I'm having issues installing Universal Scraper. When I try to install it briefly flashes "Downloading 0%" and then returns to the Add-Ons screen without being downloaded/installed. Is this currently offline with the release of FrodoRC2? I am still using Eden although I'm thinking of upgrading to FrodoRC2. I want to try Unuiversal Scraper out as I'm fed up using United States (MPAA) certification on my films and want to get the UK ones. However, if I set the default scraper of TMDB to en/gb I get GERMAN certifications!
EDIT: OK, finally got it to install, but now this is also showing GERMAN as per
http://en.wikipedia.org/wiki/Freiwillige...wirtschaft certification - the images are certainly not the UK BBFC
http://en.wikipedia.org/wiki/British_Boa...sification ones. Wonder if this is a SKIN issue rather than a scraper one?
Skin issue...
Official Confluence doesn't provide images other than us, so I guess you use another skin.
Some skins require to have a 'UK:' pretag instead of the 'Rated ' pretag to have the images show correctly. Best to ask in the forum of the skin of your choice.
(2012-12-23, 10:48)olympia Wrote: [ -> ]Olivia? Huhh?
I will definitely not put it in as odds are pretty high that this would end up in many false positive hit during bulk scraping. This is because there are many similar titles for TV series and Movies, even from the same year, so XBMC might pick the wrong one.
Well - what's worst - wrong hit or no possible hit? I guess I have to wait for the old IMDB scraper to get back on it's feet. On the other hand - if one could choose whether or not to get all the - potentially wrong - hits or not.. then everybody would be happy ?
Just a couple from my collection -
- The Good, the Bad and the Ugly (1966) shows as Il buono, il brutto, il cattivo. (original title)
http://www.imdb.com/title/tt0060196/
- The 1996 Movie Emma (with Gwen Paltrow)
http://www.imdb.com/title/tt0116191 cant be selected (even manually) it is confused with a TV Movie of the same name - also in 1996 named Emma with Kate Beckinsale
http://www.imdb.com/title/tt0118308/
- Saturday Night Live the Best of '06/'07 is also not registering properly, but there is no IMDB ID for it that I can find. Im not sure which would be the best scraper since it doesnt really correspond to a specific episode of a season...Any suggestions? (Amazons Link -
http://www.amazon.com/Saturday-Night-Liv...B00103589Y)
Should I use a different scraper for the likes of Band of Brothers/John Adams/The Pacific?
Jamie
(2012-12-24, 07:36)Sportzter Wrote: [ -> ]- The Good, the Bad and the Ugly (1966) shows as Il buono, il brutto, il cattivo. (original title) http://www.imdb.com/title/tt0060196/
There is a setting for preferred title language. You left it on 'Keep Originaltitle'
(2012-12-24, 07:36)Sportzter Wrote: [ -> ]- The 1996 Movie Emma (with Gwen Paltrow) http://www.imdb.com/title/tt0116191 cant be selected (even manually) it is confused with a TV Movie of the same name - also in 1996 named Emma with Kate Beckinsale http://www.imdb.com/title/tt0118308/
I will need to look at this closer...
edit: ok, this is not fully valid. The 1996 Movie Emma (with Gwen Paltrow) get scraped correctly from IMDb (if you look at the data and plot), but the poster is wrongly scraped from themoviedb.org which is an IMDb ID issue on themoviedb.org between the two movies you mention above. Please fix this if you have the time.
(2012-12-24, 07:36)Sportzter Wrote: [ -> ]- Saturday Night Live the Best of '06/'07 is also not registering properly, but there is no IMDB ID for it that I can find. Im not sure which would be the best scraper since it doesnt really correspond to a specific episode of a season...Any suggestions? (Amazons Link - http://www.amazon.com/Saturday-Night-Liv...B00103589Y)
Yes, these are all TV Shows. They all belong to the TV library not to the movie library and the tvdb scraper can/should be used on them.
Thanks for the quick reply
Addons --> Enabled Addons --> Movie Information --> Universal Scraper -->- I changed the settings to be USA/International (from Keep Original). - The title is still in Spanish
I am probably missing something obvious ...sorry.
How can I go about do that. I have the time, im just not sure what "this" is or where to fix it.
Thanks again.
Jamie
(2012-12-24, 08:55)Sportzter Wrote: [ -> ]There is a setting for preferred title language. You left it on 'Keep Originaltitle'
Addons --> Enabled Addons --> Movie Information --> Universal Scraper -->- I changed the settings to be USA/International (from Keep Original). - The title is still in Spanish I am probably missing something obvious ...sorry.
Wrong place. You only set the default scraper settings there, while you can configure the settings per source. If you already configured the source, change the default at the above place won't help. You need to invoke 'change content' from the context menu of the source and change the settings there.
(2012-12-24, 08:55)Sportzter Wrote: [ -> ]but the poster is wrongly scraped from themoviedb.org which is an IMDb ID issue on themoviedb.org between the two movies you mention above. Please fix this if you have the time.
You need to register an account at themoviedb.org, then you will be able to edit movies.
Perfect! Thanks for the clarification on the source.
Both issues are now resolved.
Jamie
This is a great plugin, because it recognized most of my 500+ movies. But there are 2 titles it can not match, even manually. I can not find the following titels, and I tried their different international titles as well:
http://www.imdb.com/title/tt0066357/
http://www.imdb.com/title/tt0157383/
Any idea as to why that is? I am on the latest XBMC beta release for OSX btw.
I don't find them with IMDb web search either, how could the scraper find them then?
You can enter the imdb id in the search dialog though and then the scraper will find them.
hey olympia thanks for adding BR in options. Though you did a small mistake here, BR means Brazil, right? In Brazil we speak Portuguese (PT in list), so BR should be added only to certification country list, not in other language options like for title.
Other question, the scraper (not sure) isn't saving crew for some movies, for example movie
Dredd:
http://api.themoviedb.org/3/movie/49049/...anguage=pt *change the api key*
returns:
"crew": [
"id": 43141,
"name": "Pete Travis",
"department": "Directing",
"job": "Director",
"profile_path": null
"id": 57653,
"name": "Carlos Ezquerra",
"department": "Writing",
"job": "Writer",
"id": 2036,
"name": "Alex Garland",
"job": "Screenplay",
But the field director still blank here. Any idea or it is my system?
Thanks again.
EDIT:
Sorry for info above about TMDB, I'm using IMDBFULL for crew info in options, anyway it should return right information, no? the info is on IMDB:
http://www.imdb.com/title/tt1343727/
Right, I see the issue. Will be fixed in the next ~12 hours.
Does the US set up the Collection names or is that done through the Core XBMC application?
(I have the Collection Option setting turned on)
I want to change a collection name and/or edit what movies are in a collection if possible.
Jamie
