If you're one of the beta-people - you will have to sign out and sign in again to get a correct token. This is a test to fix the 'quota exceeded' problem.
Version 5.1.0~beta10 (2015-04-13)
UPD: changed credentials
(2015-04-07, 21:12)bromix Wrote: [ -> ] (2015-04-07, 15:50)muhaha Wrote: [ -> ]Hello. Is it possible to add playlists, videos from my youtube account to local audio library, so that i can control it from yatse?
I want to play playlists from my account and control it with remote control. And it would be great if it shows title of every song in playlist, instead of playing whole playlist as a stream. and that i can skip some songs for example and control whole playlist. thanks
Not I know of...these are streams...so nothing locally to add to a database...maybe someone else has an idea.
Imagine the situation, i want to listen songs from my youtube account as jukebox. Mix songs from my favourites channels and all this stuff control from mobile.
Just like i can play, select, skip, queue music from my local library. Is it somehow possible to do? Thanks
(2015-04-13, 22:58)muhaha Wrote: [ -> ] (2015-04-07, 21:12)bromix Wrote: [ -> ] (2015-04-07, 15:50)muhaha Wrote: [ -> ]Hello. Is it possible to add playlists, videos from my youtube account to local audio library, so that i can control it from yatse?
Create a Playlist in YouTube with your account..add all the stuff you want to listen...select Play All and choose Random/Shuffle. Don't make things complicated.
(2015-04-13, 10:43)bromix Wrote: [ -> ]The plausible solution would be to provide a separate KEY (or KEYs) for all calls which are not connected to the account - for example all search relevant calls (basic search, live streams, popular right now and related to the video) will have a separate KEY. The search costs us the most of the quota and can even used by users who are not logged in.
Sure, you could even generate 100 keys and pick which one you use randomly. But I would expect google will probably consider that a violation of their terms of service and just invalidate all of them. And our justification, that their API is garbage, won't go very far in that scenario. My suggested alternative, allowing users to register for their own key, is obviously a terrible kludge but google is unlikely to do anything about it.
That said, I imagine
one extra key, used for non-searches only, hopefully shouldn't tick them off too badly.
Edit: 5.1b10 seems to work fine, so far.
:You Tube Addon seems to be going ok now...haven't experienced any daily limits in the last 24hrs
(2015-04-13, 23:04)bromix Wrote: [ -> ] (2015-04-13, 22:58)muhaha Wrote: [ -> ] (2015-04-07, 21:12)bromix Wrote: [ -> ]Not I know of...these are streams...so nothing locally to add to a database...maybe someone else has an idea.
It isnt complicated. As in soundcloud i have in youtube account almost 50 music channels, so if i want to play all this music as jukebox, i need to add every song separately to my playlist. But there are so many new songs everyday, i cant add every song to playlist.
(2015-04-14, 13:06)muhaha Wrote: [ -> ]...
You can use the 'Play from here' from the context menu (even in the 'My subscriptions') and navigate to the 'current playlist' select shuffle. This is possible in SoundCloud and YouTube. You have all the tools to accomplish your goal (Most of it is already possible from KODI)
It's looking good so far with one key. At least I see what can be optimized to shape the unit depletion a little bit.
New Key is running for at least 12h...
Nothing I can so, but in the future post your logs only via pastebin.com or similar...and complete...not only a part of it. I don't know your system and which addons are also running.
On the Youtube website, I can "save" other people's playlists.
It will show up in my sidebar (together with the playlists that I created myself) and it will be updated when the owner updates it.
I can't figure out how to get these saved playlists to show in Kodi. My own playlists show up, but not the ones that I have saved.
Is there anyway to get my saved/subscribed playlists to show in the youtube addon?
Thanks in advance!
(2015-04-14, 16:41)jcjdammers Wrote: [ -> ]Hi,
Thanks in advance!
First page of this thread you will find the following link
Missing or not supported
and from there you will find the answer to your question
Liked/Saved Playlists
(2015-04-14, 14:00)bromix Wrote: [ -> ]Nothing I can so, but in the future post your logs only via pastebin.com or similar...and complete...not only a part of it. I don't know your system and which addons are also running.
will do immediately, sorry i thought this was enough
http://pastebin.com/q65KtsjC
also tell me if there is another specific component you maybe would like to debug..
