(2015-05-25, 10:53)garydebergerac Wrote: [ -> ]Ok sorry about getting the repo install wrong, but it's really confusing that SuperRepo has a version number that is higher than yours, but is an older version.
Got it running, but having a little trouble closing the browser and this link on the first page gets a 404 https://github.com/xbmc/xbmc/blob/master...ilib/Key.h I'm using Yatse remote and no keyboard, and none of the Yatse keys seem to work (back, info, etc). Any suggestions? Thanks!
So, it looks like you guys removed that link from the main page, which I guess is ...awesome?
I had a bunch of emails back and forth with the guy that wrote Yatse and basically there is nothing he can do; to quote, when asked about sending some keystroke combination: "Well I can send whatever I want it will be sent to Kodi and not to Chrome, so if the addon does not intercept and send them back there's 0 purpose for that. The enter or arrows are not keyboard commands they are native Kodi commands all is handled by the addons." Since we are limited to the default enter or arrow keys (Yatse's play, stop, etc don't show up), any chance you guys can get the back button working as an exit button? Enter does pause, and left and right do advance through the timeline, and even the Yatse trackpad does allow for some scrubbing, so some things are definitely working. But if you can't get back out to Kodi, ie exit Chrome, well, can't really use it. And I would very much like to!
And actually, it would really be nice to have a second button mapped to "stop" the video, ie drop back to the Netflix menus so you could stop watching something that sucks without having to exit and restart the addon.
[/quote]
I'm not sure what link's missing from what main page, but the first page here has always had the real link to my repo. If you're referring the the Key.h file, it's hardly my fault that kodi restructured their source tree and didn't tell me
it's not hard to find the new location of the file though.
https://github.com/xbmc/xbmc/blob/master...nput/Key.h
superrepo does what it wants and we have no control over it, it's always had a much lower version number than here, ..4 while we're up to ..20
The control system in kodi is based on actions (play, pause,back etc). The keyboard input layer translates keys into actions (based on xml keymap files), or you can use input system's like yatse to send actions directly, which is fine.
The plugin has a neat system (which was built by the original creater AddonScripterDe, I don't take credit for it) where it opens an invisible window while a video is playing in chrome such the invisible window can receive the kodi actions and forward them to chrome. With this system, inputs like web remote or yatse all should work perfectly. I'm not using it (I've got a super cheap remote that's perfect and acts like a normal keyboard) but others use it no worries.
