2015-02-13, 17:01
(2015-02-13, 16:52)Alexsource Wrote: [ -> ]Hey guys, I'm having issues trying to play stuff from Viewster ( https://www.youtube.com/user/ViewsterTV )
If i record correctly the old addon also had issues.
This is what the log says when trying to play Blind fist of Bruce ( video_id=ZCBlKMZLxZA ) and Bruce Lee in New Guinea ( video_id=xq2aaB_Awno ) ( found in the kung fu playlist -> https://www.youtube.com/playlist?list=PL...s2aBEYoIZk ) :
Code:11:40:54 T:6132 NOTICE: -->Python Interpreter Initialized<--
11:40:54 T:6132 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
11:40:54 T:6132 NOTICE: [plugin.video.youtube] Python : 2.7.8
11:40:54 T:6132 NOTICE: [plugin.video.youtube] System : Helix (2.19)
11:40:54 T:6132 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.6~beta4)
11:40:56 T:6132 NOTICE: [plugin.video.youtube] Shutdown of Kodion
11:40:56 T:5708 NOTICE: Thread BackgroundLoader start, auto delete: false
11:41:08 T:5696 NOTICE: Thread LanguageInvoker start, auto delete: false
11:41:09 T:5696 NOTICE: -->Python Interpreter Initialized<--
11:41:09 T:5696 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
11:41:09 T:5696 NOTICE: [plugin.video.youtube] Python : 2.7.8
11:41:09 T:5696 NOTICE: [plugin.video.youtube] System : Helix (2.19)
11:41:09 T:5696 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.6~beta4)
11:41:11 T:5696 NOTICE: [plugin.video.youtube] Shutdown of Kodion
11:41:11 T:5380 NOTICE: Thread BackgroundLoader start, auto delete: false
11:41:14 T:5928 NOTICE: Thread LanguageInvoker start, auto delete: false
11:41:14 T:5928 NOTICE: -->Python Interpreter Initialized<--
11:41:14 T:5928 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
11:41:14 T:5928 NOTICE: [plugin.video.youtube] Python : 2.7.8
11:41:14 T:5928 NOTICE: [plugin.video.youtube] System : Helix (2.19)
11:41:14 T:5928 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.6~beta4)
11:41:15 T:5928 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: 'url'
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py", line 7, in <module>
runner.run(__provider__)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\runner.py", line 28, in run
__RUNNER__.run(provider, context)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\impl\xbmc\xbmc_runner.py", line 23, in run
results = provider.navigate(context)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\abstract_provider.py", line 123, in navigate
result = method(context, re_match)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\register_provider_path.py", line 12, in wrapper
return func(*args, **kwargs)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\provider.py", line 269, in on_play
return yt_play.play_video(self, context, re_match)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\helper\yt_play.py", line 21, in play_video
video_streams = client.get_video_streams(context, video_id)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\client\youtube.py", line 63, in get_video_streams
video_streams = video_info.load_stream_infos(video_id)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\helper\video_info.py", line 270, in load_stream_infos
return self._method_get_video_info(video_id)
File "C:\Users\Alexis\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\helper\video_info.py", line 495, in _method_get_video_info
url = stream_map['url']
KeyError: 'url'
11:41:15 T:5728 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=ZCBlKMZLxZA]
11:41:15 T:3188 NOTICE: Thread BackgroundLoader start, auto delete: false
11:41:18 T:5200 NOTICE: Thread LanguageInvoker start, auto delete: false
11:41:18 T:5200 NOTICE: -->Python Interpreter Initialized<--
11:41:18 T:5200 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
11:41:18 T:5200 NOTICE: [plugin.video.youtube] Python : 2.7.8
11:41:18 T:5200 NOTICE: [plugin.video.youtube] System : Helix (2.19)
11:41:18 T:5200 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.6~beta4)
11:41:19 T:5200 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
KeyError: 'url'
11:41:19 T:5728 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=xq2aaB_Awno]
11:41:19 T:5852 NOTICE: Thread BackgroundLoader start, auto delete: false
11:41:25 T:1012 NOTICE: Thread LanguageInvoker start, auto delete: false
11:41:26 T:1012 NOTICE: -->Python Interpreter Initialized<--
11:41:26 T:1012 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
11:41:26 T:1012 NOTICE: [plugin.video.youtube] Python : 2.7.8
11:41:26 T:1012 NOTICE: [plugin.video.youtube] System : Helix (2.19)
11:41:26 T:1012 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.6~beta4)
11:41:27 T:1012 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
KeyError: 'url'
11:41:27 T:5728 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=xq2aaB_Awno]
11:41:27 T:3440 NOTICE: Thread BackgroundLoader start, auto delete: false
11:41:29 T:4160 NOTICE: Thread LanguageInvoker start, auto delete: false
11:41:29 T:4160 NOTICE: -->Python Interpreter Initialized<--
11:41:29 T:4160 WARNING: CPythonInvoker(20): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
11:41:29 T:4160 ERROR: EXCEPTION: XBMC is not playing any file
11:41:31 T:3864 NOTICE: Thread AlarmClock start, auto delete: false
11:41:31 T:5972 NOTICE: Thread LanguageInvoker start, auto delete: false
11:41:31 T:5972 NOTICE: -->Python Interpreter Initialized<--
11:41:31 T:5972 WARNING: CPythonInvoker(21): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
11:41:40 T:4856 NOTICE: Thread BackgroundLoader start, auto delete: false
11:41:56 T:4156 NOTICE: Previous line repeats 4 times.
11:41:56 T:4156 NOTICE: Thread LanguageInvoker start, auto delete: false
Some other movies, like The Superheroe ( https://www.youtube.com/watch?v=8KscJuyG...94&index=1 ) do seem to work.
https://github.com/bromix/plugin.video.y...issues/190
