2022-12-21, 19:56
Hello together!
Unfortunately, I also have some issue with the UMS since some time.
Today I tried do do a fresh scan of my library, an things went worse.
I have all my movies saved as mkv, and did not use any nfo files.
What I already found out:
mkv files can store some meta data in the header, for example the "Title" and a "Date".
I never maintained those fields, and started only recently to play with those information (Thx to mkvtoolnix)
However, seems that Kodi/UMS is using this information when the field is set (even if it is empty).
The problem is now the following:
When I put the "Title" field to the "Name (Year)" format, UMS will fail to fetch the information on tmdb.
The following examples I tested with the movie "Passengers" from 2016.
The "Title" field as well as the file name is set to "Passengers (2016)"
The search URL based on the "Title" field of the mkv file is:
https://api.themoviedb.org/3/search/movi...2016)&year=
The result set is empty.
To my understanding, the URL should look like:
https://api.themoviedb.org/3/search/movi...&year=2016
I already performed a mass update of the "Title" metadata. For all my mkv movie files I set the "Title" fields to the format "Title (Year)".
However, it is not applicable to set the "Date" meta information on every file (the "Title" will also be set automatically by MakeMKV, for example)
Maybe to update the parser config to move the "(Year)" part into the correct location of the URL?
Tried to understand the universal.xml configuration, but could not figure out how to deal with nested regex and random input/output buffer numbers.
Cheers
Hook
Cheers
Hook
