2015-10-13, 02:16
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
2015-10-13, 02:20
(2015-10-13, 02:16)Wanilton Wrote: [ -> ]only need overwrite previous file Textures.xbt with new file.
Still not working
When i got Add-on/Install from Zip file,i get this error :
Video
Failed to install Add-On From the Zip
Can you please upload Aeon Mq6 Beta 2.4.0
2015-10-13, 02:21
I don´t know, try unzip skin manually on addon folder (userdata).
Remember you are using skin for helix.
2015-10-13, 02:25
(2015-10-13, 02:21)Wanilton Wrote: [ -> ]I don´t know, try unzip skin manually on addon folder (userdata).
That doesn't work!!
Any other solution?
2015-10-13, 05:30
(2015-10-12, 16:58)movie78 Wrote: [ -> ](2015-10-12, 16:39)Wanilton Wrote: [ -> ]I use MQ6 version 2.9.0.
How you test? what you do for test?
If you have teamviewer, send me ID and Password via private message, I check for you.
I think Aeon MQ 6 2.4.0 beta is not compactible with Jarvis,How do i get the version that you are using.
Aeon MQ 6 2.9.0?
I have verified this works using 5 different boxes. Install Helix 14.2, download/setup the skin how you want. Download/install latest jarvis nightly. Skin loads fine with all settings!
*EDIT* Obviously you can't see any new windows that Jarvis uses as they aren't physically there in the skin. I can't speak for PVR, but everything else works just fine!
2015-10-13, 08:47
Aeon MQ 6 2.9.0 is only available via donation.
2015-10-13, 15:28
(2015-10-13, 05:30)Fail$tyle420 Wrote: [ -> ](2015-10-12, 16:58)movie78 Wrote: [ -> ](2015-10-12, 16:39)Wanilton Wrote: [ -> ]I use MQ6 version 2.9.0.
Aeon MQ 6 2.9.0?
This what i did to get it to semi-work.
I uninstall Jarvis
Install Isengard
Load the Aeon MQ 6 2.4.0 Skin
Install Jarvis
The problem i am having now are:mouse it missing and all the menu doesn't have solid tab.
2015-10-13, 19:27
(2015-10-13, 15:28)movie78 Wrote: [ -> ](2015-10-13, 05:30)Fail$tyle420 Wrote: [ -> ](2015-10-12, 16:58)movie78 Wrote: [ -> ]I think Aeon MQ 6 2.4.0 beta is not compactible with Jarvis,How do i get the version that you are using.
Aeon MQ 6 2.9.0?
I uninstall Jarvis
Install Isengard
Install Jarvis
LOL, just do as I said and you will have a functioning MQ6 in latest Jarvis nightly. I just did it again about 15 minutes ago for another computer. Uninstall any versions you have, install helix 14.2. Install MQ6 and setup everything the way you want. Exit and install latest Jarvis nightly ontop of your current 14.2 install. Start kodi and it will look EXACTLY the same as Helix.
2015-10-13, 21:17
(2015-10-13, 19:27)Fail$tyle420 Wrote: [ -> ](2015-10-13, 15:28)movie78 Wrote: [ -> ](2015-10-13, 05:30)Fail$tyle420 Wrote: [ -> ]I have verified this works using 5 different boxes. Install Helix 14.2, download/setup the skin how you want. Download/install latest jarvis nightly. Skin loads fine with all settings!
I uninstall Jarvis
Install Isengard
Install Jarvis
Thanks for your help,will try your method tonight.
2015-10-14, 00:33
(2015-10-13, 21:17)movie78 Wrote: [ -> ](2015-10-13, 19:27)Fail$tyle420 Wrote: [ -> ](2015-10-13, 15:28)movie78 Wrote: [ -> ]This what i did to get it to semi-work.
I uninstall Jarvis
Install Isengard
Install Jarvis
Definitely let me know!
2015-10-14, 05:09
(2015-10-14, 00:33)Fail$tyle420 Wrote: [ -> ](2015-10-13, 21:17)movie78 Wrote: [ -> ](2015-10-13, 19:27)Fail$tyle420 Wrote: [ -> ]LOL, just do as I said and you will have a functioning MQ6 in latest Jarvis nightly. I just did it again about 15 minutes ago for another computer. Uninstall any versions you have, install helix 14.2. Install MQ6 and setup everything the way you want. Exit and install latest Jarvis nightly ontop of your current 14.2 install. Start kodi and it will look EXACTLY the same as Helix.
This is what it looks like using your method.
Same situation.
Mouse is missing and all solid tab gone.
2015-10-14, 19:27
(2015-10-14, 05:09)movie78 Wrote: [ -> ](2015-10-14, 00:33)Fail$tyle420 Wrote: [ -> ](2015-10-13, 21:17)movie78 Wrote: [ -> ]Thanks for your help,will try your method tonight.
Same situation.
Then you are doing something wrong. I literally did EXACTLY what I already told you to do and it works lol. I just formatted my pc to install Windows 10 Insider Preview build last night and for the 8th time, those steps have worked to get MQ6 in Jarvis. Maybe it's because I've started fresh every time? Make sure you delete your userdata folder before installing Helix 14.2. If you still can't get it to work, let me know. I'll make a video for you, but I am not doing anything other than what I have already posted.
2015-10-14, 19:59
(2015-10-14, 19:27)Fail$tyle420 Wrote: [ -> ](2015-10-14, 05:09)movie78 Wrote: [ -> ](2015-10-14, 00:33)Fail$tyle420 Wrote: [ -> ]Definitely let me know!
Same situation.
Let me see the video?
It is working,as you can see on the image above,that the only issue that i am having.
The mouse movement and solid image underneath the letters.
2015-10-14, 20:12
(2015-10-14, 19:59)movie78 Wrote: [ -> ](2015-10-14, 19:27)Fail$tyle420 Wrote: [ -> ](2015-10-14, 05:09)movie78 Wrote: [ -> ]This is what it looks like using your method.
Same situation.
Ok, I will make a video for you. It's working yes, but it should look EXACTLY like it does on Helix. Let me download a recording app and I'll get back to you later today. It probably won't be until late PM (In california here).
2015-10-14, 21:05
Ok, so I was sitting here smoking and I couldn't wrap my head around why yours wouldn't work. I went ahead and did everything I told you with a fresh install and I got the same results as you! Now, I know the ONLY thing I changed that I did NOT tell you was that I don't download aeon everytime. Mine is heavily modified, but structurally (folderwise) there isn't any difference. I then remembered that I extracted the textures.xbt file in mine. I went ahead and extracted the newly downloaded textures.xbt file, started kodi with no issues! So, basically here are the new steps lol:
1. Install Helix 14.2
2. Install Aeon MQ6 and all dependencies
3. Install latest jarvis nightly
4. Download and run texture tool: http://forum.kodi.tv/showthread.php?tid=201883
5. Extract textures.xbt from: C:\Users\YOURUSERNAMEHERE\AppData\Roaming\Kodi\addons\skin.aeonmq6\media\
6. Place newly extracted textures file into the same folder: C:\Users\YOURUSERNAMEHERE\AppData\Roaming\Kodi\addons\skin.aeonmq6\media\
7. Delete textures.xbt
8. Run kodi
*EDIT* If you haven't changed anything since we talked last, you might be able to just do steps 4-8 and be all good. Let me know how it goes!
Screenshot
8. Run kodi
Screenshot
