hello someone help me to work advanced launcher with emultionstation on linux
i try this
<application>/bin/sh</application>
<args>0 _SYS_ snes %ROM%</args>
<rompath>/opt/retropie/supplementary/runcommand/runcommand.sh</rompath>
in terminal , i tape
/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ snes 'path/to/my/game'
its work great
but in advanced launcher nothing work, i don't understand because if i tape emulationstation at rompath, it's work great....
what's happen argument 0 _SYS_ snes not work?
please help me
(2018-10-26, 16:13)Wintermute0110 Wrote: [ -> ] (2018-10-26, 16:07)bibiyanki Wrote: [ -> ]hello someone help me to work advanced launcher with emultionstation on linux
i try this
its work great
please help me
Try this
<application>/opt/retropie/supplementary/runcommand/runcommand.sh</application>
<args>0 _SYS_ snes $rom$</args>
<ROM_path>/path/to/your/snes/roms/</ROM_path>
Thank for answer
Yes i try it without succès
Ans i try without argument ROM without succès
I think,it dont take argument....because i try with bash script, that work...
(2018-10-26, 17:04)bibiyanki Wrote: [ -> ]Thank for answer
Try this
<args>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ snes $rom$</args>
If that doesn't work either I will need a debug log. You have instructions about how to post a debug log in the first post.
(2018-10-26, 17:46)Wintermute0110 Wrote: [ -> ] (2018-10-26, 17:04)bibiyanki Wrote: [ -> ]Thank for answer
Try this
unfurtunately, itsn't work
my kodi.log
Quote:0:30:52.404 T:140338873556928 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
20:30:52.653 T:140338873556928 DEBUG: ProcessMouse: unknown mouse command 57605
20:30:52.654 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:30:52.665 T:140338873556928 DEBUG: ProcessMouse: unknown mouse command 57606
20:30:52.736 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:30:54.429 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:30:55.328 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:30:55.423 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:30:57.493 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:30:58.258 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:01.017 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:01.249 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:01.796 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:02.112 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:02.419 T:140338873556928 INFO: Python, unloading python shared library because no scripts are running anymore
20:31:02.426 T:140338873556928 DEBUG: UnloadExtensionLibs, clearing python extension libraries
20:31:18.532 T:140338873556928 INFO: GL: Maximum texture width: 16384
20:31:22.002 T:140337042048768 DEBUG: Thread JobWorker 140337042048768 terminating (autodelete)
20:31:22.002 T:140338156861184 DEBUG: Thread JobWorker 140338156861184 terminating (autodelete)
20:31:22.002 T:140337033656064 DEBUG: Thread JobWorker 140337033656064 terminating (autodelete)
20:31:22.391 T:140337309992704 DEBUG: Thread JobWorker 140337309992704 terminating (autodelete)
20:31:27.106 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:27.565 T:140338873556928 INFO: GL: Maximum texture width: 16384
20:31:32.525 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:32.660 T:140338873556928 DEBUG: ProcessMouse: trying mouse action leftclick
20:31:32.660 T:140338873556928 DEBUG: RunScriptWithParams - calling plugin Advanced Launcher('plugin://plugin.program.advanced.launcher/','-1','?6a54129fc049f78b402f3ee906e0a5bc/93c4b83600c6093bdcb77f2124d8a5a2')
20:31:32.660 T:140337309992704 DEBUG: Thread LanguageInvoker start, auto delete: false
20:31:32.661 T:140337309992704 INFO: initializing python engine.
20:31:32.669 T:140337309992704 DEBUG: CPythonInvoker(2, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): start processing
20:31:32.675 T:140337309992704 DEBUG: -->Python Interpreter Initialized<--
20:31:32.675 T:140337309992704 DEBUG: CPythonInvoker(2, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): the source file to load is "/home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py"
20:31:32.675 T:140337309992704 DEBUG: CPythonInvoker(2, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): setting the Python path to /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0
20:31:32.675 T:140337309992704 DEBUG: CPythonInvoker(2, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): entering source directory /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher
20:31:32.675 T:140337309992704 DEBUG: CPythonInvoker(2, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): instantiating addon using automatically obtained id of "plugin.program.advanced.launcher" dependent on version 2.14.0 of the xbmc.python api
20:31:32.707 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:32.793 T:140337309992704 DEBUG: [ALA] Initialisation
20:31:32.793 T:140337309992704 WARNING: Attempt to use invalid handle -1
20:31:33.655 T:140338873556928 WARNING: Previous line repeats 4 times.
20:31:33.655 T:140338873556928 DEBUG: ProcessMouse: trying mouse action rightclick
20:31:33.658 T:140338873556928 DEBUG: CFavourites::Load - no system favourites found, skipping
20:31:33.658 T:140338873556928 DEBUG: CFavourites::Load - no userdata favourites found, skipping
20:31:33.658 T:140338873556928 INFO: Loading skin file: DialogContextMenu.xml, load type: KEEP_IN_MEMORY
20:31:33.659 T:140338873556928 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
20:31:33.660 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:33.801 T:140337846675200 DEBUG: Failed to connect to LIRC. Giving up.
20:31:33.801 T:140337846675200 DEBUG: Thread RemoteControl 140337846675200 terminating
20:31:33.801 T:140338873556928 INFO: LIRC SetEnabled: disabled
20:31:33.801 T:140337846675200 DEBUG: Thread RemoteControl start, auto delete: false
20:31:33.801 T:140337846675200 INFO: LIRC Process: using: /var/run/lirc/lircd
20:31:33.801 T:140337846675200 INFO: LIRC Connect: connect failed: No such file or directory
20:31:33.801 T:140337846675200 INFO: CRemoteControl:rocess - failed to connect to LIRC, will keep retrying every 5 seconds
20:31:34.410 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:34.801 T:140337309992704 INFO: CPythonInvoker(2, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): script successfully run
20:31:34.809 T:140337309992704 INFO: Python script stopped
20:31:34.809 T:140337309992704 DEBUG: Thread LanguageInvoker 140337309992704 terminating
20:31:35.906 T:140338873556928 DEBUG: ProcessMouse: trying mouse action leftclick
20:31:35.907 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:35.943 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:36.144 T:140338873556928 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
20:31:36.149 T:140338873556928 DEBUG: StartScript - calling plugin Advanced Launcher('plugin://plugin.program.advanced.launcher/','3','?6a54129fc049f78b402f3ee906e0a5bc/93c4b83600c6093bdcb77f2124d8a5a2')
20:31:36.150 T:140337309992704 DEBUG: Thread LanguageInvoker start, auto delete: false
20:31:36.150 T:140337309992704 INFO: initializing python engine.
20:31:36.150 T:140337309992704 DEBUG: CPythonInvoker(3, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): start processing
20:31:36.155 T:140337309992704 DEBUG: -->Python Interpreter Initialized<--
20:31:36.155 T:140337309992704 DEBUG: CPythonInvoker(3, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): the source file to load is "/home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py"
20:31:36.155 T:140337309992704 DEBUG: CPythonInvoker(3, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): setting the Python path to /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0
20:31:36.155 T:140337309992704 DEBUG: CPythonInvoker(3, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): entering source directory /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher
20:31:36.155 T:140337309992704 DEBUG: CPythonInvoker(3, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): instantiating addon using automatically obtained id of "plugin.program.advanced.launcher" dependent on version 2.14.0 of the xbmc.python api
20:31:36.170 T:140337033656064 DEBUG: Thread scriptobs start, auto delete: false
20:31:36.259 T:140337309992704 DEBUG: [ALA] Initialisation
20:31:36.370 T:140338873556928 DEBUG: ------ Window Init (DialogBusy.xml) ------
20:31:37.265 T:140337846675200 DEBUG: Failed to connect to LIRC. Giving up.
20:31:37.265 T:140337846675200 DEBUG: Thread RemoteControl 140337846675200 terminating
20:31:37.265 T:140338873556928 INFO: LIRC SetEnabled: disabled
20:31:37.270 T:140337846675200 DEBUG: Thread RemoteControl start, auto delete: false
20:31:37.270 T:140337846675200 INFO: LIRC Process: using: /var/run/lirc/lircd
20:31:37.270 T:140337846675200 INFO: LIRC Connect: connect failed: No such file or directory
20:31:37.270 T:140337846675200 INFO: CRemoteControl:rocess - failed to connect to LIRC, will keep retrying every 5 seconds
20:31:38.268 T:140337309992704 INFO: CPythonInvoker(3, /home/bibiyqnki/.kodi/addons/plugin.program.advanced.launcher/addon.py): script successfully run
20:31:38.277 T:140337309992704 INFO: Python script stopped
20:31:38.277 T:140337309992704 DEBUG: Thread LanguageInvoker 140337309992704 terminating
20:31:38.297 T:140337033656064 DEBUG: Thread scriptobs 140337033656064 terminating
20:31:38.542 T:140338873556928 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
20:31:39.383 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:31:40.119 T:140338873556928 DEBUG: ------ Window Init (Pointer.xml) ------
20:31:40.266 T:140338873556928 DEBUG: ------ Window Deinit (Pointer.xml) ------
someone try argument work with linux distribution
i try with wine program not work...
thank man's
friend i have success configuration with retropie/libretro load application emulationstation or libretro in opt folder
Quote:<application>/opt/retropie/emulators/retroarch/bin/retroarch</application>
<args>-L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so -f -v "$rom$"</args>
and for user emulator like cemu (wii u), i do this
that work for game windows too
Quote: <platform>Nintendo Wii U</platform>
<categoryID>root_category</categoryID>
<application>/bin/bash</application>
<args>wine '/patch/to/cemu.exe' -f -g "$rom$"</args>
<rompath>/home/$user/RetroPie/roms/wiiu/</rompath>
<romext>wud|.wud</romext>
(2018-10-27, 11:39)bibiyanki Wrote: [ -> ]friend i have success configuration with retropie/libretro load application emulationstation or libretro in opt folder
I'm glad it finally worked for you. Note that AML can launch sh scripts in Linux, this have been tested by many users.
By the way Wintermute0110, is there some way to add assets and metadata to the virtual launchers (such as the genre listing) ? I'd like to have short descriptions and icon but I can't seem to find a way to change these and/or hack it
I'm also using slightly old version (0.9.6) since I'm still on Kodi Jarvis due to using an older skin...
Thank you once more for the work on this, AEL is beautiful!
(2018-11-04, 16:19)Aatos Wrote: [ -> ]By the way Wintermute0110, is there some way to add assets and metadata to the virtual launchers (such as the genre listing) ? I'd like to have short descriptions and icon but I can't seem to find a way to change these and/or hack it .
What skin (Cirrus, Rapier, ...?)
Sadly that's the thing with Kodi, new version gets released and superb skins get lost like tears in the rain.
AEL 0.9.8 included artwork for all the virtual launchers, contributed by an user. However, 0.9.8 was never released and Chrisism and I are working now on 0.10.0. You may try 0.10.0 from Github, but keep in mind that AEL in master branch is now highly unstable. AEL is named now
plugin.program.AEL
instead of
plugin.program.advanced.emulator.launcher
. If you install AEL 0.10.0 you old AEL data will be in the
directory in
user_data
, don't panic if all your launchers are gone and just copy all the contents of old AEL dir into the new one.
If you want to hack AEL 0.9.6 I can tell you where to look at. Best thing is to wait until 0.10.0 gets released, which includes the default artwork. I can add a feature, like adding a XML so you can configure your own artwork for the virtual launchers. Minimum required Kodi version for 0.10.0 will be Krypton.
(2018-11-04, 16:50)Wintermute0110 Wrote: [ -> ] (2018-11-04, 16:19)Aatos Wrote: [ -> ]By the way Wintermute0110, is there some way to add assets and metadata to the virtual launchers (such as the genre listing) ? I'd like to have short descriptions and icon but I can't seem to find a way to change these and/or hack it .
What skin (Cirrus, Rapier, ...?) Sadly that's the thing with Kodi, new version gets released and superb skins get lost like tears in the rain.
AEL 0.9.8 included artwork for all the virtual launchers, contributed by an user. However, 0.9.8 was never released and Chrisism and I are working now on 0.10.0. You may try 0.10.0 from Github, but keep in mind that AEL in master branch is now highly unstable. AEL is named now plugin.program.AEL
instead of plugin.program.advanced.emulator.launcher
. If you install AEL 0.10.0 you old AEL data will be in the plugin.program.advanced.emulator.launcher
directory in user_data
Yes, it's the old SexyCirrus, however I've edited that too to be a bit more to my liking, so moving to 0.10.0 and to Krypton will be quite difficult. Maybe one day I have to since you keep adding great features, but would have to figure out how to move the skin first. In the meantime, if you can point me to the right direction to do something with 0.9.6 that would be great! Thanks!
Since people seem to be sharing screenshots in this thread, maybe this is also a good opportunity to show how I set it up, how awesome AEL is with this:
(2018-11-04, 20:44)Aatos Wrote: [ -> ]Yes, it's the old SexyCirrus, however I've edited that too to be a bit more to my liking, so moving to 0.10.0 and to Krypton will be quite difficult. Maybe one day I have to since you keep adding great features, but would have to figure out how to move the skin first. In the meantime, if you can point me to the right direction to do something with 0.9.6 that would be great! Thanks!
Rufoo has published a mod of Mimic + SexyCirrus named Lyrebird, for Krypton and Leia. It's not yet as complete as SexyCirrus but he's actively working on it. You also have AEL Estuary Mod for Krypton. AEL Estuary Mod is very cheap compared with SexyCirrus but at least you have some decent views.
OK, if you want to modify AEL 0.9.6 this is what you will have to do:
1) Copy the
artwork from AEL master into your copy of AEL, in the same directory.
2) Have a look at the new AEL code that uses this artwork in the virtual launchers
here.
3) You have to modify AEL 0.9.6 in a similar way
here.
Also, I can make AEL 0.10.0 minimum Kodi version to run Jarvis, but you will lose some features, notably the extended select dialog when configuring artwork.
EDIT: I have updated the list of supported skins in the first thread, if you want to have a look. You can install Kodi Portable on a Windows machine for quick testing.
Mimic is a good skin. I too was a Jarvis user cause of SC. And rufoo.
With him adding some basic views to mimic it helps. But he is working on getting the other SC views into lyrebird.
Send him a PM here with What view you’d like inputted into LB. I’m sure he can get it up and running for you.
Hi @
Wintermute0110,
and first a hello as a new user on kodi.tv and thanks for your "retro" efforts - it seems awesome
- if i get it workin....
I am trying to use the actual master release from
https://github.com/Wintermute0110/plugin.program.AEL on my Shield 2017 with Android, after failing to get the 0.97 release running (i read about a hotfix in this thread from chrisism that fixes some call conventions for external emus on the shield, but it isnt for download anymore).
Nevertherelss I renamed it to plugin.program.AEL (please consider updating your README.md, coz it tells still plugin.program.advanced.emulator.launcher).
It installed correctly - as far as i can see (nor error popups) - on newest Android Kodi Beta 5.
But if i want to import a Launcher i get always this error in kodi.log:
20:00:27.438 T:156160713968 ERROR: GetDirectory - Error getting plugin://plugin.program.AEL/
20:00:27.438 T:155958113520 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.AEL/) failed
20:01:11.549 T:155953902832 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.SyntaxError'>
Error Contents: invalid syntax (main.py, line 869)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/addon.py", line 24, in <module>
import resources.main
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/resources/main.py", line 869
selected_option = dialog.select('Select action for Launcher {0}'.format(launcher.get_name()), launcher_options))
SyntaxError: invalid syntax
Do you have any ideas how to fix this or where to get a working release / hotfix ?
Cheers, SPo!
After removing the last bracket in the script main.py at line 869, i get this error the time i want to import a Launcher XML:
20:25:37.378 T:156080510192 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/resources/objects.py:4723: SyntaxWarning: import * only allowed at module level
def pairServer(self, pincode):
20:25:37.378 T:156080510192 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/resources/objects.py:4913: SyntaxWarning: import * only allowed at module level
def getCertificateBytes(self):
20:25:37.378 T:156080510192 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/resources/objects.py:4929: SyntaxWarning: import * only allowed at module level
def getCertificateKeyBytes(self):
20:25:37.526 T:156080510192 NOTICE: AML INFO : Execute migrations
20:25:37.540 T:156080510192 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: NewFileName instance has no attribute 'scanFilesInPathAsFileNameObjects'
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/addon.py", line 41, in <module>
resources.main.run_plugin(sys.argv)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/resources/main.py", line 277, in run_plugin
m_execute_migrations(last_migrated_to_version)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.program.AEL/resources/main.py", line 9978, in m_execute_migrations
migration_files = migrations_folder.scanFilesInPathAsFileNameObjects('*.py')
AttributeError: NewFileName instance has no attribute 'scanFilesInPathAsFileNameObjects'
