Looks like issue is only on Android / MAC Os, windows desktop kodi with youtube video add on working perfectly with the live streaming as well.
I will raise the ticket with kodi group. Thanks for the help bromix.
Your addon is awesome. Keep rocking.
(2015-02-26, 18:52)firetvdude Wrote: [ -> ]Looks like issue is only on Android / MAC Os, windows desktop kodi with youtube video add on working perfectly with the live streaming as well.
Trouble with
https on Android and MAC? And thanks for the information.
(2015-02-25, 21:13)bromix Wrote: [ -> ] (2015-02-25, 19:41)dspdsp Wrote: [ -> ]I am not using proxy.
This video plays on my laptop without any issues in the same network.
I am using Kodi on Raspberry pi b+ and with basic confluence skin.
Please refer error log
http://pastebin.com/Skgz1LEK
Debug log says
it failed to read header
3:00:10 T:2812802080 DEBUG: Thread JobWorker 2812802080 terminating (autodelete)
23:00:20 T:2751198240 ERROR: ffmpeg[A3FBF420]: [mov,mp4,m4a,3gp,3g2,mj2] error reading header
23:00:20 T:2751198240 ERROR: Open - Error, could not open file https://r3---sn-i5uif5t-2o9e.googlevideo....75.185.58
23:00:20 T:2751198240 ERROR: OpenDemuxStream - Error creating demuxer
23:00:20 T:2751198240 NOTICE: CDVDPlayer::OnExit()
But earlier in the log it says video/mp4
22:59:48 T:3024781312 DEBUG: CCurlFile::GetMimeType - https://r3---sn-i5uif5t-2o9e.googlevideo....75.185.58 -> video/mp4
This is happening for large videos may be having playback more than 1 Hr
Thank you
Can you try a higher resolution (addon-settings->video quality). You're trying to open the video in 360p (ITAG 18) and ffmpeg somehow doesn't like the format (?). Just wan't to know if another format works for you.
Hello Bromix,
I tried with different resolutions today 360p, 480p, 720p, 1080p but faced same issue, none worked.
Could this ffmpeg issue be related to Raspbmc distro I am using?
Can you let me know on which distro you tried and it worked?
Thank you for quick response.
Regards
(2015-02-26, 20:56)dspdsp Wrote: [ -> ] (2015-02-25, 21:13)bromix Wrote: [ -> ] (2015-02-25, 19:41)dspdsp Wrote: [ -> ]I am not using proxy.
Debug log says
Thank you
Hello Bromix,
Regards
I test all my addons on Windows 7 (64 Bit), Ubuntu and Android 4.4.2.
This seems to be a problem of ffmpeg or curl. What I've found so far is, that in some versions the dev. missed to include the support for zlib in ffmpeg. Do you have the newest version of raspbmc? Can you try to contact someone of the devs. of the raspbmc?
@ Bromix
Using your add-ons to play a playlist option with default setting and the add-ons start with 2nd video clip instead of 1st clip. Running on XBMC Gotham. TIA
(2015-02-27, 21:44)tvlover2013 Wrote: [ -> ]@ Bromix
Can you send me please the complete URL you used for that.
Hi there!
I use the hell out of your add-on, thanks a bunch for it!!!!
Is there anyway you could add a "refresh" feature in your later updates? Or maybe even an "auto refresh" option?
I stay a lot in the "My Subscriptions" screen and I need to constantly exit and enter again to get the list refreshed.
I would really appreciate if this was possible!
With or without this feature, awesome add-on!
Very thankful =)
(2015-02-26, 14:42)dkplayaclub Wrote: [ -> ]On my way out the door to run some errands ATM, so I will try to get back to you with a debug log later today, but if you want to check it out this is the channel I was looking at when I noticed the "problem".
https://www.youtube.com/user/HGTVShows
Nothing I can do about at the moment. Google seems to have some trouble with it, because the VideoInfo API returns 'Backend Errors'. I think we have to wait
but I like your idea with the '
$-Sign'
(2015-02-27, 22:38)ateevee2 Wrote: [ -> ]Hi there!
Very thankful =)
Done Will be in the 5.0.7 (or you test the beta from my REPO)
Okay...I don't even start the player...I just add the videos to the current playlist...XBMC/KODI is running the show after that
is this a bug? Because the order is correct.
tested with:
plugin://plugin.video.youtube/play/?playlist_id=PL57hJfweW_2sv1WtKWyFiua5r0QivDTZl
(2015-02-27, 23:31)bromix Wrote: [ -> ] (2015-02-27, 22:38)ateevee2 Wrote: [ -> ]Hi there!
Very thankful =)
Wow, that was fast!!!!!!!!!!!!!
Tested here and works like a charm!
Thanks a lot! Really, really, really, really appreciate it.
Cheers!
Quote:Using your add-ons to play a playlist option with default setting and the add-ons start with 2nd video clip instead of 1st clip. Running on XBMC Gotham. TIA
Okay...I don't even start the player...I just add the videos to the current playlist...XBMC/KODI is running the show after that is this a bug? Because the order is correct.
This behaviour of not playing 1st video from the playlist was in Frodo too. I am not sure it is bug or not. if you call the xbmc player it always skip first video. It does not happen when the playlist is small like 4 or 5 items. I just accept it as is.
(2015-02-27, 13:23)bromix Wrote: [ -> ] (2015-02-26, 20:56)dspdsp Wrote: [ -> ] (2015-02-25, 21:13)bromix Wrote: [ -> ]Can you try a higher resolution (addon-settings->video quality). You're trying to open the video in 360p (ITAG 18) and ffmpeg somehow doesn't like the format (?). Just wan't to know if another format works for you.
Hello Bromix,
Regards
Thank you for information
I tried with different distros OpenELEC, XBian , OSMC but same problem ffmpeg failed to read header.
Also tried by directly installing KODI on my Mac OS X 10.9 even there same problem.
How can we make this work any ideas??
Update:
This issue seems to be related low internet speed.
I did some tweaking in "advancedsettings.xml" and it started working for vidoes having playback greater than 1hr but less than 2hrs.
Below settings helped me, though it did not completely solve the issue.
<advancedsettings>
<network>
<buffermode>0</buffermode>
<cachemembuffersize>0</cachemembuffersize>
<readbufferfactor>20</readbufferfactor
<curlclienttimeout>500</curlclienttimeout>
<curllowspeedtime>1</curllowspeedtime>
</network>
</advancedsettings>
One more observation is, with this settings if video quality is set to 240p then all videos play without any issues.
I still feel this should be fixed in kodi source code. First frame for long videos seems to be corrupted.
