(2021-12-11, 18:56)Mongoose18 Wrote: [ -> ]Thanks, I'm just leaving for work. I'll get a screenshot for you tomorrow. And yes to flix spotlight triggered by back button. Otherwise everything is working great.
I will see if it's easy to fix. If yes I will do it but can't promise anything. Maybe tomorrow I will find a couple of minutes
Thankyou appreciate your time.
Switched to Cosmic after finally updating to Matrix (previously used AuraMod), and am thus far enjoying its simplicity.
A couple of questions though, the latter two being possible feature additions in the future.
- What is the difference between Default, Curial and Flat themes?
- Re widgets - is it possible when setting the "limit items" option to "10", to also have the "Next Page" option at the end of the displayed widget list? Right now it only shows when either the value is left blank or using "25".
- When turning on "Enable Trailers in background" and turning on "Manually start trailer", is it possible to get another option added that can toggle whether using the "select button" plays the trailer or takes you into the shows season page (as it does when enabled trailers option is turned off) when selecting a show from a widget? Would like to have the trailer feature on, but change how it's manually controlled a little.
it would be possible to install a video when starting kodi ?
and i noticed when i start kodi the submenu of the first entry always opens automatically
but all in all great skin
Mongoose18
Two things...
- When you post screenshots, please try to avoid the "VerticalVideoSyndrome" (VVS) on your phone. We're not interesting in the layout of your living room, but only the contents of your Kodi screen(s).
- Speaking of... We do not welcome Kodi setups that have one or more video piracy add-ons installed. We have a zero-tolerance stance on that. Kindly read again our
forum rules (wiki) and its
piracy policy (wiki) before posting again.
(2021-12-16, 23:05)jjd-uk Wrote: [ -> ]as Kodi has a built in screenshot facility
Yes and no... LibreELEC has a non-working printscreen function in Kodi 19 due to the new video driver package on e.g. the Raspberry Pi 4. Not sure about its "Generic" release though.
(2021-12-11, 19:12)Mongoose18 Wrote: [ -> ]Quick screenshot
Hey,
Sorry, it took long time to response but I was busy.
Unfortunately I can't reproduce the issue. Just everything seems to works ok:
https://imgur.com/WL21Bue ,
https://imgur.com/gHegVsm
Where you widgets points? Is it local library, some addons or what? Maybe there is issue with an addon and not with the skin?
I refreshed the skin and since it hasn't happened again. Thankyou for your help though.
(2021-12-23, 18:40)Mongoose18 Wrote: [ -> ]I refreshed the skin and since it hasn't happened again. Thankyou for your help though.
Uff, glad to hear and sorry again for late reply
I am having issues installing your skin on my Apple TV 4K 2021.
When opening kodi, on start up, I get an error message "check log for more info". once Kodi launches its a blank black screen, and can't do anything...
(2021-12-25, 04:10)ACEY777 Wrote: [ -> ]I am having issues installing your skin on my Apple TV 4K 2021.
Sounds like an issue with skinshortcuts... You can try to revert back to v1.1.5:
https://mirrors.xmission.com/kodi/addons...-1.1.5.zip
Sorry if it's me being an idiot, but is there a way to make the trailer stop when moving to the next movie/show on a widget?
I know there was an option on the Arctic skin.
At the minute, the trailer continues until it ends.. and then a new trailer can start.
Thanks in advance.
