(2017-02-23, 13:24)sualfred Wrote: [ -> ]Servus,
could you please provide me the debug log?
I have to check what dependencies are causing it.
Edit:
Solved. Repo was buggy.
i think this was for me !...?
Yesterday, first i downgraded to KODI 17.0 RC (clean install),
Then i tryed to install fTV (with TV and mods). - Same Error-Window
Then i installed fTV (Krypton) an it works fine...!!! No Error during insall-process...!
The only problem is: i insalled ipTV via "simple client list", but i cant see anything.
Maybe not a skin-problem - i will try again till it works.
sualfred
Final questons:
WHEN (time) did you upload the "new" Repo...?
Should i reinstall everything (clean), or can i overwrite the old Repo...?
Should i install the Krypton-one or the TV+Mods-one...?
wolast
My changes solved the installation problem for the Krypton version.
Regarding you IPTV question:
Installing the client isn't enough. You have to configure it with your own (legal!) IPTV sources. Kodi does not provide any streaming content.
(2017-02-24, 10:15)sualfred Wrote: [ -> ] (2017-02-24, 01:18)Edworld Wrote: [ -> ]http://pastebin.com/ggNB1F28
I hope this helps
Your log looks clean. Hmm..
Please test it with this change: https://github.com/sualfred/skin.fTVfred...a88251c86d
Otherwise you have to provide the issue to Marcel in his skin helper service thread.
I have tested your fix with different tvshows and it works! I get the role they played if the actor is in my local database which matches the number of actors I downloaded from thetvdb.
Thanks for looking into this
sualfred:
I have locals NFO's, local fanarts, and extrafanarts. For some reason, when in movies, sometimes the fanart displayed is not in my database.
I am assuming it is related to skinhelper, but I am not sure why it would be doing this
Nope, this has nothing to do with Skin Helper. The skin prefers the local stored list item information.
sualfred:
I noticed that when extended info is used, if you select to watch a trailer, it gives you the option to play the trailer that are available. If you decide to cancel by pressing "x" after the trailer started, it goes into a loop, exits the trailer but starts playing it again.
Thanks, it's fixed. Update is available in the next few minutes.
suafred:
Not sure if it has an impact in other views of the screen, but would you consider changing the width of the title so it doesn't scroll?
watch gallery
edit:
I guess the only way to fix this is changing the font from 48 to 40
If I type something into the search window,
there are automatically generated word suggestions below...
I can scroll down, but can not select anything by pressing the OK button on the amazon-fire remote control.
The words are not taken into the search field and an empty search is executed.
Where is my mistake...?
(2017-03-02, 13:43)wolast Wrote: [ -> ]If I type something into the search window,
Same for me ever since switching to Krypton on my FireTV.
Have not found a solution as yet.
Sometimes if I press select 2 or 3 times it actually works.
I have even tried fresh installs to solve this one - plagues me.
The addon is already installed, otherwise you won't see the suggestions.
What I mean is that the addon or your Android Kodi version is causing the issue.
I do not have any Android/fTV device here, so I'm not able to test it by myself.
