(2020-05-16, 01:03)pkscout Wrote: [ -> ]OK, I've spent the last couple of hours going through the documenation, looking though the code, and looking at the XML files the script generates to try and figure out how I might add a custom widget to a skin (I"m using Arctic Zephyr 2, so I'm basically trying to mod the skin to add this widget as an option). I specifically would like to have the PVR status widget
this may be script.skin.helper.service pvr timers
(2020-05-16, 01:03)pkscout Wrote: [ -> ]OK, I've spent the last couple of hours going through the documenation, looking though the code, and looking at the XML files the script generates to try and figure out how I might add a custom widget to a skin (I"m using Arctic Zephyr 2, so I'm basically trying to mod the skin to add this widget as an option). I specifically would like to have the PVR status widget Estuary has that tells me what the next recording is and what is currently recording. I have the XML from Estuary to do it (probably needs some changes to adapt visually to AZ2), I just can't figure out how or where to add it so that it shows up in the widgets I can pick it as an option to show on the LiveTV section of the home screen. It feels like it should go into the templates.xml file, but ¯\_(ツ)_/¯. Here's some of the code I'm trying to use as a widget (it does the currently recording part).
xml:
<control type="image">
<top>80</top>
<left>16</left>
<width>670</width>
<height>225</height>
<texture border="21">dialogs/dialog-bg.png</texture>
</control>
<left>55</left>
<top>122</top>
<width>140</width>
<height>140</height>
<aspectratio>keep</aspectratio>
<texture background="true" fallback="DefaultVideo.png">$INFO[PVR.TVNowRecordingChannelIcon]</texture>
</control>
<control type="label">
<left>225</left>
<top>127</top>
<height>25</height>
<width>420</width>
<label>$LOCALIZE[19158]</label>
<aligny>center</aligny>
<font>font36_title</font>
<shadowcolor>black</shadowcolor>
</control>
<left>225</left>
<top>172</top>
<height>105</height>
<width>420</width>
<label>$INFO[PVR.TVNowRecordingDateTime][CR]$INFO[PVR.TVNowRecordingTitle][CR]$INFO[PVR.TVNowRecordingChannel]</label>
<font>font12</font>
</control>
BTW, it looks like AZ2 uses skin shortcuts to generate everything, so I can't just manually shove this somewhere without it getting overwritten.
pkscout, for a widget to show up as an option that you can choose when you customize the menu, it needs to be in the <widget groupings> section of the overrides.xml file in the shortcuts folder of the skin. You don’t necessarily need to have the code (actual controls) in the template.xml file, but I guess it is a good idea.
I don’t know the code of AZ2, so I can’t just provide you a snippet you can use. What I do in Amber for that widget in particular is that I have a toggle (radio button) in the menu customization dialog (script-skinshortcuts.xml) that sets whether a menu item will have the PVR widget or not. Then, in the skin’s menu presentation code (look in includes_horizontal_home.xml and includes_vertical_home.xml) I include the pvr widget group which will be visible if the toggle (which skinshortcuts sets as a property of the menu item) is on. The code for the PVR widget is in the file includes_shelf_contents.xml, around line 639. Again, this is what I do in Amber (
https://github.com/bartolomesoriano/skin.amber). You are more than welcome to look at the code and use whatever could be of help to you for AZ2.
Regards,
Bart
(2020-05-16, 08:37)bsoriano Wrote: [ -> ]@pkscout, for a widget to show up as an option that you can choose when you customize the menu, it needs to be in the <widget groupings> section of the overrides.xml file in the shortcuts folder of the skin. You don’t necessarily need to have the code (actual controls) in the template.xml file, but I guess it is a good idea.
I don’t know the code of AZ2, so I can’t just provide you a snippet you can use. What I do in Amber for that widget in particular is that I have a toggle (radio button) in the menu customization dialog (script-skinshortcuts.xml) that sets whether a menu item will have the PVR widget or not. Then, in the skin’s menu presentation code (look in includes_horizontal_home.xml and includes_vertical_home.xml) I include the pvr widget group which will be visible if the toggle (which skinshortcuts sets as a property of the menu item) is on. The code for the PVR widget is in the file includes_shelf_contents.xml, around line 639. Again, this is what I do in Amber (https://github.com/bartolomesoriano/skin.amber). You are more than welcome to look at the code and use whatever could be of help to you for AZ2.
Regards,
Bart
Thanks for the tips. I started down the path you mentioned, but for the life of me I could not figure out the visible condition so that the PVR widget showed up only on the screen you had indicated in the settings. AZ2 has a couple "fullscreen" widgets that only work if they are the first ones in the widget list (AZ2 ignores any widget after that), so I added a TV PVR Recording Widget in the PVR area in overrides.xml with a title that indicated it had to be in the first position. Instead of ignoring any widgets after that, I just did a conditional animation to push the other widgets down the screen if the TV PVR Recording Widget was present. It works, although I have a feeling I missed a more elegant solution. But after two hours of trying to figure out where various settings are stored with Skin Shortcuts, I'm OK with that. '-)
Maybe someone could help me with this:
I've got a list of widgets users can select from in my overrides.xml within
<widget-groupings>
part of that file. Under each defined node there're a few widgets defined via shortcuts like this:
xml:
<!-- Widget Grouping -->
<widget-groupings>
<!-- Video -->
<node label="3">
<node label="$LOCALIZE[31178]" condition="Library.HasContent(movies) | Library.HasContent(tvshows)">
<!-- Movies -->
<node label="$LOCALIZE[342]" condition="Library.HasContent(movies)">
<shortcut widget="NewMovies" label="$LOCALIZE[31179]" icon="DefaultRecentlyAddedMovies.png" widgetType="movies" widgetTarget="video">special://skin/extras/playlists/movies_recentlyadded.xsp</shortcut>
</node>
</node>
<content>video</content>
<node label="136">
<content>playlist-video</content>
</node>
<node label="32075">
<content>videosources</content>
<content>upnp-video</content>
</node>
</node>
</widget-groupings>
My skin offers four different types of widget layouts (size of the widget as well as size/aspect ratio of the individual widget icons) defined by
property="layout"
. For my
widgetdefault
default properties I can set the layout by adding corresponding
propertydefault
s with the same
labelID
Any idea how I can pre-define the layout property for shortcuts within the
widget-groupings
section?
(2020-05-22, 17:03)Chillbo Wrote: [ -> ]Maybe someone could help me with this:
I've got a list of widgets users can select from in my overrides.xml within <widget-groupings>
xml:
<widget-groupings>
<!-- Video -->
<node label="3">
<!-- Movies -->
</node>
</node>
<node label="136">
</node>
</node>
</node>
</widget-groupings>
My skin offers four different types of widget layouts (size of the widget as well as size/aspect ratio of the individual widget icons) defined by property="layout"
. For my widgetdefault
default properties I can set the layout by adding corresponding propertydefault
s with the same labelID
Any idea how I can pre-define the layout property for shortcuts within the widget-groupings
section?
you could read the files estuary mod shortcuts
that has the widgets layouts in Includes_Home.xml
(2020-05-23, 03:44)the_other_guy Wrote: [ -> ]you could read the files estuary mod shortcuts
I'm not sure I can follow. The Estuary Mod skin's
overrides.xml
as well as the widget layouts in its
Includes_Home.xml
look quite the same as mine in principle. But how do I define which layout a specific shortcut (pre-defined widget) should be shown with when being selected by a user?
The default widgets' layouts can be defined in the
overrides.xml
file via a
propertydefault
. Is there anything similar for shortcuts that can define a specific property for any shortcut? To me, it doesn't look like a
propertydefault
can be used for a
shortcut
i think you need them in template.xml for selectable widgets
i have it set for 1 widget type on estuary default menus
Includes_Home.xml
xml:
<include name="WidgetListCategories2">
<include content="CategoryLabel">
<param name="label">$PARAM[widget_header]</param>
<param name="label_focus">$PARAM[widget_header_focus]</param>
<param name="list_id" value="$PARAM[list_id]"/>
<param name="visible" value="$PARAM[visible]"/>
<param name="pvr_submenu">false</param>
</include>
<include content="BusyListSpinner">
</include>
<onleft>9000</onleft>
<control type="panel" id="$PARAM[list_id]">
<left>0</left>
<top>110</top>
<right>0</right>
<height>290</height>
<include content="WidgetListCommon">
</include>
<visible>$PARAM[visible]</visible>
<visible>String.IsEmpty(Container(9000).ListItem.Property(HideSubMenu))</visible>
<itemlayout width="240" height="240">
<control type="group">
<centertop>0</centertop>
<left>18</left>
<top>10</top>
<width>250</width>
<height>250</height>
<texture colordiffuse="99999999" fallback="$VAR[PosterThumbVar]">$INFO[ListItem.Icon]</texture>
<bordertexture border="21">overlays/shadow.png</bordertexture>
<visible>String.IsEqual(Skin.String(shortcutWidgetShape),0)</visible>
<bordersize>20</bordersize>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
<bordertexture border="21">overlays/shadow1.png</bordertexture>
<visible>String.IsEqual(Skin.String(shortcutWidgetShape),1)</visible>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
<bordertexture border="21">overlays/shadow2.png</bordertexture>
<visible>String.IsEqual(Skin.String(shortcutWidgetShape),2)</visible>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
<bordertexture border="21" >overlays/shadow3.png</bordertexture>
<visible>String.IsEqual(Skin.String(shortcutWidgetShape),3)</visible>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
<texture fallback="$VAR[PosterThumbVar]">$INFO[ListItem.Icon]</texture>
<bordertexture border="21">overlays/shadow4.png</bordertexture>
<visible>String.IsEqual(Skin.String(shortcutWidgetShape),4)</visible>
</control>
</control>
</itemlayout>
<focusedlayout width="240" height="240">
<depth>DepthContentPopout</depth>
<animation type="Focus">
<effect type="zoom" start="100" end="115" time="500" tween="sine" easing="inout" center="120,120" />
</animation>
<animation type="Unfocus">
<effect type="zoom" start="115" end="100" time="500" tween="sine" easing="inout" center="120,120" />
</animation>
<left>18</left>
<top>10</top>
<width>250</width>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
<bordertexture border="21">overlays/shadow3.png</bordertexture>
</control>
<left>18</left>
<top>10</top>
<width>250</width>
</control>
</control>
</focusedlayout>
<content>
<include>skinshortcuts-submenu</include>
</content>
</control>
</include>
Home.xml
xml:
<include content="WidgetListCategories2" condition="Library.HasContent(movies) + !Skin.HasSetting(hide_tvshowscategory)">
<param name="widget_header" value="$LOCALIZE[31148]"/>
<param name="widget_header_focus" value="$INFO[Container(5900).ListItem.Label, | ]"/>
<param name="list_id" value="5901"/>
<param name="visible" value="!Skin.HasSetting(UseSmallerCategories)" />
</include>
Unfortunately, I haven't found a way to easily pre-set the widget layout for pre-defined widgets offered in the
overrides.xml
. If anyone has an idea, I'd be very happy about it, but from what I can see, there's no proper way of doing this like there is for the
template.xml
widgets defined as the fallback home screen layout. Maybe this could be added in the future - defining different properties of widgets offered in the
overrides.xml
dialog?
Sorry if this has been discussed before or even is available somewhere else.
I'm looking to see if I can add the ability to cache a menu or widget to disk so that when my skin initially loads it has some content available instead of blank lists. And then reload the data later. It should also help on lower end hardware where many plugins are used in widgets as these could be loaded at a slower rate?
I have some trouble with the automatic menu building with the Amber skin master from 20.8.2020
Nvidia Shield 2017 + the very latest Kodi Matrix from 20.8.2020 as well.
Here is the log
https://paste.kodi.tv/avayociwit
Hopefully this is of some use.
