Hey Bromix,
Will the plugin be able to show the subtitles from Youtube in the future updates? Old versions used to do this but subs sort of overlapped. Old lines did not disappear, new ones just kept being written on top.
And I also got the plugin installation error and it did not update to 5.0.1 but I will try the solution you suggested in the above posts. Thanks!
Hello, Bromix.
Thanks for the plugin. I wanna ask for subtitles support too.
(2015-01-02, 11:42)leckylao Wrote: [ -> ] (2015-01-01, 18:45)bromix Wrote: [ -> ] (2015-01-01, 18:19)kromos Wrote: [ -> ]I've gote some error in playlist longer then 50 and search
17:06:45 T:2748812096 ERROR: EXCEPTION: argument "thumbnailImage" for method "XBMCAddon::xbmcgui::ListItem" must be unicode or str
17:06:45 T:2748812096 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: argument "thumbnailImage" for method "XBMCAddon::xbmcgui::ListItem" must be unicode or str
File "/home/xbmc/.xbmc/addons/plugin.video.youtube/default.py", line 7, in <module>
runner.run(__provider__)
File "/home/xbmc/.xbmc/addons/plugin.video.youtube/resources/lib/kodion/runner.py", line 16, in run
__RUNNER__.run(provider, context)
File "/home/xbmc/.xbmc/addons/plugin.video.youtube/resources/lib/kodion/impl/xbmc/xbmc_runner.py", line 44, in run
self._add_directory(context, item, item_count)
File "/home/xbmc/.xbmc/addons/plugin.video.youtube/resources/lib/kodion/impl/xbmc/xbmc_runner.py", line 89, in _add_directory
thumbnailImage=directory_item.get_image())
TypeError: argument "thumbnailImage" for method "XBMCAddon::xbmcgui::ListItem" must be unicode or str
17:06:46 T:3037375168 ERROR: GetDirectory - Error getting plugin://plugin.video.bromix.youtube/kodion/search/query/?q=moherowy%20ninja
17:06:46 T:3037375168 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.bromix.youtube/kodion/search/query/?q=moherowy%20ninja) failed
17:06:46 T:2748812096 NOTICE: Thread XBPyThread start, auto delete: false
17:06:46 T:2748812096 NOTICE: -->Python Interpreter Initialized<--
17:06:46 T:2748812096 NOTICE: Thread Background Loader start, auto delete: false
You're not using KODI or Gotham right? This seems to me a bug in Frodo. Please consider updating at least to Gotham and provide always complete logs.
Hi, I have the same issue and I am using Frodo. The problem is the directory_item image is None. So here's my quick ifx:
if directory_item.get_image() is not None:
item = xbmcgui.ListItem(label=directory_item.get_name(),
iconImage=u'DefaultFolder.png',
else:
thumbnailImage="")
I think the new API might handle the None image but for old API still need to check if it's None image
Hi i am a newbie and am on Frodo having the same issue
May i know how to apply the above fix as in which folder/file to edit?
else:
thumbnailImage="")
Yes, this code fix the problem. Thanks a lot.
In nearest weeks I have no time to upgrade xbmc (I plan to upgrade the whole system) and this quick fix works well.
To
pinelights: you must edit :/home/xbmc/.xbmc/addons/plugin.video.youtube/resources/lib/kodion/impl/xbmc/xbmc_runner.py above line 44. (begining of path may be diferent)
At the start of def _add_directory you must replace
withe the code posted by leckylao.
Or perheps in newest version it's done.
Hey there, i am using my PC to send multiple Youtubelinks to Kodis Youtube-Addon, so that i can whatch them one after another without user interaction. I am logged in on my PC and i am logged in the Youtube Addon on Kodi. Is there a way that the watched videos are added to the "Recently watched" list? Sometimes there is a video that i really like and want to send it to others, but i am not sure which one it was because i can't search for it in my watched list.
Thank you
(2015-01-03, 02:51)kromos Wrote: [ -> ]To pinelights: you must edit :/home/xbmc/.xbmc/addons/plugin.video.youtube/resources/lib/kodion/impl/xbmc/xbmc_runner.py above line 44. (begining of path may be diferent)
Thks for the help but i decided to just upgrade Frodo to Kodi before you posted and all is fine
(2015-01-01, 20:29)bromix Wrote: [ -> ] (2015-01-01, 20:19)laptopu Wrote: [ -> ] (2015-01-01, 19:07)bromix Wrote: [ -> ]This I'm already using...and that's the problem This works on all playlists (even Watch Later)...but not for the History. Thanks for your feedback
Thanks for the info. I have reported it as a problem to Google, hopefully that will help us get a fix
Where and how did you report this?
On the API resource page under the 'connect' heading at the bottom of the page I pressed 'report an issue' and did it that way.
I'm stuck on the 5.0.1 problem package too, using Openelec with Raspberry Pi I have cleared out the cached file but it keeps downloading the broken package.
Hi ! I have an Apple tv2 with xbmc koi gotham and i have a update for pluggin vidéo youtube 5.0.1 but i can't upgrade
If i click to upgrade this plug can't upgrade ? It's normal ? Thank's and happy new year ;-)
(2015-01-03, 14:01)ggkameleon Wrote: [ -> ]Hi ! I have an Apple tv2 with xbmc koi gotham and i have a update for pluggin vidéo youtube 5.0.1 but i can't upgrade
Please see
post
(2015-01-03, 13:46)laptopu Wrote: [ -> ] (2015-01-01, 20:29)bromix Wrote: [ -> ] (2015-01-01, 20:19)laptopu Wrote: [ -> ]Thanks for the info. I have reported it as a problem to Google, hopefully that will help us get a fix
Please see
post
First of, thanks a lot for a great add-on!
I have a small, perhaps already answered question, is there any way to map next & previous chapter buttons to skip videos back and forth in their entirety? Right now, it just skips short periods, at a time.
the "old" plugin had some nifty features like editable search and a download option. Any plans to add ?
Greetz
LCS
(2015-01-03, 15:23)bromix Wrote: [ -> ] (2015-01-03, 14:01)ggkameleon Wrote: [ -> ]Hi ! I have an Apple tv2 with xbmc koi gotham and i have a update for pluggin vidéo youtube 5.0.1 but i can't upgrade
Please see post
(2015-01-03, 13:46)laptopu Wrote: [ -> ] (2015-01-01, 20:29)bromix Wrote: [ -> ]Where and how did you report this?
Please see post
Thanks, still a no go for me afraid. Followed info in that post and there was no version number, folder is already named plugin.video.youtube. Tried pulling zip file from
https://github.com/bromix/plugin.video.youtube and placing this directly in /addons/packages folder and still came up installation failed, it's like the old file is still on the repo.
(2015-01-03, 19:42)LastCoder Wrote: [ -> ]Hi,
Greetz
LCS
+1
(2015-01-03, 21:17)laptopu Wrote: [ -> ] (2015-01-03, 15:23)bromix Wrote: [ -> ] (2015-01-03, 14:01)ggkameleon Wrote: [ -> ]Hi ! I have an Apple tv2 with xbmc koi gotham and i have a update for pluggin vidéo youtube 5.0.1 but i can't upgrade
Please see post
(2015-01-03, 13:46)laptopu Wrote: [ -> ]On the API resource page under the 'connect' heading at the bottom of the page I pressed 'report an issue' and did it that way.
Please see post
Thanks, still a no go for me afraid. Followed info in that post and there was no version number, folder is already named plugin.video.youtube. Tried pulling zip file from https://github.com/bromix/plugin.video.youtube and placing this directly in /addons/packages folder and still came up installation failed, it's like the old file is still on the repo.
Please try this one:
https://github.com/bromix/plugin.video.y...0.3-b1.zip
(2015-01-03, 19:25)igjunk Wrote: [ -> ]First of, thanks a lot for a great add-on!
If you play videos with 'Play from here' or 'Play all' this will work. But it has nothing to do with the addon itself if next or prev. is working.
Greetz
LCS
Download not for now. But what editable search settings?
