2011-01-03, 02:12
Trying (and failing) to run this off my personal domain, using statically set IPs and such. Running into some problems though. It seems like the software is unable to pull information, despite the fact that I've coded in the right IPs and that if I go to things myself it works. For example, I get this error under both Recent TV and XBMC Library:
Now, if I click the Service link, it works just fine, so I'm not sure what the problem is. I'd really like to run this off my webserver, since I don't have an always-on machine besides my HTPC, and I'd rather not install a webserver onto it. Anyone have any ideas what might be causing this error?
My other problem is that absolutely nothing appears under SABnzbd or Coming Episodes. I've taken a screenshot so you can see what I'm talking about. You can see it here: http://imgs.nickkuras.com/mfp.png
If I can't run this off my domain for some reason, that's fine, though I'd much prefer to. I can't really see why it wouldn't work though. Anyone have any ideas?
Quote: XBMC's JSON API did not respond.
Check your configuration (config.php) and that the JSON service variable is configured correctly and that the Service is running.
{"jsonrpc": "2.0", "method": "VideoLibrary.GetRecentlyAddedEpisodes", "params" : { "start" : 0 , "end" : 15 , "fields": [ "genre", "director", "trailer", "tagline", "plot", "plotoutline", "title", "originaltitle", "lastplayed", "showtitle", "firstaired", "duration", "season", "episode", "runtime", "year", "playcount", "rating", "writer", "studio", "mpaa", "premiered", "album" ] }, "id" : 1 }
