With v44 I am getting tmdbhelper errors and does not want to play my local files from Popular or trending. I reset my device and installed everything and started to give errors once I set the trailers to manual. Does anyone else have this issue or is it just me?
I tried to delete tmdbhelper from users addons but also no succes.
@nfm886 I sent you by message my log file as well.
(2021-09-04, 21:35)sasquatchjaques Wrote: [ -> ]Hi loving the skin so far - in regards to the PVR would you be able to add the now playing widget (as shown in emburary skin) and maybe an option to choose the individual pvr groups as a widget choice rather then just all groups ??
No worries if not
Thanks for everything
Do you mean that "On Now" widget in PVR Hub? I will think of it.
[/quote]
[/quote]
That’s the one 👍🏻
Could you enter an option to include “custom widgets” I’ve seen it on a few skins - I think o could use this to identify individual channel groups
The trailers are not working correctly. They show something different than actual highlited movie or TV Show. Happening since v.44..
(2021-09-05, 17:31)Rijs43 Wrote: [ -> ]Hi,
Hi, thanks. I will look into it later. Now I'm working on something else in the skin
btw. Is it happening when you have disabled manually played trailers or by clicking on it?
(2021-09-05, 18:03)AudigierSanchez Wrote: [ -> ]Hi Heppen I have seen that there is no option to see the synopsis in large could you implement something like that
https://images.app.goo.gl/eRBPJ69ptQAosd9R6
Heh, actually I added this today
It will be available with today's update in the evening.
Is their a recommended addon for "live tv" to use.
I'm not after free channels, i have a provider, i just would like to incorporate everything into one place on this kodi skin.
Apologies if this is not aloud to be asked here.
(2021-09-05, 18:23)Robertsond1987 Wrote: [ -> ]Is their a recommended addon for "live tv" to use.
I'm using IPTV Simple Client. It just works and for me have everything I need.
(2021-09-05, 18:36)nfm886 Wrote: [ -> ] (2021-09-05, 18:23)Robertsond1987 Wrote: [ -> ]Is their a recommended addon for "live tv" to use.
Thanks 👍😉
(2021-09-05, 17:46)nfm886 Wrote: [ -> ] (2021-09-05, 17:31)Rijs43 Wrote: [ -> ]Hi,
In both options, see Money Heist for example in Popular widget. I have also noticed that most of the times the first click gives No Trailer message, after hitting again it starts the trailer.
Hooe this can be fixed.
Update will be probably today in the evening. I'm working on "Flix Spotlight" view, this is how it looks so far:
https://streamable.com/brbq14
There is still some bugs and things to complete, I hope it will be ready to push today
(2021-09-06, 11:10)nfm886 Wrote: [ -> ]Hi,
Update will be probably today in the evening. I'm working on "Flix Spotlight" view, this is how it looks so far: https://streamable.com/brbq14
Wooh. Very nice
Amazing and very clean!
