I'm running AeonMQ5 1.6.3 and I have found a little graphic bug :
settings_button_large.png have some missing pixel in right bottom corner :
fixed :
When using default movie menu item (based on script.skin.widget properties), In Progress movies are displayed with little blue to black bar under poster :
But the same movie when using smart playlist custom menu item (based on script.randomandlastitems properties), this bar is missing for some movies :
Which property is used to display this progress bar (so I can check if my script return the good value) ?
And this progress bar is not linked to % played ? I mean all my movies get the same progress bar but don't have the same % played.
1 - I see nothing wrong here:
2 - Already fixed. Don't need any change in script:
(2013-11-22, 16:12)dodino Wrote: [ -> ]Define "Just Wait
Can't wait for this... but... Thanks a lot for your effort and for this incredible skin!
Version 1.7.4 has been sent to ronie for approval, but he must be very busy with XBMC Gotham at this time, so we can only wait.
alfredeneuman this is how the XBMC works. For each level there is a new type of view.
Anybody else seeing 100% CPU usage just highlighting/selecting a movie? Using XBMC 12.2.
Aeon MQ 5 - 1.7.4 available - Frodo version. Gotham version still waiting for approval.
Changelog:
Added: Media Flag for Drive Storage - Support up to 20 drivers. (use tag in drive like as "hd01, ext01, volume01, hd02, ext02, volume02...")
Added: Greek Fonts. (thanks to CutSickAss)
Added: Hebrew Fonts. (thanks to Idan)
Added: Auto instalation for Cinema Experience script.
Added: Widgets popup (play movie) - Option to play by Cinema Experience.
Added: TvShow Poster in Pause Screen.
Added: Sets View - Available for movies.
Added: System Date in Main Menu/Library.
Improved: Sets View - New layout for use in mixed library, movie sets and single movies are supported.
Improved: Rework in selector recent/random/in progress to avoid skin crash on some systems.
Changed: Weather popup only will be appear if have one weather service active.
Fixed: Change view cause skin freeze in some cases.
Fixed: Cinema Experience/Video Info - Command to run the addon.
Fixed: Overlapping between Smart Submenu and RSS bar.
Fixed: Set the option 'Smart Kiosk' make top menu open up automatically in some cases.
Fixed: Video Playlist widgets - Recent items show indication '0%' if selected.
Fixes: During Media Scan process, if get out of Home screen, the top popup is closed, and does not open again.
Fixed: Gotham Version - Compatible to latest changes in XBMC Alpha.
Nice, going to test the new version tonight
. Thank you MQ!
I'm sorry but I see this: "Aeon MQ 5 - 1.7.4 available" but I can not find a download link............can someone point it out to me?
Available in official frodo repository. in XBMC, go to settings-> addons -> get addons-> skin -> Skin Aeon MQ 5.
(2013-11-22, 21:59)Wanilton Wrote: [ -> ]Available in official frodo repository. in XBMC, go to settings-> addons -> get addons-> skin -> Skin Aeon MQ 5.
I did that but the version wasn't 5-1.7.4............it was 5-1.6........I do not understand?
have no idea how to add a submenu under a main menu
iv created a new main menu option
youtube
now under that in a sub menu i want to throw gametrailers in there how do i do this??
robert1901, it´s possible in skin, but your example is too bad, no support for piracy addon here, sorry, see forum rules.
(2013-11-22, 22:56)Wanilton Wrote: [ -> ]@robert1901, it´s possible in skin, but your example is too bad, no support for piracy addon here, sorry, see forum rules.
ok fixed if yo know can you please help
Please guys...we would love the gotham version approved too............
