Is there a 19.1 version of this Kodi flavour?
fandangos This weekend, after my Mac Mini (early 2009) died, and finding that neither my Vero4k+ nor my Sony x900h could play my Hi10p anime reliably, I bought a 2019 Shield Pro. Installed your DV MKV build of Kodi, and I had to come here and thank you. It works a treat, plays everything I've thrown at it so far. Your work is much appreciated!
(2021-05-20, 10:02)Hitcher Wrote: [ -> ] (2021-05-20, 08:35)gil80 Wrote: [ -> ]Is there a 19.1 version of this Kodi flavour?
(2021-05-12, 17:11)Epedemic Wrote: [ -> ]@fandangos : Any chance you'll have time for a new build based on 19.1, now that that is out?
(2021-05-15, 22:01)sky.viewer42 Wrote: [ -> ]@fandangos When you have free time please, make build with v19.1
Current matrix builds (19.1) with DV adaptation are also made available
here.
(2021-05-26, 18:28)catshome Wrote: [ -> ] (2021-05-20, 10:02)Hitcher Wrote: [ -> ] (2021-05-20, 08:35)gil80 Wrote: [ -> ]Is there a 19.1 version of this Kodi flavour?
Current matrix builds (19.1) with DV adaptation are also made available here.
Which link is the 19.1 DV build for the Shield Pro? I can't tell.
(2021-05-26, 18:28)catshome Wrote: [ -> ]Current matrix builds (19.1) with DV adaptation are also made available here.
Thank you. Do these builds also have the blu-ray menu with Java capabilities enabled?
(2021-05-26, 23:30)MrMagic Wrote: [ -> ] (2021-05-26, 18:28)catshome Wrote: [ -> ]Current matrix builds (19.1) with DV adaptation are also made available here.
if you have any questions about the builds, please contact the author.
(2021-05-26, 20:22)catshome Wrote: [ -> ] (2021-05-26, 19:43)Wagg Wrote: [ -> ] (2021-05-26, 18:28)catshome Wrote: [ -> ]Current matrix builds (19.1) with DV adaptation are also made available here.
Matrix
Thanks- I assume the one in the 19.1 folder is the release and the others are dailies?
how can i install this over the @
fandangos Build?
(2021-05-27, 07:35)TrailFoX Wrote: [ -> ]how can i install this over the @fandangos Build?
I don't think you can. fandangos has to build his binary to overwrite the previous build.
no - this build has its own package name and is therefore installed in its own directory. you can install this build perallel.
(2021-05-27, 09:42)catshome Wrote: [ -> ] (2021-05-27, 07:35)TrailFoX Wrote: [ -> ]how can i install this over the @fandangos Build?
Are you saying you can have 2 kodi' s running side by side?
(2021-05-27, 11:12)movie78 Wrote: [ -> ] (2021-05-27, 09:42)catshome Wrote: [ -> ] (2021-05-27, 07:35)TrailFoX Wrote: [ -> ]how can i install this over the @fandangos Build?
I only installed this build, but a parallel installation would work.
