I already reinstalled xbmc 13.2 final but that does not change anything. What must I do to fix this issue?
20:16:32 T:4840 ERROR: C:\Users\Bj�rn\AppData\Roaming\XBMC\addons\script.skinshortcuts\resources\lib\datafunctions.py:407: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
if not xbmcgui.Window( 10000 ).getProperty( "skinshortcuts-overrides-user-data" + profileDir ) or not xbmcgui.Window( 10000 ).getProperty( "skinshortcuts-overrides-user" + profileDir ) == __profilepath__:
20:16:32 T:4840 ERROR: C:\Users\Bj�rn\AppData\Roaming\XBMC\addons\script.skinshortcuts\resources\lib\datafunctions.py:383: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
if not xbmcgui.Window( 10000 ).getProperty( "skinshortcuts-overrides-skin-data" ) or not xbmcgui.Window( 10000 ).getProperty( "skinshortcuts-overrides-skin" ) == __skinpath__:
20:16:32 T:4840 ERROR: Traceback (most recent call last):
20:16:32 T:4840 ERROR: File "C:\Users\Bj�rn\AppData\Roaming\XBMC\addons\script.skinshortcuts\resources\lib\xmlfunctions.py", line 83, in buildMenu
20:16:32 T:4840 ERROR: self.writexml( profilelist, mainmenuID, groups, numLevels, buildMode, progress, options )
20:16:32 T:4840 ERROR: File "C:\Users\Bj�rn\AppData\Roaming\XBMC\addons\script.skinshortcuts\resources\lib\xmlfunctions.py", line 395, in writexml
20:16:32 T:4840 ERROR: self.buildElement( submenuItem, submenuTree, submenu, "StringCompare(Container(" + mainmenuID + ").ListItem.Property(submenuVisibility)," + escapeXML( DATA.slugify( submenu ) ) + ")", profile[1], itemid = itemidsubmenu, options = options )
20:16:32 T:4840 ERROR: File "C:\Users\Bj�rn\AppData\Roaming\XBMC\addons\script.skinshortcuts\resources\lib\xmlfunctions.py", line 505, in buildElement
20:16:32 T:4840 ERROR: elif onclick.text.startswith( "ActivateWindow(" ) and xbmc.translatePath( "special://skin/" ) in onclick.text:
20:16:32 T:4840 ERROR: UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 11: ordinal not in range(128)
20:16:32 T:4840 NOTICE: Log level changed to 2
20:16:32 T:4840 NOTICE: Enabled debug logging due to GUI setting. Level 2.
20:16:32 T:4840 DEBUG: script.skinshortcuts: Profile found: Master user (special://masterprofile/)
20:16:32 T:4840 DEBUG: script.skinshortcuts: Includes file does not exist
20:16:32 T:6848 DEBUG: ------ Window Init () ------
20:16:32 T:4840 DEBUG: script.skinshortcuts: Loading shortcuts for group x1
20:16:32 T:4840 DEBUG: script.skinshortcuts: - No shortcuts
20:16:32 T:4840 DEBUG: script.skinshortcuts: Loading shortcuts for group x2
20:16:32 T:4840 DEBUG: script.skinshortcuts: - Loaded file C:\Users\Björn\AppData\Roaming\XBMC\addons\skin.aeon.nox.5\shortcuts\x2.DATA.xml
20:16:32 T:4840 DEBUG: script.skinshortcuts: Failed to write menu
