Full Version: [RELEASE] Aeon MQ 5
MarcosQui,
Could you please go back to the Original Watched Overlay ICON, or is it possible for users to change the icon.
Because the Yellow tick circle looks very cheap and doesn't go with the theme at all.
The weather bug presented some pages back is still alive Sad After I reset the skin's settings I'm trying to change to animated icons for the weather, not changing anything else....and the weather no longer shows on the main page. Is there a trick to make it work again ? I can't get it back in any way, only restetting the skin again works...and that is only with no animated icons. I have the extrapack, everything...
When I go to Music on the main menu, above Music is: recently added or random artists or albums and a sampling of the chosen option. How do I make so that one of my custom added main menu selections will have this as well?
Advanced Launcher Doesn't work as it should in MQ5 fanart not showing, fanart has been scraped but not showing in selection.
Fixed
(2013-10-01, 16:02)arabesque Wrote: [ -> ]hello again i have spotted a bug and an omission...
the number of seasons is not mentioned correctly
and here there is no reference to the season currently browsed
Make sure you don't have other episodes or seasons in other drives/folders.
I had the same problem and discovered i had a season on one drive and the rest on another.
My problem was I had,
F:\TV Shows\Breaking Bad\ Season 1\Breaking bad 1x01, 1x02, 1x03 etc etc
F:\TV Shows\Breaking Bad\ Season 2\Breaking bad 2x01, 2x02, 2x03 etc etc
and
G:TV Shows\Breaking Bad\ Season 3\Breaking bad 3x01, 3x02, 3x03 etc etc
It only showed 2 seasons, because season three was on another drive.
(2013-10-09, 13:08)indiejones Wrote: [ -> ]Fixed
What are you referring to??
Customizing main menu on Gotham seems to quite broken, adding custom submenu entries doesn't seem to be working at all, only cloning.
When adding new main menu entries they often don't work until xbmc is restarted and menu items seems to randomly break in general when changing things.
Is there a way to change the EPG Timeline to display channel icons on the grid? Also, how do I make Timeline the default view when I go to Live TV? Right now it defaults to TV Channels with the top menu activated.
I use the WMC PVR by krustyreturns (http://forum.xbmc.org/showthread.php?tid=171216) and the backend comes with the ability to create a series recording when you select to record an episode. This is controlled by an XML file RecordPrefs.XML. I have created the XML file, and it functions the way I want it to, however it doesn't display the same as other MQ5 dialogs (i.e. doesn't change the background) and I was hoping somebody could help me put the finishing touches on this and explain to me what I was missing. Thank you!
Here is a link to the file: https://docs.google.com/file/d/0B0WaVVQc...sp=sharing
Some bugs with skin settings
If I choose the "show next track" but the "show now playing" is off then it doesn't show only show next track.
if I shut down the "show details " button , the details shuts down,but then if I press the button again if I want to see the details,
the details are still off,also on the full player mode.
u need to restart the xbmc and it gets fixed again.
I don't really use it, but thought of reporting it cause I love this skin...
i use xbmc 13 alph1 and try to install mq5 21mb file with name of skin.aeonmq5-1.3.2-Gotham.zip but i get error "Dependencies not met"
whyHuh
@behking, better you install add-ons from official XBMC repo, look in first post, for list add-ons necessary, and only after installed, install skin.
When installing the skin a large number of addons are installed simultaneously, so it is absolutely normal to have only a black screen for 1 minute or more, depending on the internet conditions.
Sometimes, donĀ“t get all modules necessary for addon install fine, and appears message - dependencies not met.
Holy cow...Only been using a few minutes but holy cow...MQ...This is breathtaking. What an achievement. Thank you so much.
thanks wanilton
i like to use "episode banner" view for tvshows in mq4 . is there any way to add this view in mq5 or ace Huh
Great skin,working almost perfectly
2 things: how to save a playlist?no option SAVE anywhere
How to fit more (smaller) posters on Multiplex view?
at the moment I can view 7 large posters per page only
