2016-01-01, 04:31
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
2016-01-02, 05:41
OK. I've gotten everything working except for the sound. I am having issues with it. Searching through this thread, there has been various different suggestions. Using the latest repo, what is the best way to fix it? I am using the latest development build of kodi on Ubuntu 15.04.
2016-01-03, 23:03
Try if your browser can play any sound ( with YouTube ) I had the same problem and I had to write a .asoundrc file in home directory. Google for that it is alsa related
2016-01-07, 11:16
(2015-12-30, 20:55)newsilentsilver Wrote: [ -> ](2015-12-30, 18:27)sagrath Wrote: [ -> ]Tested with the Newest Version... Working Ok, Now list appear. Everything is Ok, Will tested controls after came back from work.
All is working fine on OpenElec now, too.
I have been keeping an eye on the Netflix plugins and their issues. And surprised to note, that someone has Netflix working on Kodi.
I run OpenElec 6 on ASUS Chromebox and was wondering, if you could share the setup or even better perhaps point me to the directions for the installation.
2016-01-11, 12:50
Hello,
I hope you guys are able to help me. I'm using Kodi Isengard on an Odroid U3 (ARM). Chrome is not available for ARM platforms, therefore I have chromium installed. Is it possible to get Netflixbmc to run with chromium? If so.. could someone explain to me what to do in order to get it to work? Sorry, I'm kinda newbie here.
2016-01-11, 13:14
Not sure this version is still being worked on. You should probably go here http://forum.kodi.tv/showthread.php?tid=254263
2016-01-11, 20:31
Chromium is pretty much drop in replacement for chrome. You just need to change the path to chromium instead of chrome.
2016-01-29, 19:40
kodi 15.2-3, running on Archlinux on Intel® Core i5-2540M CPU @ 2.60GHz
netflixbmc 1.3.23
Appears to be failing to parse out the title from netflix on line 375 of default.py
Unfortunately I dont know python enough to fix it.
netflixbmc 1.3.23
12:36:59 T:140437956286208 NOTICE: URL: https://www.netflix.com/WiHome
12:37:01 T:140437964678912 NOTICE: Thread BackgroundLoader start, auto delete: false
12:37:03 T:140437973071616 NOTICE: Previous line repeats 1 times.
12:37:03 T:140437973071616 NOTICE: Thread LanguageInvoker start, auto delete: false
12:37:03 T:140437973071616 NOTICE: -->Python Interpreter Initialized<--
12:37:03 T:140437973071616 NOTICE: OpenSSL distribution not available for your platform.
Please add one if possible by following instructions in top of file: /home/gregbert/.kodi/addons/plugin.video.netflixbmc-master/resources/lib/pyOpenSSL/__init__.pyo
12:37:04 T:140437989857024 NOTICE: Thread BackgroundLoader start, auto delete: false
12:37:05 T:140437973071616 NOTICE: Thread LanguageInvoker start, auto delete: false
12:37:05 T:140437973071616 NOTICE: -->Python Interpreter Initialized<--
12:37:05 T:140437973071616 NOTICE: OpenSSL distribution not available for your platform.
12:37:05 T:140437973071616 NOTICE: URL: https://www.netflix.com/WiGenre?agid=83
12:37:07 T:140437973071616 NOTICE: Previous line repeats 1 times.
12:37:07 T:140437973071616 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "/home/gregbert/.kodi/addons/plugin.video.netflixbmc-master/default.py", line 1313, in <module>
listVideos(url, type, runAsWidget)
File "/home/gregbert/.kodi/addons/plugin.video.netflixbmc-master/default.py", line 277, in listVideos
listVideo(videoID, "", "", False, False, type)
File "/home/gregbert/.kodi/addons/plugin.video.netflixbmc-master/default.py", line 376, in listVideo
title = match[0].strip()
IndexError: list index out of range
12:37:07 T:140438742407296 ERROR: GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=tv&url=https%3a%2f%2fwww.netflix.com%2fWiGenre%3fagid%3d83
12:37:07 T:140438742407296 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=tv&url=https%3a%2f%2fwww.netflix.com%2fWiGenre%3fagid%3d83) failed
12:37:07 T:140437973071616 NOTICE: Thread LanguageInvoker start, auto delete: false
12:37:07 T:140437973071616 NOTICE: -->Python Interpreter Initialized<--
12:37:08 T:140437973071616 NOTICE: OpenSSL distribution not available for your platform.
12:37:08 T:140437964678912 NOTICE: Thread BackgroundLoader start, auto delete: false
2016-02-01, 16:27
(2016-01-29, 19:40)gregbert Wrote: [ -> ]kodi 15.2-3, running on Archlinux on Intel® Core i5-2540M CPU @ 2.60GHzI will suggest deleting the master in plugin.video.netflixbmc. Because kodi is trying to access plugin://plugin.video.netflixbmc/..... not plugin.video.netflixbmc-master
netflixbmc 1.3.23
Code:12:36:59 T:140437956286208 NOTICE: URL: https://www.netflix.com/WiHome
I think that might be your problem. Please be gentle if I am wrong, still a newb to kodi just trying to help and learn where I can
2016-02-01, 20:11
This addon don´t work anymore!
2016-02-11, 15:22
(2015-12-30, 23:08)sirhcjw Wrote: [ -> ]All working like a charm for me now thanks for all the hard work.
Anyone on kodibuntu to get this working in full screen just install blackbox window manager and official chrome browser
Then make these changes to the launchBrowser.sh script on my instalation the path is
.kodi/addons/plugin.video.netflix/resources/launchBrowser.sh
Code:#!/bin/bash
# copy from https://github.com/andrewleech/plugin.video.netflixbmc/blob/master/browser.sh
# Managed to resolve the issues with, but will leave this here anyway, as its a good fallback
CHROME_STARTED=`ps -ef | grep google-chrome | grep -v "grep" | wc -l`
if [ $CHROME_STARTED -gt 0 ]; then
exit 1;
fi
# lets find out if xdotool actually exist before we try to call it
command -v xdotool >/dev/null 2>&1
XDOTOOL=$?
url=$1
# start window manager to make fullscreen work
/usr/bin/blackbox &
# move mouse pointer to bottom right of screen
if [ $XDOTOOL -eq 0 ]; then
# no point sleeping if xdotool is not installed.
#sleep 5
xdotool mousemove 9999 9999 click 1
else
echo "xdotool is not installed, can't remove cursor"
fi
# notice no ampersand to keep google chrome in front so remote works
/usr/bin/google-chrome --start-maximized --disable-translate --disable-new-tab-first-run --no-default-browser-check --no-first-run --kiosk "$url"
# kill window manager so we exit back to kodi
killall blackbox >/dev/null 2>&1
installed the addon from page 1 but i dont have a launchBrowser.sh not even the folder
2016-02-13, 13:13
I have just installed netflixbmc on the latest Kodi release on ubuntu, installed chome and chrome launcher.
I launch the add-on and go to movies>latest.
It thinks for a while and then comes up with "Netflixbmc error: check log for details"
That happens with any option.
What could be the issue? Where do I find the log?
2016-02-13, 17:01
(2016-02-13, 13:13)Spacedementia87 Wrote: [ -> ]I have just installed netflixbmc on the latest Kodi release on ubuntu, installed chome and chrome launcher.
I am not sure if this addon is even working or being updated any more. If I am right than you have other choices for netflix on kodi that you can use instead. At least until this one is fixed. Hope this helps.
2016-02-13, 18:16
This one don´t work anymore!!
Use Flix2Kodi...
Let this thread dead!
Use Flix2Kodi...
2016-02-14, 01:49
That was what I was saying except was trying to break it to him a little more gently. lol. anyway had to post one more time so I could get #1500. Moving on.
