fezster Wrote:Which mkv splitter are you using ? Probably worth posting your mediasconfig.xml. Have you ever installed haali or matroska splitter (or another codec pack) - Im wondering if the splitter you are using or have registered is causing this.
Fezster - Here is mediasconfig.xml:
Maybe you can find something I am missing....Thanks
- <mediasconfig>
- <rules>
- <!-- DVD RULES
- <!-- Iso still return a crash on this filter.
- <rule filetypes="iso">
<source filter="lavfsplitter" />
<splitter filter="lavfsplitter" />
<video filter="ffdvideodec" />
<audio filter="lavaudiodec" />
</rule>
- <!-- If you want to play a dvd select the file /dvdfolder/VIDEO_TS/VIDEO_TS.ifo
- <rule filetypes="ifo">
<source filter="dvdnavigator" />
<splitter filter="dvdnavigator" />
<video filter="mpeg2videodec" />
<audio filter="mpaaudiodec" />
</rule>
- <!-- END DVD RULES
- <rule filetypes="avi|divx">
<source filter="avisource" />
<splitter filter="avisplitter" />
<video filter="mpcvideodec" />
<audio filter="ffdaudiodec" />
</rule>
- <rule filetypes="ogm">
<source filter="oggsource" />
<splitter filter="oggsplitter" />
</rule>
- <rule filetypes="flv">
<source filter="flvsource" />
<splitter filter="flvsplitter" />
</rule>
- <rule filetypes="mp4">
<source filter="mp4source" />
<splitter filter="mp4splitter" />
</rule>
- <rule filetypes="mov|m4v">
</rule>
- <rule filetypes="m2v">
<source filter="mpegsource" />
<splitter filter="mpegsplitter" />
</rule>
- <rule filetypes="ts|mpeg|mpg|m2ts">
</rule>
- <rule filetypes="mkv">
<source filter="mkvsource" />
<splitter filter="mkvsplitter" />
- <!-- You can do like that to specifie a DXVA only filters.
If you want to use the same filter for DXVA and non DXVA media, just add
a single <video> line.
<video>
<video dxva="true" filter="mpcvideodec" />
</video>
- <!-- <extra>
<extra filter="ac3filter" />
<extra filter="dcgraphiceq" />
</extra>
- <!-- Shaders example
Must starts with <shaders> and ends with </shaders>
Inside, specify your shader like that :
<shader id="x" dxva="true" videocodec="h264" audiocodec="mp3" ... />
x is the ID of the shader, declared in the /system/DSPlayer/Shaders/shaders.xml file
- <!-- <shaders>
<shader id="7" />
</shaders>
</rule>
- <rule filetypes="wmv">
<source filter="wmasfreader" />
<splitter filter="wmasfreader" />
<video filter="wmvideodecoder" />
<audio filter="wmaudiodecoder" />
</rule>
- <!-- You need Real Alternative in order to read real media files
- <rule filetypes="rmvb">
<source filter="realsource" />
<splitter filter="realsplitter" />
<video filter="realvideodec" />
<audio filter="realaudiodec" />
</rule>
- <!-- New rule for preferred streaming source filter
- <rule url="true" filetypes=".*">
<source filter="internal_ffmpegsource" />
</rule>
</rules>
</mediasconfig>
UNDER USER/***/APPDATA/ROAMING I have this....
- <mediasconfig>
- <rules>
- <rule filetypes="ts|mpeg|mpg|m2ts|bdmv|mkv">
<source filter="lavsource" />
<splitter filter="lavsplitter" />
<video filter="lavvideo" />
<audio filter="lavaudio" />
</rule>
</rules>
</mediasconfig>
I think maybe this is the problem....I switched this when I was trying to get LAV to work. Maybe this should be deleted
Hopefully you haven't abandoned DSPlayer completely in favor of Daniela's patch..
Mark
