(2013-02-24, 21:37)Portisch Wrote: [ -> ]I modfied now the latest source from A600 to use RTSP streaming instead of UPnP for the live streaming.
Also I found a bug about the favorites!
The original source was using a 32 bit id for the favorites channel but the new system of DVBViewer is 64 bit.
This is may the reason why some favorites channels where missing in XBMC.
This is corrected in this build but it is necessary to update your favorites.xml to 64 bit ids!!
The best way is to delete the favorites.xml of DVBViewer an make a new one!
Otherwise the favorites will not be found in the channel list.
I attached a modified version what is using the getchannelsxml.html option of the new Recording Service.
Only Win32 is here for testing. Also only video channels are right now supported.
The bad thing is that channel switching time didn't change much. I think there have to be somewhere else something optimized...
Somebody an idea?
XBMC_dvbviewer_win32.zip
Thank your for this.
I seem to currently have 2 versions of this dll on my pc
C:\Program Files (x86)\XBMC\addons\pvr.dvbviewer 178KB
C:\Users\Chris\AppData\Roaming\XBMC\addons\pvr.dvbviewer 188KB
Which one do I need to change, or shouldn't I have 2?!
I've done some experimenting but...
After a complete uninstall and re-install I now just have one instance of the dvbviewer add-on in C:\Program Files (x86)\XBMC\addons\pvr.dvbviewer
Trouble is, now I can't even view half my channels! My favourites list still has my unedited channel names in. Anyone else have the same or similar problem?
Quote:Trouble is, now I can't even view half my channels! My favourites list still has my unedited channel names in. Anyone else have the same or similar problem?
I will do a fix for the 32bit channel id in the favorites.xml later this day!
(2013-01-30, 17:42)piipes Wrote: [ -> ] (2013-01-30, 15:39)newlynx Wrote: [ -> ]Does the plugin support subtitles (DVB or teletext) because I cannot find an option for that or it is part of the PVR mechanism?
Yes it support. Command is nextsubtitle, i use eventghost. Think that keyboard L is right key.
Unfortunately I cannot make it work. Subtitles are working in DVBViewe but not in XBMC.
Here a update of the Win32 addon. This should load all favorites channels now.
RTSP (SAT>IP) streaming is used and RS 1.24 and higher is required.
Thanks for that
I get my favourites in the channel list (although they don't seem to match the epg!).
And when I press 'e' to get the timeline epg large numbers of channels are missing.
In my favourites.xml I have (for example) this:
-<section name="5"> <entry name="Header">2385227835863356112|Channel 4 HD (AC3,eng)</entry> </section
and in the xbmc.log I have this (for all the channels I think):
16:41:43 T:5972 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
16:41:43 T:5972 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
16:41:43 T:5972 ERROR: XFILE::CFileCache::Open - failed to open source <http://127.0.0.1:8089/api/epg.html?lvl=2&channel=562958676201247&start=41331.653970&end=41334.695637>
16:41:43 T:5972 ERROR: AddOnLog: DVBViewer Client: Dvb::GetEPGForChannel Unable to parse XML. Error: 'Warning: No XML tag found'
16:41:43 T:5972 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'DVBViewer:127.0.0.1' returned an error: server error
16:41:43 T:5972 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Channel 4 HD (AC3,eng)' from client '1': server error
16:41:43 T:5972 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Channel 4 HD (AC3,eng)'
I did recreate the favourites.xml. This is a win 7 64bit HTPC with (I assume) 32bit dvbviewer and 32bit XBMC. Am I still doing something really dumb?!
Still not getting timer entries on atv1 or raspberry pi linux distros.
After a lot of digging i can see in the debug logs that all of the tiners are being retrieved fron the recording service.
There must be a difference where they are being stored or displayed by the addon for linux as win7 versions work fine.
Surely everyone using a pi or atv1 would be having this problem?? If not maybe i have a config issue.
@Waka: I think this is releated to channels who doesn't have an EPG Info or it is not found in the epg.dat of the RS. Delete the epg.dat in your RS configuration folder. This is not realy an error. Just no EPG info for the channel.
Also I have done a debug log of connecting to the Recording Service.
The XBMC part is:
Quote:18:26:34 T:4300 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
18:26:38 T:4300 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
So ffmpeg needs here 4 seconds to demux the stream. If this is working properly the channel switching time should be decreased to 1-3 seconds...
Quote:18:26:31 T:4300 NOTICE: Creating InputStream
18:26:31 T:4300 DEBUG: PVRManager - PVR::CPVRManager::OpenLiveStream - opening live stream on channel 'arte HD'
18:26:31 T:4300 DEBUG: opening live stream on url 'rtsp://192.168.1.10:554/?src=1&freq=11493&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11493,22000,9750,0,0,3,2,5112,5111,5110,10302,6,0,24,0,1019,1&pids=0,18,5110,5111,5114,5112,5113,5116,'
18:26:31 T:4300 DEBUG: PVRFile - XFILE::CPVRFile::Open - playback has started on filename pvr://channels/tv/Alle TV-Kanäle/6.pvr
18:26:31 T:4300 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: rtsp://192.168.1.10:554/?src=1&freq=11493&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11493,22000,9750,0,0,3,2,5112,5111,5110,10302,6,0,24,0,1019,1&pids=0,18,5110,5111,5114,5112,5113,5116,
18:26:31 T:4300 NOTICE: Creating Demuxer
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
18:26:31 T:4300 DEBUG: Previous line repeats 1 times.
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] SDP:
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] v=0
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] o=- 348390761 1 IN 192.168.1.10
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] s=SatIPServer:1 4
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] t=0 0
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] a=control:rtsp://192.168.1.10:554/stream=9
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] m=video 0 RTP/AVP 33
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] c=IN IP4 0.0.0.0
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] b=AS:5000
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] a=fmtp:33 ver=1.0;src=1;tuner=1,0,0,0,11493,h,dvbs2,8psk,off,0.35,22000,23;
18:26:31 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] a=inactive
18:26:31 T:3168 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:26:31 T:4996 DEBUG: Previous line repeats 2 times.
18:26:31 T:4996 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:31 T:4996 DEBUG: CurlFile::Open(0BF17008) http://192.168.1.10:...l?aktion=status
18:26:32 T:3168 INFO: XCURL:llLibCurlGlobal::CheckIdle - Closing session to http://192.168.1.10 (easy=0B968FA0, multi=01877FC8)
18:26:32 T:2152 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:32 T:2152 DEBUG: CurlFile::Open(0C0363A8) http://192.168.1.10:...l?aktion=status
18:26:32 T:2152 INFO: XCURL:llLibCurlGlobal::easy_aquire - Created session to http://192.168.1.10
18:26:34 T:4224 NOTICE: Thread CFileCache start, auto delete: false
18:26:34 T:4224 INFO: CFileCache:rocess - Hit eof.
18:26:34 T:4224 DEBUG: Thread CFileCache 4224 terminating
18:26:34 T:4300 ERROR: ffmpeg[10CC]: [rtsp] ignoring previously allocated packet on stream 0
18:26:34 T:4300 ERROR: Previous line repeats 5 times.
18:26:34 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] CSeq 4 expected, 0 received.
18:26:34 T:4300 ERROR: Previous line repeats 1 times.
18:26:34 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] PES packet size mismatch
18:26:34 T:1992 ERROR: Previous line repeats 3 times.
18:26:34 T:1992 NOTICE: Thread CFileCache start, auto delete: false
18:26:34 T:1992 INFO: CFileCache:rocess - Hit eof.
18:26:34 T:1992 ERROR: Previous line repeats 6 times.
18:26:34 T:1992 DEBUG: Thread CFileCache 1992 terminating
18:26:35 T:4300 ERROR: Previous line repeats 5 times.
18:26:35 T:4300 ERROR: ffmpeg[10CC]: [NULL] non-existing PPS referenced
18:26:35 T:4300 ERROR: ffmpeg[10CC]: [h264] non-existing PPS 0 referenced
18:26:35 T:4300 ERROR: ffmpeg[10CC]: [h264] decode_slice_header error
18:26:35 T:4300 ERROR: ffmpeg[10CC]: [h264] no frame!
18:26:35 T:4300 ERROR: ffmpeg[10CC]: [h264] non-existing PPS referenced
18:26:35 T:4300 ERROR: ffmpeg[10CC]: [rtsp] ignoring previously allocated packet on stream 0
18:26:35 T:4300 ERROR: Previous line repeats 10 times.
18:26:35 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] PES packet size mismatch
18:26:35 T:4996 ERROR: Previous line repeats 59 times.
18:26:35 T:4996 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:35 T:4996 DEBUG: CurlFile::Open(0C036008) http://192.168.1.10:...l?aktion=status
18:26:35 T:3184 ERROR: Previous line repeats 8 times.
18:26:35 T:3184 NOTICE: Thread CFileCache start, auto delete: false
18:26:35 T:3184 INFO: CFileCache:rocess - Hit eof.
18:26:35 T:3184 ERROR: Previous line repeats 1 times.
18:26:35 T:3184 DEBUG: Thread CFileCache 3184 terminating
18:26:35 T:2152 ERROR: Previous line repeats 11 times.
18:26:35 T:2152 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:35 T:2152 DEBUG: CurlFile::Open(0C036008) http://192.168.1.10:...l?aktion=status
18:26:36 T:4000 ERROR: Previous line repeats 2 times.
18:26:36 T:4000 NOTICE: Thread CFileCache start, auto delete: false
18:26:36 T:4000 INFO: CFileCache:rocess - Hit eof.
18:26:36 T:4300 ERROR: ffmpeg[10CC]: [rtsp] ignoring previously allocated packet on stream 0
18:26:36 T:4000 ERROR: Previous line repeats 3 times.
18:26:36 T:4000 DEBUG: Thread CFileCache 4000 terminating
18:26:36 T:4300 ERROR: Previous line repeats 44 times.
18:26:36 T:4300 ERROR: ffmpeg[10CC]: [h264] non-existing PPS referenced
18:26:36 T:4300 ERROR: ffmpeg[10CC]: [h264] non-existing PPS 0 referenced
18:26:36 T:4300 ERROR: ffmpeg[10CC]: [h264] decode_slice_header error
18:26:36 T:4300 ERROR: ffmpeg[10CC]: [h264] no frame!
18:26:36 T:4300 ERROR: ffmpeg[10CC]: [mp1] Header missing
18:26:36 T:4300 ERROR: Previous line repeats 3 times.
18:26:36 T:4300 DEBUG: ffmpeg[10CC]: [h264] Increasing reorder buffer to 1
18:26:36 T:4300 INFO: ffmpeg[10CC]: [h264] concealing 2974 DC, 2974 AC, 2974 MV errors
18:26:36 T:4300 DEBUG: ffmpeg[10CC]: [h264] Increasing reorder buffer to 2
18:26:36 T:4300 ERROR: Previous line repeats 37 times.
18:26:36 T:4300 ERROR: Previous line repeats 2 times.
18:26:36 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] PES packet size mismatch
18:26:36 T:4300 ERROR: Previous line repeats 1 times.
18:26:36 T:4996 ERROR: Previous line repeats 2 times.
18:26:36 T:4996 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:36 T:4996 DEBUG: CurlFile::Open(0C036008) http://192.168.1.10:...l?aktion=status
18:26:36 T:2176 NOTICE: Thread CFileCache start, auto delete: false
18:26:36 T:2176 INFO: CFileCache:rocess - Hit eof.
18:26:37 T:2176 DEBUG: Thread CFileCache 2176 terminating
18:26:37 T:4300 ERROR: ffmpeg[10CC]: [rtsp] ignoring previously allocated packet on stream 0
18:26:37 T:4300 ERROR: ffmpeg[10CC]: [mp1] Header missing
18:26:37 T:2152 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:37 T:2152 DEBUG: CurlFile::Open(0C036008) http://192.168.1.10:...l?aktion=status
18:26:37 T:4300 ERROR: Previous line repeats 1 times.
18:26:37 T:4300 ERROR: Previous line repeats 4 times.
18:26:37 T:3008 NOTICE: Thread CFileCache start, auto delete: false
18:26:37 T:3008 INFO: CFileCache:rocess - Hit eof.
18:26:37 T:3008 DEBUG: Thread CFileCache 3008 terminating
18:26:37 T:4300 ERROR: Previous line repeats 2 times.
18:26:37 T:4300 ERROR: Previous line repeats 3 times.
18:26:38 T:4996 DEBUG: CFileCache::Open - opening <status.html> using cache
18:26:38 T:4996 DEBUG: CurlFile::Open(0C036008) http://192.168.1.10:...l?aktion=status
18:26:38 T:4300 ERROR: ffmpeg[10CC]: [rtsp] ignoring previously allocated packet on stream 0
18:26:38 T:4300 ERROR: ffmpeg[10CC]: [mp1] Header missing
18:26:38 T:2864 ERROR: Previous line repeats 2 times.
18:26:38 T:2864 NOTICE: Thread CFileCache start, auto delete: false
18:26:38 T:2864 INFO: CFileCache:rocess - Hit eof.
18:26:38 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] decoding for stream 1 failed
18:26:38 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] Could not find codec parameters (Audio: mp1 ([6][0][0][0] / 0x0006), 0 channels, s16)
18:26:38 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] decoding for stream 5 failed
18:26:38 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] Could not find codec parameters (Unknown: none ([5][0][0][0] / 0x0005))
18:26:38 T:4300 DEBUG: ffmpeg[10CC]: [rtsp] Estimating duration from bitrate, this may be inaccurate
18:26:38 T:4300 INFO: ffmpeg[10CC]: Input #0, rtsp, from 'rtsp://192.168.1.10:554/?src=1&freq=11493&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11493,22000,9750,0,0,3,2,5112,5111,5110,10302,6,0,24,0,1019,1&pids=0,18,5110,5111,5114,5112,5113,5116,':
18:26:38 T:4300 INFO: ffmpeg[10CC]: Metadata:
18:26:38 T:4300 INFO: ffmpeg[10CC]: title : SatIPServer:1 4
18:26:38 T:4300 INFO: ffmpeg[10CC]: Duration: N/A, start: 30207.839844, bitrate: 832 kb/s
18:26:38 T:4300 INFO: ffmpeg[10CC]: Program 10301
18:26:38 T:4300 INFO: ffmpeg[10CC]: Program 10302
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:5: Unknown: none ([5][0][0][0] / 0x0005)
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 54.61 fps, 50 tbr, 90k tbn, 100 tbc
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:3(deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:2(fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:1(deu): Audio: mp1 ([6][0][0][0] / 0x0006), 0 channels, s16
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:6(deu): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:4(deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, s16, 448 kb/s
18:26:38 T:4300 INFO: ffmpeg[10CC]: Stream #0:7(fra): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
18:26:38 T:4300 INFO: ffmpeg[10CC]: Program 10303
18:26:38 T:4300 INFO: ffmpeg[10CC]: Program 10304
For me using the RTSP DLL from Portisch is muuuch slower then UPNP. Channel switching is really at 5-6 seconds instead of 1-2 sec. with upnp.
I don't know what is the difference of my system that the channel switching is that fast, but of course I would like to have it even quicker^^
Portisch
Could you may provide your modified source code??
Portisch
If I get it right, you're just working on a windows version of this plugin right?
So is there a chance that maybe a600 implements it in the "original" plugin so that any platform profits from this?
I'm using a raspberry pi with the recording service running on my server and it would be really nice, to use rtsp instead of upnp.
Somebody an idea?
Portisch,
Slow channel switching times is due to xbmc doing its 'thing' there is a pull request fix by fernetmenta waiting to be merged with xbmc mainline that apparently fixes this. See here:
https://github.com/xbmc/xbmc/pull/1757
Explained here:
http://forum.xbmc.org/showthread.php?tid=145063
I have done a lot of changes already for the plugin in work together with the DVBviewer team.
Loading the channels/favorites/recordings is much speeded up now.
But I have to conntect A600 for the changes because he is the author of the plugin.
Or how to upload the modfied sources of the addon?
Also I just know how to compile the addon for win32.
(2013-02-27, 13:51)aceofclubs Wrote: [ -> ]Still not getting timer entries on atv1 or raspberry pi linux distros.
Yes same problem for me on the raspberry pi
Somebody can give me info how to compile the source for other platforms?
I use debian with the original pvr addon source:
git clone
https://github.com/opdenkamp/xbmc-pvr-addons.git
cd xbmc-pvr-addons
./bootstrap
./configure
make zip
But this will build the linux version. How to compile it for android, ios,....
Thank you portisch - I really appreciate the work and the time you spend in this project.
I hope for a new raspbmc build!
