(2019-05-09, 18:45)bennyhanna Wrote: [ -> ]Endgame poster...
Quote:Alita: Battle Angel
Really great great work!
Your skill is very good!
Since @
mouflo is retired atm, we really have a lack of talented content creators here.
(2019-05-27, 12:23)djdirty60 Wrote: [ -> ]how can I solve this
Every skin is handling animated artwork in a different way.
You get more likely support when ask in the skin forum thread of the skin you use.
Thanks for the kind words...
Captain Marvel
For the first 2 John Wick movies there are really great Animated Posters made:
https://www.kyradb.com/movie/46/images
https://www.kyradb.com/movie/47/images
Maybe we can continue the tradition and there will be one for the third movie as well.
I looked a little bit cause we want as always use the "main poster" as main source:
This poster IMDB and TMDB is using as main poster:
But this motive is most downloaded and highest rated on fanart.tv:
___
Both looking good, a also cannot make a decision wich is fitting better, and on both there are possibilities for animation effects,
on the first with sun to make some lens flare bling bling stuff effects (there is already i little sun lens flare reflection in the poster),
or on the second with the neon "gloriole" make some neon bling bling pulse effect.
Optional also a really discreet smoke effect of the gun but in my opinion this would fit only on the second motive (but unfortunately the logo will covers the weapon again)
As mostly it's more comfortable the use the textless poster (keyart) as source and put the posterlogo afterwards back in the same position.
logo sources:
1st:
https://fanart.tv/api/download.php?type=...§ion=3
2nd:
(2019-05-30, 18:32)Captain_Pike Wrote: [ -> ] (2019-05-27, 12:23)djdirty60 Wrote: [ -> ]how can I solve this
it doesn't work with any skin
(2019-05-31, 08:58)djdirty60 Wrote: [ -> ] (2019-05-30, 18:32)Captain_Pike Wrote: [ -> ] (2019-05-27, 12:23)djdirty60 Wrote: [ -> ]how can I solve this
Im trying to up my game and learn how to do these Animated Posters,ive concentrated on making boxsets for Emby for 4 years. But do not mind helping out the kodi team if i can.
(2019-05-31, 08:58)djdirty60 Wrote: [ -> ]it doesn't work with any skin
Are your animated artworks saved locally or on a network location, like a NAS. Animated artworks only work when saved locally.
https://kodi.wiki/view/Artwork_types#Animated_artwork
It may also be affected by certain settings in your advancedsettings.xml.
My take on John Wick 3...
Not totally like the official poster,
There are times I will take certain creative liberties that help facilitate what
I imagine the animation should look
like.
EDITS: smoothed out statue arm animation....and added textless
Congratulations Bennyhanna, thank you for taking the relay. I was not very present the last weeks but I did not stop so far. I will be operating this week so after I will have time to convalescence at home to be able to remake a little.
nice to see you back again @
mouflo
Just messing around with a few ideas for Dark Phoenix...
it will most likely change.
Any thoughts?
