A little update to play VEVO...but another approach on decoding the signature (works a little faster)
great, i'm going to test.
Peppe
Update...alpha9
Login has been added. Feedback would be nice
so I can see if everything works fine. To Login into YouTube you have to go into the settings of the addon before navigating into the root directory. After you have entered your credentials, you should see your subscriptions and so on.
And Thanks!
(2014-07-29, 02:40)upandcumming Wrote: [ -> ]Login not working!
Did you not read the first post?
Quote:A solution for the login I have also (tests worked - but not implemented yet -> coming soon)
(2014-07-29, 06:36)handbone Wrote: [ -> ] (2014-07-29, 02:40)upandcumming Wrote: [ -> ]Login not working!
Did you not read post #4?
(2014-07-28, 20:25)bromix Wrote: [ -> ]Update...alpha9
Login has been added. Feedback would be nice so I can see if everything works fine. To Login into YouTube you have to go into the settings of the addon before navigating into the root directory. After you have entered your credentials, you should see your subscriptions and so on.
And Thanks!
I would be interested in using this as my default youtube plugin but I require a few features...
If possible can you add direct playback via shortcut, similar to the official youtube plugin? for example
'plugin://plugin.video.bromix.youtube/?path=/root/video&action=play_video&videoid='+url
url == the youtube video id
Can you also suppress any dialog boxes from opening during playback, for example the official youtube plugin would have a "Opening youtube" okdialog box , I would like to either have that removed or not displayed when a xbmc event window is active...
I appreciate your efforts to remove some sluggish features inorder to stream line video playback.
This YouTube (ALPHA) addon does seem a bit faster to me. Also I really like how this version shows the avatar pics of the subscriptions. I often add subscription channels to may favorites and then have to go and set the icon on my own. With the YouTube (ALPHA) version I don't have to do that anymore. Thank you for all of your effort with this.
(2014-07-29, 17:31)Lunatixz Wrote: [ -> ]I would be interested in using this as my default youtube plugin but I require a few features...
At the moment this should work. If you need a version with the full url, I can add this feature for the next update, but if possible, I would prefer the ID
'plugin://plugin.video.bromix.youtube/?action=play&id=VIDEO_ID
Which dialogs do you mean exactly?
(2014-07-29, 19:18)TomFreeloader Wrote: [ -> ]This YouTube (ALPHA) addon does seem a bit faster to me. Also I really like how this version shows the avatar pics of the subscriptions. I often add subscription channels to may favorites and then have to go and set the icon on my own. With the YouTube (ALPHA) version I don't have to do that anymore. Thank you for all of your effort with this.
Thank you for your feedback. I am pleased that the addon is running faster. Since today alpha10 is out. You might try this version
(2014-07-29, 21:35)bromix Wrote: [ -> ] (2014-07-29, 17:31)Lunatixz Wrote: [ -> ]I would be interested in using this as my default youtube plugin but I require a few features...
Thanks, VideoID is just fine, exactly what I need... I'm referring to this dialog box... if you can either disable it all together or disable when a activewindow is true... it would be great
https://www.dropbox.com/s/rgs312i0qwdfh5...hot032.png
if xbmcgui.Window(10000).getProperty("PseudoTVRunning") == "True":
##Disable dialog
Very good work bromix, really liking this.
I am hoping that my search history could stay visible (without logging in), hopefully that is possible.
Update Alpha11
Age-restricted videos should work now
Like the work on this so far, would like to make a request; feature:- to auto play unwatched or random..
