Ha, with so many problems, I can't but help wonder what you are doing wrong
(2022-08-18, 02:09)SirLancy Wrote: [ -> ]1. Why isn't there an option to select the title of the film from a list like some other scrapers?
There is. This function is not scraper related, it is a Kodi core function.
If the movie is already in your library, press the Refresh button from the Information Page.
If the movie is not yet in the library, find the movie in Videos>Files then press the
i button on your keyboard, or "Scan to library" from the Context menu.
If you are using the correct scrapers mentioned below, then you can also use ID searches...
Movies...
https://kodi.wiki/view/Add-on:The_Movie_Database_Python
TV Shows...
https://kodi.wiki/view/Add-on:TMDb_TV_Shows
(2022-08-18, 02:09)SirLancy Wrote: [ -> ]can't get Metacritic and Rotten Tomatoes ratings to display
I don't know about this as I don't have an OMDB key to test.
One common problem is that some movies don't have ratings listed there.
(2022-08-18, 02:09)SirLancy Wrote: [ -> ]. I noticed The Movie Database Python has the option to pull ratings from Trakt.TV, although I couldn't get it to work.
Why can't you get this to work? It works.
No, there won't be Trakt ratings in UMS.
(2022-08-18, 02:09)SirLancy Wrote: [ -> ]Since this add-on only works for movies, does anyone have any recommendations for an Information Provider add-on for TV Shows? Kodi has these by default 1. The Movie Database 2. The TVDB (new) 3. The TVDB v4 4. TMDb TV Shows 5. TV Maze 6. XEM
Where did you get the numbering from?
Use TMDb TV Shows if you want data from TheMovieDB
Use The TVDB v4 if you want data from TVDB.
Forget the rest as they are no longer maintained but need to remain for users on older systems, unfortunately.
If you are still experiencing problems, then provide a
Debug Log that captures the problem. Without it we have no idea what you are doing and it becomes a guessing game.
