Full Version: [RELEASE] Aeon MQ 5
I'll try that. Thing is, my 3d folder is inside a folder.
Example,
Movies folder. Inside that I have "Bluray" and "3D" folders
(2013-12-18, 22:12)Wanilton Wrote: [ -> ]Maniac, have one widget in live tv item in main menu, with info about tv shows live today.
Yeah, is that the "Next Aired Show" widget? Even tho I do have that addon I never see the widget.
I don't see how that addon\widget is relevant for the LiveTV menu item. I was thinking more about what schumi wrote, EPG-releated widget for, say, the last 5 visited channels or favourite channels.
But I guess you'll need some sort of script for that, in order to logg somewhere what channels have been visited\opened. I don't think XBMC loggs this for you, like recent moves\episodes?
(2013-12-18, 22:25)jjmucker Wrote: [ -> ]I'll try that. Thing is, my 3d folder is inside a folder.
Example,
The only reason I suggested 'movies.3DBD' is so that windows will let you use the dot.
You could use anything in theory, as the skin will only take note of the .3DBD
Hi all,
I am having jerky picture playback and I can only get 2.0 audio, no dolby HD or DTS sound.
I have set up everything in a Windows to make sure my amp is getting the correct feed. I can't find where to check the Wasabi settings in the skin though, I was wondering might that help, and could anyone point me in the right direction. I basically can't find where System settings menu is in MQ5?
Or could there be any other reason for the jerky playback and lost audio?
Do you get this problem also with the default skin ?
If yes then it has nothing to-do with this skin.
Post in the right topic and provide a Debug log (wiki)
(2013-12-19, 23:18)TRaSH Wrote: [ -> ]Do you get this problem also with the default skin ?
I wasn't able to change the skin to test, but I figured it out.
Problem solved, it was a sound setup problem, and apologies.
Anyone has an idea on how to change default view for every page/addon you visit by default?
For example, when using xbmctorrent addon and you go to next page in addon you will be presented default list view again unless you change it.
I would like to see an option/possibility to have right list view enabled by default in all cases unless i change it manually.
Is such possible?
@shumi2004
Yep, can be done by editing myvideonav.xml
Find the line with
<views>51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68</views>
and replace by
<views>59,52,53,54,55,56,57,58,51,60,61,62,63,64,65,6.6,67,68</views>
Number represent a view id. 59 is right list id. You have to put it in first postion in the list.
Then you have to delete ViewModes4 database in /.../xbmc/userdata/database/
(2013-12-20, 10:31)GuiZ Wrote: [ -> ]@shumi2004
Find the line with
and replace by
Thanks, works perfect.
@Marcos/Wanilton, is it possible to make this a configurable item in skin settings?
Aeon MQ 5 - 1.9.0 available - Frodo and Gotham
Changelog:
Changed: Extrafanart for Music in MainMenu - To show is necessary go to Music Menu/top menu/collection/show artist-album art/ and define root path (music path)
Fixed: Extrafanart in Main Menu - Skin shows wrong extrafanart for content that not have extrafanart.
Fixed: My Menu - Item number 12 appears twice.
Fixed: Gotham version/Available subtitles are not displayed after searching.
Fixed: Overlapping in Video FullScreen between furniture and settings OSD if use shortcut in remote control.
Happy Christmas and a happy new year to all users.
@shumi, I prefer to leave the skin as it is.
In Gotham I read version 5.8.0, is that correct?
Maniac, wait for version 5.9.0, soon is available too.
(2013-12-20, 20:36)MarcosQui Wrote: [ -> ]Fixed: Extrafanart in Main Menu - Skin shows wrong extrafanart for content that not have extrafanart.
Hello
Many thanks for the new skin update! Big Grin
However after updating the skin and rebooting I am still having the same issues with extrafanart and it doesn't appear to be fixed. ?
"Eddy Grant" info page, showing incorrect background fanart of artist "Grimes" which is currently playing.
On the main XBMC menu whilst playing "Eddy Grant" it shows the incorrect fanart of the previously played artist which was "Grimes'.
Also in the full screen view when using the OSD setting ARTIST FANART + VIEWING the incorrect artist fanart is also shown.
"Eddy Grant" artist has no extrafanart folder present
"Grimes" artist does have an extrafanart folder present
Many thanks
cw-kid, do you select path for music folder in collections, look post MarcosQui, it´s necessary, you don´t comment if follow this instruction.
Here are the settings:
These settings were already defined before the V1.9.0 update so I did not have to change anything here?
Thank you.
