(2013-01-04, 11:33)shms Wrote: [ -> ]does the android version work now?
Last time I checked with my tablet, it worked just fine. Sadly, the Rockchip soc my tablet has doesn't support hardware acceleration (and I doubt it will ever do) so I haven't used it that much.
automatic channel logos didnt work for me! If i set them manually they aren't saved and only visible in the actual session.
greetings
My log files give me those errors on raspberry pi! Can some one help me please?
19:35:45 T:2768237632 WARNING: FillBuffer: curl failed with code 7
19:35:45 T:2768237632 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
19:35:45 T:2768237632 ERROR: Open - failed to open source <http://admin:[email protected]:8089/api/epg.html?lvl=2&channel=563521185186310&start=41281.771458&end=41284.813125>
19:35:45 T:2768237632 ERROR: AddOnLog: DVBViewer Client: GetEPGForChannel Unable to parse XML. Error: 'Warning: No XML tag found'
19:35:45 T:2768237632 ERROR: PVR - GetEPGForChannel - addon 'DVBViewer:192.168.1.3' returned an error: server error
19:35:45 T:2768237632 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'ESP HD Czech' from client '1': server error
19:35:45 T:2768237632 ERROR: EPG - Update - failed to update table 'ESP HD Czech'
19:35:45 T:2946647104 WARNING: FillBuffer: curl failed with code 7
19:35:45 T:2946647104 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
19:35:45 T:2946647104 ERROR: Open - failed to open source <http://admin:[email protected]:8089/status.html?aktion=status>
19:35:45 T:2946647104 ERROR: PVR - exception 'basic_string::substr' caught while trying to call 'SignalQuality' on add-on 'DVBViewer:192.168.1.3'. Please contact the developer of this add-on: jdembski, A600
As a long user of DVBViewer I want to ask some questions!
- Is it possible to start XBMC with the plugin and switch directly to the last channel?
- I think this can be done by the plugin itself: I am watching Live TV, now I start to playback a recording. After stopping the playback it would be nice that the plugin switch back to the last channel what I was watching before playback.
- Any idea if timeshift will be possible with the recording service?
thx to A600 for this plugin!
Yes you can switch to the last channel by enabling this option in live tv settings!
(2013-01-08, 09:46)Portisch Wrote: [ -> ]As a long user of DVBViewer I want to ask some questions!
#1: Settings->Live TV->Playback-> "Continue last channel on startup"
Quote:#1: Settings->Live TV->Playback-> "Continue last channel on startup"
thx for this info! I will try it.
(2013-01-08, 13:01)dhjgv Wrote: [ -> ]#1: Settings->Live TV->Playback-> "Continue last channel on startup"
It would be great if "Continue last channel on startup" can be assigned to a shortcut key.
I think its better for the developer to focus on bugs and not features at this time
And I think this is not a thing A600 has to care about but the XBMC Devs themself.
Punch me if I am wrong
(2012-12-29, 02:13)A600 Wrote: [ -> ] (2012-12-27, 02:50)polosatix Wrote: [ -> ]That's strange, because dvbviewer itself switches any channels very fast. So the problem is not in the hardware tuner (CT 3650-CI).
I saw your bug report at the DVBViewer forum so I hope it'll be fixed
Could someone here show me the post in the DVBViewer Forum regarding the issues with an CT 3650, cause I have exactly the same problem and the same TV-Card
How can this be solved?
Thanks for any Info.
Regards
Vlaves
I have another question about this plugin.
I am realy not sure if this is the right position for this or if it is related to XBMC itself.
About this info screen:
http://www.dvbviewer.tv/forum/topic/4746...ntry375582
Is there a way to set the cursor to the active channel? Like in this picture it should be "TVE HD".
But on my side the active cursor position is every time the channel on the top.
Like on this example it is "Neox".
(2013-01-10, 15:30)Portisch Wrote: [ -> ]I have another question about this plugin.
What happens when you choose the channel within this miniEPG and reopen it? Is it still on the top channel?
(2012-12-19, 15:49)A600 Wrote: [ -> ] (2012-12-18, 18:28)Dakkar Wrote: [ -> ]Then the question become: does it depend on you or is someone else we are waiting for having this implemented ?
I have to do some more testing before.
Hello!
Do we have any update on this?
How is testing proceeding?
Thank you!
P.
