Is there a option to change the music visualization screen. I do no like the little overlapped images in the background.
Yes, keisuji, only need press M (in fullscreen), find settings (enter) and configure for not show mobile.
(2013-11-23, 10:41)nupi Wrote: [ -> ]I am seeing 5.7.4 on Gotham but it is marked as incompatible due to missing dependencies?
Never mind, kicking out SuperRepo and some other zombie repos fixed it...
Using Frodo repositories in Gotham kinda asks for problems with dependencies. Use the new Gotham repo if you need other addons too and let me know when it does not work as expected.
[/quote]
How to get a 3D cover MQ5. I tested different file names but still can not see 3D cover ..; ( Skin Ace 3D displays without a problem
What does it depend?
I'm sorry for the mistakes and not understood a word I do not know English ...
I'm also using MQ5 as skin for my mobile device.
Only issue i have is that you can't navigate properly in certain situations, configure theme, select different views or open submenu's since my mobile doesn't have a mouse/keyboard.
So I ran across this handy tool
ShareKM, very handy for initial setup.
Maybe it's useful for someone else who is in the same situation.
(2013-12-09, 11:45)Poland Wrote: [ -> ]
[/quote]
Avatar (2009).3dbd.mkv
should work.
(2013-12-08, 22:32)BartOtten Wrote: [ -> ] (2013-11-23, 10:41)nupi Wrote: [ -> ]I am seeing 5.7.4 on Gotham but it is marked as incompatible due to missing dependencies?
How do you make sure you are using the new Gotham repo?
(2013-12-09, 12:00)schumi2004 Wrote: [ -> ]I'm also using MQ5 as skin for my mobile device.
So I ran across this handy tool ShareKM, very handy for initial setup.
Schumi2004, go to skin settings, general settings, active option optimize skin for touch-screen (a help tab will apper)
(2013-12-09, 13:41)T800 Wrote: [ -> ] (2013-12-09, 11:45)Poland Wrote: [ -> ]
should work.
[/quote]
Already named as movies 3dbd.iso 3DBD etc. Still experimenting with the names of movie files. I have XBMC 13 Gotham Alpha 9. Other users managed to get a 3D cover I still can not ...
Provide a link to the new repository Gotham
(2013-12-09, 14:24)Poland Wrote: [ -> ]Already named as movies 3dbd.iso 3DBD etc. Still experimenting with the names of movie files. I have XBMC 13 Gotham Alpha 9. Other users managed to get a 3D cover I still can not ...
If you're using folders, make sure they have .3DBD in them. Then it should work.
For 3D file's name.I used to add "tag" for each 3D format like...
-"Movie name".3D.HSBS.Bluray."extention" for SBS-3D (e.g. Up (2009).3D.HSBS.BluRay.x264 - 1.5GB - YIFY.mkv)
-"Movie name".3D.HOU.Bluray."extention" for HOU-3D (e.g. Avatar 2009 1080p.3D.HOU.BluRay.x264 ac3 vice.mkv)
Now it should be like this
Hi
Is it possible to set separate fanart for submenu items
(2013-12-09, 15:15)Wanilton Wrote: [ -> ]Poland, here addon gotham repo:
http://mirrors.xbmc.org/addons/gotham/
Page does not work, I have to wait
I want to install everything from scratch as in the link you provided .... I want to install the XBMC 13 Gotham Alpha 10 But the problem with the site is ...
Yes, official addon xbmc repo currently experiencing issues, wait fix by team.
(2013-12-09, 13:49)Wanilton Wrote: [ -> ] (2013-12-09, 12:00)schumi2004 Wrote: [ -> ]I'm also using MQ5 as skin for my mobile device.
Damm, how could i forgot.
When enabled it still isn't 100% perfect for tablets/touchscreens. For example Theme's, you can't scroll to bottom to select custom theme.
Is there also a way to change this background?
In some situations your getting this "default" background but when using colored themes it's kinda strange/ugly.
