(2015-11-07, 20:49)onizuka Wrote: [ -> ]Thanks for all your hard work Garbear!
If it's not too much to ask, could you please base your next OpenElec build off of Fritsch's EGL? It would really provide the best of Retroplayer and OpenElec. Thanks for the consideration!
http://fritsch.fruehberger.net/openelec/...ritsch.tar
What's so special about this particular build? No to sound like a snob, I just can't find any information or reference to it anywhere, hoping you could clarify what it does differently.
garbear thanks for your job
I've got your OE RPi2 image and i want to try it
I've a XBOX 360 Wired controller, and i want to configure it, but it seems that it's not recognized on Openelec RPi version
how i could get it work?
there's something to install?
I'd like to try to get this running on my ASUS Chromebox i.e. the M004U with a Celeron 2955U. I'm a Linux n00b & don't really know what to do with the SYSTEM or KERNAL files letalone the MD5 files. Here’s what I’m working with:
OpenELEC 6.0.0 (Generic.x86_64)
Kernel: Linux 4.1.12
Kodi 15.2 Git:02e7013 (Nov 1st 2015)
Has anyone ever got a retro emulator to run under Kodi 15.2 on an ASUS Chromebox? I just can't seem to figure it out. I've tried RetroArch, RetroPlayer and Rom Collection Browser but nothing seems to actually launch an application I can use. Thanks!
Trying out the latest build on a Win 7 machine. Kodi hangs at the splash screen when I launch it and I have to force close it. Log is
here. I've installed it alongside a standard build on the same machine and I'm launching this Retroplayer version in portable mode.
Hm, I'm not seeing an error in the log. Did the hang happen on previous builds? can you try with a fresh userdata folder? A while ago Montellese was seeing some deadlocks in the peripherals code, not sure if this is related.
I uninstalled, then re-installed. Same thing happened.
I uninstalled, then installed the previous version (KodiSetup-20151001-5d4efc1-retroplayer-15.1.exe). This version actually didn't even get to the splash screen. Here's the
log it produced, but again doesn't look very interesting.
The peripherals I have on this computer are:
- An xbox 360 controller (actually a PS3 controller, but it's using the windows workaround SCPServer to make it look like an xbox 360 controller, since there isn't a driver that works with it otherwise)
- A nyxboard remote
Are there any installation notes for a non-Raspberry Pi build? I thought i'd need an img file for a clean install.
Any help is appreciated, great work!
Hi, I apologize if this has already been addressed but can I just install the latest version over the one I already have or is it best to do a fresh install?
Ya, all of the download links seem to be down
Patience people.
Retroplayer is still in heavy development and builds wont always be regular (they disappear after a month on our mirrors).
I fixed the links for windows and osx
(2015-11-24, 12:19)garbear Wrote: [ -> ]I fixed the links for windows and osx
Thanks garbear, keep up the fantastic work!
Hi, Its been a few years since I tried retroplayer. I'm running into some issues straight away. Apologies if these are already know. I am running the latest OpenElec build from the first post OpenELEC-RetroPlayer-20151027-e83fc3b-Generic.x86_64-5.95.5.zip with a wireless 360 control.
Full debug log here >
http://xbmclogs.com/pt3yba4bk#line-899
Stumbling point is when setting up the controller in Settings > Games > Input > Default device. it runs through the first buttons fine until we get to "Up" I press the up button and it skips the down button and goes to "right" same happens on right ie left is skipped. Think this can be seen via the snippet below which shows button 13 pressed for up, and its not released until after down is configured.
11:10:52 T:140448934647680 DEBUG: Joystick Xbox 360 Wireless Receiver: Button 13 pressed
11:10:52 T:140448934647680 DEBUG: AddOnLog: Joystick Support: Button map: relationship for "up" already exists
11:10:52 T:140448934647680 DEBUG: Loaded button map with 15 features for controller game.controller.default
11:10:52 T:140448934647680 DEBUG: Previous line repeats 1 times.
11:10:52 T:140448934647680 DEBUG: Event handled
11:10:52 T:140448934647680 DEBUG: AddOnLog: Joystick Support: Button map: relationship for "down" already exists
11:10:53 T:140448934647680 DEBUG: Previous line repeats 1 times.
11:10:53 T:140448934647680 DEBUG: Joystick Xbox 360 Wireless Receiver: Button 13 released
11:10:53 T:140448815372032 INFO: AddOnLog: Joystick Support: CJoystickInterfaceLinux::Initialize: opening joystick /dev/input/js0
11:10:54 T:140448934647680 DEBUG: Joystick Xbox 360 Wireless Receiver: Button 12 pressed
11:10:54 T:140448934647680 DEBUG: AddOnLog: Joystick Support: Button map: relationship for "right" already exists
11:10:54 T:140448934647680 DEBUG: Loaded button map with 15 features for controller game.controller.default
11:10:54 T:140448934647680 DEBUG: Previous line repeats 1 times.
11:10:54 T:140448934647680 DEBUG: Event handled
11:10:54 T:140448934647680 DEBUG: AddOnLog: Joystick Support: Button map: relationship for "left" already exists
11:10:54 T:140448934647680 DEBUG: Joystick Xbox 360 Wireless Receiver: Button 12 released
I had to manually edit the buttonmap.xml to correct my controller.
