2017-08-04, 00:32
(2017-08-04, 00:04)axlt2002 Wrote: [ -> ](2017-08-03, 23:57)djhifi Wrote: [ -> ]OK so, with the autoconf.py replacement I can get to a part where the PHP binaries are installed OK. BUT, when I try to run the manual scan, the same error appears again.
You need another debug log?
(2017-08-03, 23:57)axlt2002 Wrote: [ -> ]Hey, what a quick answer!
Ok, lets put like this: the add-on retrieve the Movies/TV Shows/Episodes information directly from the Kodi database. So, if the Kodi database is updated by the EMBY for KODI add-on respecting the uniqueid formats, there is no issue for the ratings update. That is why I was asking you to provide my the log, just to check that aspect. Having said this, maybe I dind't understand correctly what you were asking...sorry, my brain is on vacation!
Yes, EMBY is actually modifying the KODI.db indeed and maybe thats why it Works, because my EMBY server scrapes everything OK, and what it doesnt, I make sure it is scrapped ok .
The debug log you want is from your addon running the ratings update on all my library items, correct?
Exactly! In case everything is confirmed, I will update the first post considering also EMBY.
(2017-08-04, 00:10)axlt2002 Wrote: [ -> ](2017-08-03, 23:39)djhifi Wrote: [ -> ]OK so, with the autoconf.py replacement I can get to a part where the PHP binaries are installed OK. BUT, when I try to run the manual scan, the same error appears again.
Sounds strange to receive the same error...before was something related to the fact that the system was not supported...now it should be different...of course a debug log would be useful!
I will post both debug logs asap.
