2018-03-19, 19:48
Hi and thanks for the super skin. I have problem with search for subtitles, download. Notifications about search and download are not visible.
(2018-03-19, 19:48)AVeliki Wrote: [ -> ]Hi and thanks for the super skin. I have problem with search for subtitles, download. Notifications about search and download are not visible.
(2018-03-20, 12:49)Decosub Wrote: [ -> ]please
in the submenu there is not the option of wigedt in the main menu if it is in the submenu ... is there any version that does? Could it be added as in the original version
(2018-03-21, 00:08)Decosub Wrote: [ -> ]it does not matter it's the best skin by far ... thank you very much for developing it, thank you for your timeI agree with the above. I keep looking at other skins to try out thinking "maybe this one will be better!" Nope, I always come back to Eminence 2 MOD.
(2018-03-20, 18:27)Alanon Wrote: [ -> ]There shouldn't be a bug. You probably have "Show sorting and info-line headers" disabled in the skin settings. Switch it on and the upper portions of the subtitles window should display the information.
(2018-03-25, 18:17)rusterboy77 Wrote: [ -> ]Hi to all,Hello! This is an old glitch/limitation that I haven't been able to fix. Due to the complexity of the shortcuts structure, the hub elements basically inherit settings from the main menu hub setting. I haven't been able to find a way to establish the colours beyond a list, because they seem to enter in as parts of a distinct unit. The best I can do at this point is to separate the settings somewhat, so that the hub list elements will have one independent text and highlight colour, the one set for the first hub list element, but independent of the main menu colour setting. I'll push that fix soon.
I'm having a problem with the setup color in the hub elements. I setup a different color for each hub list element but nothings happen.
Also hub element letter color isn't working for me. I just can change letter color writting it in the name description of the hub element.
Is there any option to make this two features on?
Thanx Alanon for your awesome job with the skin and your support. I hope we can see the new features of this beautiful skin on Kodi 18 very soon.
(2018-03-25, 20:32)cemmec Wrote: [ -> ]Hi everyone,The Spotlight is basically just a renamed playlist, though it's been so long since I've fiddled with it that I've forgotten about which specific settings it has. You can easily achieve what you need by using any of the pre-configured playlists from the widget selection menu (there are separate configurations for Unwatched Episodes and Unwatched Movies, as well as random and recommended tv/movie playlists).
I am a little confused by the concept of Spotlight. I want to change Spotlight to show unwatched movies when I am in movies menu and next episodes when I am in series menu. Is there any way to do these?
And in movie information screen I see a "Portugal" flag for my legends, but I'd like to show "Brazil" flag. How can I change this?
(2018-03-25, 22:56)Alanon Wrote: [ -> ]The Spotlight is basically just a renamed playlist, though it's been so long since I've fiddled with it that I've forgotten about which specific settings it has. You can easily achieve what you need by using any of the pre-configured playlists from the widget selection menu (there are separate configurations for Unwatched Episodes and Unwatched Movies, as well as random and recommended tv/movie playlists).I didn't find out how to to this in Spotlight.
There are two screens with that information. If you use the extended info add-on call (the one that's activated through the extendedinfo button in the skin's info screen), it retrieves all the information from web sources, so any error can be found/checked on the TMDb site. As far as the skins primary info screen, language flags are assigned based on the file's actual audio and subtitle tags - bra is standard for Brazillian and por is for Portuguese. If you're seeing an improper tag it's most likely because the encoder named it incorrectly. There's nothing you can do about that except manually erase the Portuguese flag por.png from the skin folder (media/lang) and replace it with the Brazillian (bra.png), essentially removing Portuguese entirely.
(2018-03-26, 00:16)cemmec Wrote: [ -> ] I didn't find out how to to this in Spotlight.
And about the flag, It worked replacing the file por.png, but my substitles are external .srt files, how to rename srt to be recognized?
(2018-03-25, 22:56)Alanon Wrote: [ -> ]Hello! This is an old glitch/limitation that I haven't been able to fix. Due to the complexity of the shortcuts structure, the hub elements basically inherit settings from the main menu hub setting. I haven't been able to find a way to establish the colours beyond a list, because they seem to enter in as parts of a distinct unit. The best I can do at this point is to separate the settings somewhat, so that the hub list elements will have one independent text and highlight colour, the one set for the first hub list element, but independent of the main menu colour setting. I'll push that fix soon.
As for 18, I haven't got the time to maintain any nightly builds, so I plan to move to v 18 exclusively when the first beta arrives and start building the skin slowly. Hopefully, I'll have everything up and running and any bugs fixed between the first beta and the final release.
