How to disable mini poster in the collection section.
Sorted out
Algum brasileiro nesse fórum ?
(2020-05-11, 01:28)Acrjunior Wrote: [ -> ]Algum brasileiro nesse fórum ?
Yes! I am brazilian.
But you have to write in english here.
(Sim, eu sou brasileiro!
Mas você tem que escrever em inglês por aqui.)
Hi, I have a trouble with play blu-ray disks on this theme+coreelec:
When I press "OK" (default settings function "play") key on pult, KODI does nothing: 1 second shows "waiting" and that all.
But when I hold key "ok" and select item from open menu: "play", kodi shows blu-ray menu from this media and I can play this media.
(2020-05-11, 02:05)edjalmo Wrote: [ -> ] (2020-05-11, 01:28)Acrjunior Wrote: [ -> ]Algum brasileiro nesse fórum ?
Ok, thanks for the tip.
As i am ne around here i didn`t know.
tell me some content in Portuguese for eminence 2 customiazation ?
i`m a fan of this skin.
(2020-05-11, 17:18)Acrjunior Wrote: [ -> ] (2020-05-11, 02:05)edjalmo Wrote: [ -> ] (2020-05-11, 01:28)Acrjunior Wrote: [ -> ]Algum brasileiro nesse fórum ?
What do you want to do ?
(#BR)
(2020-05-11, 18:40)Castilho Wrote: [ -> ] (2020-05-11, 17:18)Acrjunior Wrote: [ -> ] (2020-05-11, 02:05)edjalmo Wrote: [ -> ]Yes! I am brazilian.
(#BR)
I wanted to know why whenever I press down, the COLLECTION window opens.
I use my kodi just to watch TvOnline, movies and series.
I would like some tips to customize it.
Like, use more than transparencies.
Sorry for the mistakes in English.
(2020-05-11, 19:48)Acrjunior Wrote: [ -> ]I would like some tips to customize it.
We can give you one big tip: do not use or mention video piracy add-ons when you are on our forum.
You have accepted our
forum rules (wiki) when you registered here.
Hi, Long time user. IT savy but always a bit out of my depth with getting this skin humming. I've got it up and running nicely on my Shield but unfortunately every time it exits to the Shield UI when I come back in its defaulted back to Estuary. The Skin settings still say Eminence 2 Mod but its default Kodi. Switch skin to Estuary manually and then back to Eminence and its all back 100%
My research suggests that in shutting down there's some point where the skin crashes and so Kodi reverts to default every time. My question is, how do I find out what is failing where? Where is the shut down log? How best to access it? Any chance its viewable in onscreen?
Is there a way to disable the Media Info on the HOME SCREEN only? I see an option to disable it entirely, but I like it everywhere but the main screen.
Ideas?
Anyone else not get scroll bars for media? Neither movies nor TV shows has a way to scroll. I select the setting for the bar and /or alphabet. Neither show. The left side bar blips for a second, like it really wants to show up.
Using POSTERS view. I tried the rest.
Only works with BIG POSTERS view on the bottom.
Ideas?
there is some possibility of adding a function to go directly to a letter without having to go down with the bar.
Thank you
This has easily become my favorite skin. I switch every year or so, but this has been the cleanest with no crashes.
My want list for the skin is this:
- Remove Media Info from the HOME screen only. (A button already allows full removal)
- Quick scroll for Poster Wall view, as nothing is present at the moment. Something that uses a bar, alphabet, or a pop out. Most skins have it. This one does for several views.
- Remove $Film Budget info from the bottom of the screen. (A button removes it, but it doesn't always seem to work)
- Swap the Rating Star for a Favorite Star...or at least add one.
- Maybe a "what this button does" text when hovering over buttons in the media play view.
I'd take some assistance at least knowing where to begin editing.
Have used Eminence for many years and really enjoying the MOD. Thank you for your hard work.
I have maybe a simple question but couldn’t find the answer. When I click on the movie for more ‘information’ there are 9 squares below that you can click on for more information, when I click on actors they do come up. If I click on the actor it searches and always says ‘no results found’ it appears something is set up wrong?
Also when i click on ‘extended info’ nothing happens and at that point I am unable to click on the star and looks to be reload skin.
Any info how to get these working would be much appreciated.
