2019-04-12, 22:33
Hi, im looking for a way to play grim dawn on my Kodi setup Intel Nuc i5 HD5000. i installed AEL uploaded the unpacked game dir with correct exe version to the inten nuc ssd and added the exe as a new launcher for microsoft windows on ael, but when i try to run it i get :
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: ---------- Called AEL Main::run_plugin() constructor ----------
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: sys.platform "linux2"
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: Python version "2.7.15 (default, Feb 21 2019, 02:13:12) [GCC 8.2.0]"
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: __a_version__ "0.9.7"
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: sys.argv[0] "plugin://plugin.program.advanced.emulator.launcher/"
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: sys.argv[1] "18"
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: sys.argv[2] ""
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: sys.argv[3] "resume:false"
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: JSON {"id" : 1, "jsonrpc" : "2.0", "method" : "Application.GetProperties", "params" : {"properties" : ["name", "version"]} }
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: Response {"id":1,"jsonrpc":"2.0","result":{"name":"Kodi","version":{"major":18,"minor":1,"revision":"18.1-Leia","tag":"stable"}}}
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: JSON {"id" : 1, "jsonrpc" : "2.0", "method" : "Settings.GetSettingValue", "params" : {"setting" : "lookandfeel.skin"} }
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: Response {"id":1,"jsonrpc":"2.0","result":{"value":"skin.aura"}}
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL DEBUG: JSON RPC time 0.161 ms
2019-04-12 16:26:49.539 T:139694442608384 ERROR: AEL VERB : fs_load_catfile() Loading special://profile/addon_data/plugin.program.advanced.emulator.launcher/categories.xml
2019-04-12 16:26:49.541 T:139694442608384 ERROR: AEL DEBUG: command = "SHOW_ADDON_ROOT"
2019-04-12 16:26:49.541 T:139694442608384 ERROR: AEL DEBUG: Advanced Emulator Launcher run_concurrent() BEGIN
2019-04-12 16:26:49.541 T:139694442608384 ERROR: AEL DEBUG: _misc_set_AEL_Content() Setting Window(10000) property "AEL_Content" = "launchers"
2019-04-12 16:26:49.592 T:139694442608384 ERROR: AEL DEBUG: Advanced Emulator Launcher run_concurrent() END
2019-04-12 16:26:49.592 T:139694442608384 ERROR: AEL DEBUG: Advanced Emulator Launcher run_plugin() exit
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: ---------- Called AEL Main::run_plugin() constructor ----------
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: sys.platform "linux2"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: Python version "2.7.15 (default, Feb 21 2019, 02:13:12) [GCC 8.2.0]"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: __a_version__ "0.9.7"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: sys.argv[0] "plugin://plugin.program.advanced.emulator.launcher/"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: sys.argv[1] "-1"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: sys.argv[2] "?com=LAUNCH_STANDALONE&catID=root_category&launID=79c870d105b2c40fb4c968cbcbf1614b"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: sys.argv[3] "resume:false"
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: JSON {"id" : 1, "jsonrpc" : "2.0", "method" : "Application.GetProperties", "params" : {"properties" : ["name", "version"]} }
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: Response {"id":1,"jsonrpc":"2.0","result":{"name":"Kodi","version":{"major":18,"minor":1,"revision":"18.1-Leia","tag":"stable"}}}
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: JSON {"id" : 1, "jsonrpc" : "2.0", "method" : "Settings.GetSettingValue", "params" : {"setting" : "lookandfeel.skin"} }
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: Response {"id":1,"jsonrpc":"2.0","result":{"value":"skin.aura"}}
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL DEBUG: JSON RPC time 0.160 ms
2019-04-12 16:26:50.606 T:139694442608384 ERROR: AEL VERB : fs_load_catfile() Loading special://profile/addon_data/plugin.program.advanced.emulator.launcher/categories.xml
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL DEBUG: command = "LAUNCH_STANDALONE"
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL DEBUG: SingleInstance::__enter__() Lock not in use. Setting lock
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL DEBUG: Advanced Emulator Launcher run_protected() BEGIN
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() categoryID root_category
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() launcherID 79c870d105b2c40fb4c968cbcbf1614b
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() application "/storage/emulators/PC/Grim Dawn/Grim Dawn.exe"
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() apppath "/storage/emulators/PC/Grim Dawn"
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() app_basename "Grim Dawn.exe"
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() app_ext ".exe"
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() launcher name "Grim Dawn"
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() raw arguments ""
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL INFO : _run_standalone_launcher() final arguments ""
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL VERB : _run_before_execution() media_state_action is "Stop" (0)
2019-04-12 16:26:50.608 T:139694442608384 ERROR: AEL VERB : _run_before_execution() DO NOT suspend Kodi audio engine
2019-04-12 16:26:50.609 T:139694442608384 ERROR: AEL VERB : _run_before_execution() Toggling Kodi fullscreen DEACTIVATED in Launcher
2019-04-12 16:26:50.609 T:139694442608384 ERROR: AEL VERB : _run_before_execution() Pausing 500 ms
2019-04-12 16:26:51.108 T:139694442608384 ERROR: AEL DEBUG: _run_before_execution() function ENDS
2019-04-12 16:26:51.115 T:139694442608384 ERROR: AEL DEBUG: _run_process() arguments = ""
2019-04-12 16:26:51.115 T:139694442608384 ERROR: AEL DEBUG: _run_process() arg_list = []
2019-04-12 16:26:51.115 T:139694442608384 ERROR: AEL DEBUG: _run_process() exec_list = [u'/storage/emulators/PC/Grim Dawn/Grim Dawn.exe']
2019-04-12 16:26:51.115 T:139694442608384 ERROR: AEL INFO : _run_process() (Linux) Launching blocking process subprocess.call()
2019-04-12 16:26:51.148 T:139694442608384 ERROR: AEL ERROR: SingleInstance::__exit__() Unhandled excepcion in protected code
2019-04-12 16:26:51.148 T:139694442608384 ERROR: AEL DEBUG: SingleInstance::__exit__() Releasing lock
2019-04-12 16:26:51.151 T:139694442608384 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.OSError'>
Error Contents: [Errno 8] Exec format error
File "/storage/.kodi/addons/plugin.program.advanced.emulator.launcher/addon.py", line 39, in <module>
main.Main().run_plugin()
File "/storage/.kodi/addons/plugin.program.advanced.emulator.launcher/resources/main.py", line 270, in run_plugin
self.run_protected(command, args)
File "/storage/.kodi/addons/plugin.program.advanced.emulator.launcher/resources/main.py", line 371, in run_protected
self._command_run_standalone_launcher(args['catID'][0], args['launID'][0])
File "/storage/.kodi/addons/plugin.program.advanced.emulator.launcher/resources/main.py", line 7096, in _command_run_standalone_launcher
self._run_process(application.getPath(), arguments, application.getDir(), app_ext, non_blocking_flag)
File "/storage/.kodi/addons/plugin.program.advanced.emulator.launcher/resources/main.py", line 7501, in _run_process
retcode = subprocess.call(exec_list, stdout = f, stderr = subprocess.STDOUT, close_fds = True)
File "/usr/lib/python2.7/subprocess.py", line 172, in call
File "/usr/lib/python2.7/subprocess.py", line 394, in __init__
File "/usr/lib/python2.7/subprocess.py", line 1047, in _execute_child
OSError: [Errno 8] Exec format error
