2015-07-28, 15:18
(2015-07-28, 07:53)seftongillis Wrote: [ -> ]Hello,
I wonder if you could help me, I have an issue with an nfo file. I installed the VideoExtras addon and successfully scraped a movie in its own folder with an extra in its own Extras folder. However, when trying to scrape another movie of the same set, with a videoextras.nfo file inside its folder pointing to the other Extras directory (shared extras), the scraping fails (no title, no cast, no crew, etc.). I suspect it's because the nfo file is interpreted to have information about the movie rather than the extras. If I remove the nfo file the movie is scraped properly but the extra is not associated with the movie. I understand nfo files are meant to be ignored when they don't have the same name as the movie file, but in this case the videoextras.nfo file is always picked up by this scraper.
Here's the videoextras.nfo file:
Code:<?xml version='1.0' encoding='UTF-8'?>
<videoextras>
<directory>..\Raiders of the Lost Ark (1981).DVD [en, es-lat, sub] [xtra]\Extras</directory>
</videoextras>
I store the movies in VIDEO_TS folders inside the movie folders, along with the Extras folders when they apply. However, just to make sure this wasn't the problem, I tested the scraper using a single movie file in a folder, rather than a DVD structure, and the problem persisted.
Any help will be greatly appreciated.
Have you tried creating a new "ignore" in advanced settings? Just a wild guess, but might work.
