(2017-01-04, 17:22)pkscout Wrote: [ -> ] (2017-01-04, 14:47)hoschilo Wrote: [ -> ]I think the beta repo points towards "gotham" branch - so no updates by this channel for me..or do I miss something?
Please check the wiki page for AS. There are two versions of the beta repo, one for Gotham and one for for Helix onward. I use my beta repo on my main HTPC. I just checked, and it downloaded AS 2.0.6~beta2 last night. If you have the right repo, you might try manually checking for updates. I think Kodi only checks repos every day or so for updates automatically.
I'm sorry but when I click the link on the AS wiki page it directly downloads the Gotham file. No selection possible. For me it is not a problem I can download beta via github - if I'm the only one struggling with this no need to change anything.
(2017-01-04, 19:26)hoschilo Wrote: [ -> ] (2017-01-04, 17:22)pkscout Wrote: [ -> ] (2017-01-04, 14:47)hoschilo Wrote: [ -> ]I think the beta repo points towards "gotham" branch - so no updates by this channel for me..or do I miss something?
I checked the wiki. There are two repos for my skins, but only one for my beta stuff. My bad. The one for the beta stuff is Helix+ and it's the one I use on my main production machine to get updates. It's definitely working. If you want to just download from GitHub that's your call. Be aware that if you install the GitHub one directly from the zip you will get a folder with -master at the end. So you could end up with 2 copies of AS, and I have no idea which one Kodi will try and run.
(2017-01-04, 08:29)pkscout Wrote: [ -> ] (2017-01-04, 07:30)rew88 Wrote: [ -> ]hi pk at the moment it is doing the same thing but leaving a blank page no picture
my log file http://www.freespace.com.au/filehosting/794499
Fixed. That was caused by some additional logging I added when trying to troubleshoot the artist change problem. The crash probably only happened with artists that have extended characters in their name. 2.0.6~beta2 is in the repo now.
thanks for that at the moment it is running perfectly boy you sure are fast at fixing things LOL
rew88
(2017-01-04, 22:19)pkscout Wrote: [ -> ] (2017-01-04, 19:26)hoschilo Wrote: [ -> ] (2017-01-04, 17:22)pkscout Wrote: [ -> ]Please check the wiki page for AS. There are two versions of the beta repo, one for Gotham and one for for Helix onward. I use my beta repo on my main HTPC. I just checked, and it downloaded AS 2.0.6~beta2 last night. If you have the right repo, you might try manually checking for updates. I think Kodi only checks repos every day or so for updates automatically.
I guess we are talking about different things or tracks. I'm talking about the link shown below
Nope. That's the link. I checked, double checked, and tripled checked. It is going to the one and only version of the beta repo installer, and that repo is working fine for all versions of Kodi Helix and later. I use it on a machine of my own to download any beta I push out. As of yesterday I was able to get the current beta software downloaded from it.
Just to show some love for your addon
One of the best! Really makes the difference!
your addon and CRC lyrics are the perfect setup to hear music in kodi.
pkscout, ever seen this before? It's trying to download images but not displaying them.
03:20:19.164 T:1958597552 NOTICE: Running the application...
03:20:19.173 T:1958597552 NOTICE: starting zeroconf publishing
03:20:19.211 T:1958597552 NOTICE: CWebServer[8080]: Started
03:20:19.211 T:1958597552 NOTICE: starting upnp client
03:20:19.215 T:1596978160 NOTICE: ES: Starting UDP Event server on port 9777
03:20:19.215 T:1596978160 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
03:20:20.166 T:1665905648 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
03:20:24.555 T:1683993584 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
03:20:32.801 T:1958597552 ERROR: Error loading Smart playlist special://masterprofile/PartyMode.xsp (failed to read file)
03:20:35.245 T:1692382192 NOTICE: Skin Helper Service --> skin helper service version 1.0.100 started
03:20:35.275 T:1717548016 NOTICE: service.libraryautoupdate-0.9.8 : Update Library Service starting...
03:20:35.345 T:1692382192 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
03:20:35.440 T:1717548016 NOTICE: service.libraryautoupdate-0.9.8 : update timers
03:20:35.490 T:1709159408 NOTICE: script.grab.fanart: Grab Fanart Service Started
03:20:35.591 T:1717548016 NOTICE: service.libraryautoupdate-0.9.8 : Creating timer for Video Library
03:20:36.016 T:1958597552 ERROR: file : XML file doesnt contain <window>
03:20:37.097 T:1734325232 WARNING: CSkinInfo: failed to load skin settings
03:20:51.952 T:1451226096 NOTICE: Skin Helper Service --> getfanartTVimages lookup failed--> HTTPConnectionPool(host='webservice.fanart.tv', port=80): Read timed out. (read timeout=15)
03:21:00.242 T:1405076464 NOTICE: [Artist Slideshow] script version 2.0.6 started
03:21:00.243 T:1405076464 NOTICE: [Artist Slideshow] debug logging set to false
03:21:05.531 T:1958597552 ERROR: file : XML file doesnt contain <window>
03:21:07.963 T:1451226096 NOTICE: Skin Helper Service --> getfanartTVimages lookup failed--> HTTPConnectionPool(host='webservice.fanart.tv', port=80): Read timed out. (read timeout=15)
03:22:35.320 T:1958597552 ERROR: file : XML file doesnt contain <window>
03:26:40.007 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:26:40.008 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:26:42.273 T:1734325232 WARNING: CSkinInfo: failed to load skin settings
03:26:43.647 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:26:43.647 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:26:46.326 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:26:46.326 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:26:47.138 T:1665905648 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
03:26:47.364 T:1665905648 WARNING: Previous line repeats 2 times.
03:26:47.364 T:1665905648 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/dywDjqAJoWudjgtHHIndmY9xvj9.jpg
03:26:47.863 T:1958597552 ERROR: Misplaced [
03:26:47.864 T:1958597552 ERROR: Error parsing boolean expression !System.HasAddon(script.artistslideshow) | !$INFO[Window(Visualisation).Property(ArtistSlideshow.ArtworkReady)]
03:26:47.898 T:1518326768 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
03:26:47.898 T:1518326768 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/nBNZadXqJSdt05SHLqgT0HuC5Gm.jpg
03:26:47.910 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:26:47.911 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:26:51.936 T:1665905648 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
03:26:51.937 T:1665905648 WARNING: Previous line repeats 1 times.
03:26:51.937 T:1665905648 NOTICE: LoadJpeg: unable to load /home/osmc/.kodi/userdata/addon_data/script.artistslideshow/transition/3c787293.jpg
03:26:52.378 T:1393554416 NOTICE: [Artist Slideshow] script version 2.0.6 started
03:26:52.379 T:1393554416 NOTICE: [Artist Slideshow] debug logging set to false
03:26:52.379 T:1393554416 NOTICE: [Artist Slideshow] script stopped
03:26:55.041 T:1692382192 NOTICE: Skin Helper Service --> getfanartTVimages lookup failed--> HTTPConnectionPool(host='webservice.fanart.tv', port=80): Read timed out. (read timeout=15)
03:27:30.754 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:27:30.754 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:27:34.236 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:27:34.236 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:27:36.445 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:27:36.445 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:27:37.908 T:1674294256 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/City.png
03:27:40.251 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:27:40.275 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:27:49.609 T:1393554416 NOTICE: [Artist Slideshow] script version 2.0.6 started
03:27:49.609 T:1393554416 NOTICE: [Artist Slideshow] debug logging set to false
03:27:49.610 T:1393554416 NOTICE: [Artist Slideshow] script stopped
03:27:58.705 T:1393554416 NOTICE: [Artist Slideshow] script version 2.0.6 started
03:27:58.705 T:1393554416 NOTICE: [Artist Slideshow] debug logging set to false
03:27:58.707 T:1393554416 NOTICE: [Artist Slideshow] script stopped
03:28:36.904 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:28:36.904 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:28:38.925 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:28:38.926 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:28:38.969 T:1937765360 NOTICE: DecodeJpeg: unable to decode /home/osmc/.kodi/userdata/addon_data/script.artistslideshow/ArtistSlideshow/3eeda8fb/9a6a720b.jpg 1280x720
03:28:42.084 T:1518326768 NOTICE: [Artist Slideshow] script version 2.0.6 started
03:28:42.084 T:1518326768 NOTICE: [Artist Slideshow] debug logging set to false
03:28:42.085 T:1518326768 NOTICE: [Artist Slideshow] script stopped
03:28:44.364 T:1405076464 ERROR: GetDirectory - Error getting /mnt/Main/Music/Justins/Dark Lotus/extrafanart
03:29:14.643 T:1451226096 NOTICE: Skin Helper Service --> getfanartTVimages lookup failed--> HTTPConnectionPool(host='webservice.fanart.tv', port=80): Read timed out. (read timeout=15)
03:29:24.243 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:29:24.243 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:29:27.120 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:29:27.120 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:31:05.482 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:31:05.482 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:31:08.466 T:1958597552 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
03:31:08.466 T:1958597552 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
03:31:14.211 T:1937765360 NOTICE: [Artist Slideshow] script version 2.0.6 started
03:31:14.212 T:1937765360 NOTICE: [Artist Slideshow] debug logging set to false
03:31:14.215 T:1937765360 NOTICE: [Artist Slideshow] script stopped
03:31:34.322 T:1451226096 NOTICE: Skin Helper Service --> getfanartTVimages lookup failed--> HTTPConnectionPool(host='webservice.fanart.tv', port=80): Read timed out. (read timeout=15)
03:31:46.890 T:1665905648 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
03:31:46.892 T:1665905648 WARNING: Previous line repeats 1 times.
03:31:46.892 T:1665905648 NOTICE: LoadJpeg: unable to load /home/osmc/.kodi/userdata/addon_data/script.artistslideshow/ArtistSlideshow/be96b158/35b5076e.jpg
Based on that log I'd say you have some kind of OS problem. LoadJpeg is failing for everything, not just images AS has downloaded.
(2017-01-07, 18:04)pkscout Wrote: [ -> ]Based on that log I'd say you have some kind of OS problem. LoadJpeg is failing for everything, not just images AS has downloaded.
Yeah, I don't know what all that was about but it seems to have gone away. Still can't get AS images to show up, though. I've tried the kodi repo and your beta repo versions of AS. I tried modding the stock Confluence skin and using your Estuary mod. I'm on Kodi 17 RC1.
Did I do this part right?
$ head MusicVisualisation.xml
<?xml version="1.0" encoding="UTF-8"?>
<onload>RunScript(script.artistslideshow)</onload>
<window>
<defaultcontrol>-</defaultcontrol>
<controls>
<control type="visualisation" id="2">
<!-- FIX ME Music Visualization needs to have an id of 2 in this window to be able to lock or change preset -->
<description>visualisation</description>
<left>0</left>
<top>0</top>
There's still some LoadJpeg errors popping up but that seems to be due to your Estuary mod not having a background named pattern1.jpg.
~/.kodi/addons/skin.estuary.krypton.pkscout.mod/extras/backgrounds$ ls
primary.jpg secondary2.png secondary4.png secondary6.png secondary1.png secondary3.png secondary5.png
I turned on debug logging for Kodi and AS, sorry for the huge file.
http://paste.osmc.io/patucigeju
Edit: I just restarted and now they're working in your Estuary Mod. Still black screen in Confluence.
Are you using the stock Confluence for Kodi 17? If so, that doesn't support Artist Slideshow. I'm also not planning to do a Confluence mod for Kodi 17, and I don't think any of the older mods of Confluence I did will work well in Kodi 17.
(2017-01-06, 01:13)pkscout Wrote: [ -> ]Nope. That's the link. I checked, double checked, and tripled checked. It is going to the one and only version of the beta repo installer, and that repo is working fine for all versions of Kodi Helix and later. I use it on a machine of my own to download any beta I push out. As of yesterday I was able to get the current beta software downloaded from it.
Similar to @
hoschilo I am not finding the AS 2.0.6 beta 2 version either. I download the repo and AS 1.7.0 is what it showing that is able to be downloaded. So there is no confusion:
http://raw.github.com/pkscout/repository...-1.0.2.zip
Is this the correct address for those with Helix and newer? This is the link that I am getting when going to the wiki.
(2017-01-07, 23:50)Xtraordinair Wrote: [ -> ] (2017-01-06, 01:13)pkscout Wrote: [ -> ]Nope. That's the link. I checked, double checked, and tripled checked. It is going to the one and only version of the beta repo installer, and that repo is working fine for all versions of Kodi Helix and later. I use it on a machine of my own to download any beta I push out. As of yesterday I was able to get the current beta software downloaded from it.
Similar to @hoschilo I am not finding the AS 2.0.6 beta 2 version either. I download the repo and AS 1.7.0 is what it showing that is able to be downloaded. So there is no confusion:
Apparently I needed to quadruple check the link. That repo link is, in fact, to the old Gotham one. I've updated with wiki with the link to the Helix one. Sorry about that. That was totally my bad.
Hi pkscout,
thanks for the great addon. It worked fine for a long time I used Kodi 14.2 Helix with confluence skin.
Today I've made an update to 17.0, installed AS and AS Helper and installed the modded skin from your repository too. AS shows a message that it's downloading pictures. The pictures can be copied correctly with AS Helper. But Kodi is not showing the slideshow. Not the downloaded pictures, not either the local ones.
Here is the logfile:
https://paste.ubuntu.com/23767253/
Vizualization is set to "none".
Thanks for your help.
Gussel
(2017-01-09, 01:03)Gussel Wrote: [ -> ]Today I've made an update to 17.0, installed AS and AS Helper and installed the modded skin from your repository too. AS shows a message that it's downloading pictures. The pictures can be copied correctly with AS Helper. But Kodi is not showing the slideshow. Not the downloaded pictures, not either the local ones.
I see where AS sets the directory for the artist images to Y:\Fady Maalouf\extrafanart, but when it goes to see if there are images, Kodi generates a directory read error:
XFILE::CDirectory::GetDirectory - Error getting Y:\Fady Maalouf\extrafanart
This generally indicates that the directory doesn't exist or isn't readable by Kodi. Is Y: still a valid drive mapping on your system?
(2016-12-25, 17:06)pkscout Wrote: [ -> ] (2016-12-25, 05:34)hurricane51 Wrote: [ -> ] (2016-12-25, 05:15)pkscout Wrote: [ -> ]Please DO NOT paste the log in a reply. See the link in my signature for how to post a debug log.
Here's the logfile: https://paste.ubuntu.com/23680615
That log shows only that Artist Slideshow has been installed. There is no indication that it is ever activated. You have to playing music, have your skin on the music visualization screen, and have a skin that supports AS.
I don't know what to say. I looked at the add-on and it is enabled. In this case I click on Run (I never had to do that before). When I play music the background is black. I bring up the visualization screen and the Artist slideshow add-on is enabled. If I disable AS in that screen, exit back to the song listing, then return to the visualization window and re-enable AS everything works, until I exit KODI. Then I have to go through this whole procedure again.
I'll send another log file. I also have a screen capture video, but that's a bit larger.
