences here: I have set global-machine to "true" and put in my actual URL instead of $_SERVER["HTTP_HOST"].
[quote=Aenima99x][b]SickBeard Config.ini[/b]
[CODE]web_root = /tv
Code:[SickBeard]
web_root=/sickbeard
Aenima99x Wrote:The ONLY thing I don't have working right now is Headphones, but that's only because it doesn't have the webroot options in the program yet. Hope this helps.
steve1977 Wrote:Thanks, this is great. While mine is working, I have a few settings, which are different from yours. Would love to understand differences and whether they matter or not:Sure, glad to help cuz I know what a pain it is to get working.
Quote:2 differences here: I have set global-machine to "true" and put in my actual URL instead of $_SERVER["HTTP_HOST"].I only don't have global-machine set to true because I have 2 boxes, my NAS running the webserver & all the apps and my HTPC running only XBMC. As for the $_SERVER["HTTP_HOST"] - I was having some trouble with everything working properly inside my network and externally and this fixed it. I'm not real sure on the implications of using this yet, but I'll let you know what I find out.
Quote:I have put both web-roots to /tv, which is my reverse-proxy (and I thought so it yours).Yeah that was my bad, it should be /tv in both.
Quote:Where would you use this for? You will still need it manually in the navbar anyways and headphones and no widget is addressing it yet?Haven't tried Subsonic, but I'll give it a look.
Related question - have you tried using subsonic? I believe that this is the very best part, but I don't get it working as part of the navbar (to be more precise, I get videos working, but dont get audio to play).
