(2014-12-09, 11:39)bromix Wrote: [ -> ]I'm planing to. Is this even working in the other addon? I',m asking because for me this never worked in my tests (compared to some videos on the web page).
Yes. Subtitle works in official plugin. Not many videos have them though. But sometime very useful.
I vote for it too. Option in menu enable subtitles after that all works. You can enable and disable as on DVD during viewing. But I would like to ask about Default View first. Is there any progress it that direction...Just asking.
Thank you!
(2014-12-09, 20:25)389abc Wrote: [ -> ] (2014-12-09, 11:39)bromix Wrote: [ -> ]I'm planing to. Is this even working in the other addon? I',m asking because for me this never worked in my tests (compared to some videos on the web page).
I vote for it too. But I would like to ask about Default View. Is there any progress it that direction... I am just asking. Thank you!
Okay...I put the default view on the list for the next update
Thank you Thank you Thank you
Not sure if you have already answered this question already but
Any chance for 1080p and maybe some 60 fps?
i like to watch gaming videos and some grand strat games with 720p kinda makes it blurry,
And is the cache limit 25mb for a reason or just a number?
also any possibility that you can add Play from here?
What is "play from here" anyways? I've never used it in all these years. lol
(2014-12-10, 00:38)razord93 Wrote: [ -> ]Not sure if you have already answered this question already but
Any chance for 1080p and maybe some 60 fps? ¨
Yes already answered
1080p and 60fps no. Not because I won't but because of technical limitations (Kodi+ffmpeg and also YouTube).
If you mean the cache of the addon. That has nothing to do with caching video data but more with caching of meta data
so navigation will be fast and meta data for videos and channels are available fast.
(2014-12-10, 01:46)dkplayaclub Wrote: [ -> ]What is "play from here" anyways? I've never used it in all these years. lol
It plays rest of the videos from playlist from the point you choose, without play from here i have to play videos manually
Noticed another thing tonight that might need some looking into. There needs to be a way to hide or filter paid content, or at least mark paid videos somehow (maybe a different color). As it is now, these videos just throw an error, but with no explanation as to why, I would have figured they would only show up in the "paid channels" section, but paid content will show up in searches and there isn't any way to tell if some videos on a playlist are paid or not.
For me subtitles always worked in the other addon. I watched a lot of movies on youtube and never a problem.
I have installed your add-on and I'm impressed by the speed on my Raspberry Pi/OpenELEC. I saw that get it to remember (or default to) thumbnail view was on your todo list and I'm looking forward to that. One thing that I find confusing is "My Subscriptions" vs. "Subscriptions". I've got it now but wouldn't it be clearer if it was called "Subscription Updates" or something instead of "My Subscriptions" or does the captions come from YouTube?
Keep up the good work!
Hassuni, I am assuming that the regions will be selectable in upcoming versions. I have noticed that I get a good amount of German videos in searches which leads me to believe that the code is based on getting results from that region. I am almost positive I remember Bromix saying something about region settings being on his to-do list.
Wasn't expecting it to work since it hasn't for me to date, but I tried liking some videos on the newest version and I actually get a "forbidden" error when trying to like a video. Don't know if it helps or not, but here is a log of it happening to me.
http://xbmclogs.com/show.php?id=371298
Also, been having intermittent issues with thumbnails loading very slowly or not at all. It may not be an issue with the addon.
(2014-12-08, 20:44)bromix Wrote: [ -> ] (2014-12-08, 11:36)hacky4real Wrote: [ -> ]Sweet addon! Great work.
Two things: 1) I have problem logging in
2) will there be an option for live streaming
Many thanks
If you have very special characters in you PW, can you tests with something simpler? I don't know why, but the ClientLogin API of Google has some problems with correct url-form-encoding.
I've tested live streams, but I can't get them to work (the same with the other addon).
I changed my password to remove only a ! and not to use special characters and now login seems to work.
Strange though that it wasn't an issue with normal YT addon.
(2014-12-07, 20:34)mo123 Wrote: [ -> ] (2014-11-26, 13:38)torenvalk Wrote: [ -> ]I made a simple plugin called Youtube Forwarder that substitutes the standard Youtube one and forwards playback requests to Bromix's plugin (or another plugin if you know the path).
Download here
The plugin says script error, can it be fixed?
Getting this error:
10:42:33 T:140616168281856 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named CommonFunctions
File "/storage/.kodi/addons/plugin.video.youtube.forwarder/default.py", line 22, in <module>
import CommonFunctions as common
ImportError: No module named CommonFunctions
https://github.com/nkestrel/kodi.plugin....r/issues/1
Same error here for the youtube forwarder
