2015-06-21, 20:59
After the last NetfliXBMC Update the Addon disappeared out of my List and is not marked as installed. I tried to reinstall it but this doesn't work either.
What's wrong there?
What's wrong there?
22:57:48 T:140398749599488 DEBUG: FileManager: copy http://www.alelec.net/kodi/repo/plugin.video.netflixbmc/plugin.video.netflixbmc-1.3.22.zip -> special://home/addons/packages/plugin.video.netflixbmc-1.3.22.zip
22:57:48 T:140398749599488 DEBUG: CurlFile::Open(0x7fb13c0201c0) http://www.alelec.net/kodi/repo/plugin.video.netflixbmc/plugin.video.netflixbmc-1.3.22.zip
22:57:49 T:140398749599488 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
22:57:49 T:140398749599488 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
22:57:50 T:140398749599488 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
22:57:50 T:140398749599488 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:18:35 T:1680 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
07:18:35 T:1680 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
07:18:35 T:1680 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','1','')
07:18:35 T:1680 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=14) plugin...
07:18:35 T:8312 NOTICE: Thread LanguageInvoker start, auto delete: false
07:18:35 T:8312 INFO: initializing python engine.
07:18:35 T:8312 DEBUG: CPythonInvoker(14, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): start processing
07:18:35 T:8120 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url
07:18:35 T:8312 NOTICE: -->Python Interpreter Initialized<--
07:18:35 T:8312 DEBUG: CPythonInvoker(14, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py"
07:18:35 T:8312 DEBUG: CPythonInvoker(14, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc;C:\Users\test\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
07:18:35 T:8312 DEBUG: CPythonInvoker(14, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc
07:18:35 T:8312 DEBUG: CPythonInvoker(14, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
07:18:36 T:8312 NOTICE: SSL is Disabled
07:18:36 T:8312 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\resources\language\English, fallback to strings.xml
07:18:36 T:8312 DEBUG: DialogProgress::StartModal called
07:18:36 T:8312 DEBUG: ------ Window Init (DialogProgress.xml) ------
07:18:36 T:8312 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
07:18:36 T:8312 NOTICE: URL: https://www.netflix.com/Login
07:18:37 T:8312 NOTICE: URL: https://signup.netflix.com/Login
07:18:39 T:8312 NOTICE: Setting Country: AT
07:18:39 T:8312 NOTICE: URL: https://www.netflix.com/ProfilesGate?nextpage=http%3A%2F%2Fwww.netflix.com%2FDefault
07:18:43 T:1680 DEBUG: ------ Window Init (DialogSelect.xml) ------
07:18:43 T:1680 INFO: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
07:18:43 T:1680 WARNING: Trying to add unsupported control type 1
07:18:44 T:1680 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
07:18:44 T:1680 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
07:18:44 T:1680 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
07:18:44 T:1680 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
07:18:45 T:1680 DEBUG: ------ Window Deinit (DialogSelect.xml) ------
07:18:45 T:8312 NOTICE: URL: https://api-global.netflix.com/desktop/account/profiles/switch?switchProfileGuid=MO6RB4GNOFHLZGRQ36RLPCDM4Y
07:18:45 T:8312 NOTICE: URL: https://www.netflix.com/WiHome
07:18:47 T:1680 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
07:18:47 T:8312 INFO: CPythonInvoker(14, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): script successfully run
07:18:47 T:1680 DEBUG: Saving fileitems [plugin://plugin.video.netflixbmc/]
07:18:47 T:1680 DEBUG: -- items: 4, sort method: 0, ascending: false
07:18:47 T:7308 NOTICE: Thread BackgroundLoader start, auto delete: false
07:18:47 T:8312 INFO: Python script stopped
07:18:47 T:8312 DEBUG: Thread LanguageInvoker 8312 terminating
07:18:47 T:7308 DEBUG: Thread BackgroundLoader 7308 terminating
07:18:47 T:1680 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
07:18:48 T:1680 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
07:18:48 T:1680 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
07:18:49 T:1680 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
07:18:49 T:1680 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
07:18:50 T:1680 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/?mode=main&thumb&type=tv&url)
07:18:50 T:1680 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
07:18:50 T:7264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','2','?mode=main&thumb&type=tv&url')
07:18:50 T:4324 NOTICE: Thread LanguageInvoker start, auto delete: false
07:18:50 T:4324 INFO: initializing python engine.
07:18:50 T:4324 DEBUG: CPythonInvoker(15, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): start processing
07:18:50 T:7264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=15) plugin...
07:18:50 T:4324 NOTICE: -->Python Interpreter Initialized<--
07:18:50 T:4324 DEBUG: CPythonInvoker(15, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py"
07:18:50 T:4324 DEBUG: CPythonInvoker(15, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc;C:\Users\test\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
07:18:50 T:4324 DEBUG: CPythonInvoker(15, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc
07:18:50 T:4324 DEBUG: CPythonInvoker(15, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
07:18:50 T:1680 DEBUG: ------ Window Init (DialogBusy.xml) ------
07:18:50 T:4324 NOTICE: SSL is Disabled
07:18:50 T:4324 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\resources\language\English, fallback to strings.xml
07:18:50 T:7264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
07:18:50 T:4324 INFO: CPythonInvoker(15, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): script successfully run
07:18:50 T:8460 NOTICE: Thread BackgroundLoader start, auto delete: false
07:18:50 T:8460 DEBUG: Thread BackgroundLoader 8460 terminating
07:18:50 T:4324 INFO: Python script stopped
07:18:50 T:4324 DEBUG: Thread LanguageInvoker 4324 terminating
07:18:51 T:1680 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
07:18:51 T:1680 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
07:18:51 T:1680 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
07:18:54 T:1680 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
07:18:54 T:1680 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
07:18:55 T:1680 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
07:18:55 T:1680 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
07:18:55 T:1680 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=tv&url=https%3a%2f%2fwww.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall)
07:18:55 T:1680 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/?mode=main&thumb&type=tv&url]
07:18:55 T:7264 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','3','?mode=listVideos&thumb&type=tv&url=https%3a%2f%2fwww.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall')
07:18:55 T:7264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=16) plugin...
07:18:55 T:7456 NOTICE: Thread LanguageInvoker start, auto delete: false
07:18:55 T:7456 INFO: initializing python engine.
07:18:55 T:7456 DEBUG: CPythonInvoker(16, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): start processing
07:18:55 T:7456 NOTICE: -->Python Interpreter Initialized<--
07:18:55 T:7456 DEBUG: CPythonInvoker(16, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py"
07:18:55 T:7456 DEBUG: CPythonInvoker(16, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc;C:\Users\test\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
07:18:55 T:7456 DEBUG: CPythonInvoker(16, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc
07:18:55 T:7456 DEBUG: CPythonInvoker(16, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
07:18:55 T:1680 DEBUG: ------ Window Init (DialogBusy.xml) ------
07:18:56 T:7456 NOTICE: SSL is Disabled
07:18:56 T:7456 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\resources\language\English, fallback to strings.xml
07:18:56 T:7456 DEBUG: DialogProgress::StartModal called
07:18:56 T:7456 DEBUG: ------ Window Init (DialogProgress.xml) ------
07:18:56 T:7456 NOTICE: URL: https://www.netflix.com/MyList?leid=595&link=seeall
07:18:57 T:7264 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
07:18:57 T:7456 INFO: CPythonInvoker(16, C:\Users\test\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): script successfully run
07:18:57 T:7044 NOTICE: Thread BackgroundLoader start, auto delete: false
07:18:57 T:7044 DEBUG: Thread BackgroundLoader 7044 terminating
07:18:57 T:7456 INFO: Python script stopped
07:18:57 T:7456 DEBUG: Thread LanguageInvoker 7456 terminating
07:18:57 T:1680 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
07:18:57 T:1680 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://feeds.xbmc.org (easy=0D717BE8, multi=019A4BA0)
07:18:58 T:1680 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
07:19:01 T:1680 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
07:19:02 T:1680 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
07:19:02 T:1680 DEBUG: CApplication::OnKey: alt-leftalt (0x4f0d4) pressed, action is
07:19:02 T:1680 DEBUG: CWinEventsWin32::WndProcWindow is active
07:19:02 T:1680 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
(2015-06-22, 09:04)bolter Wrote: [ -> ]It doesn't matter where I install Netflixmbc from (repo or Zip file from Github) I get a script error and Kodi just freezes when trying to run Netflixmbc.
Attached the log file created when Kodi crashes. I am running nightlies of Isengard and Phil65 version of Aeon Nox.
Everything else runs fine just not Netflixmbc.
http://goo.gl/92cTAH
Can someone tell me what the problem is?
(2015-06-22, 09:48)corona Wrote: [ -> ](2015-06-22, 09:04)bolter Wrote: [ -> ]It doesn't matter where I install Netflixmbc from (repo or Zip file from Github) I get a script error and Kodi just freezes when trying to run Netflixmbc.
Sorry but the log file actually doesn't tell us much, which is strange. Basically the plugin just dies during login, without giving any error/exception messages.
There's a msg about trying to initialize the progress bar twice which is bad, but probably not the main issue.
There's often issues with ssl, could you try turning off advanced ssl in the netflixbmc settings if you haven't already?
(2015-06-22, 09:58)corona Wrote: [ -> ]Good to hear!One more thing, the "suggestion" field comes up empty all the time. I had this once before and had to turn off "test participation" to off but no longer works?
It's a real pain, the ssl changes are required for some people to get Netflix, and clearly break it for others. Might have to build a way to try connections with both settings and remember the result.
(2015-06-22, 10:09)bolter Wrote: [ -> ](2015-06-22, 09:58)corona Wrote: [ -> ]Good to hear!One more thing, the "suggestion" field comes up empty all the time. I had this once before and had to turn off "test participation" to off but no longer works?
