Full Version: Cosmic
I know that you're too busy to work on Cosmic right now, but I've noticed a few issues when using Horizontal home layout. I'll address them now, so you're aware that they exist.
- The InfoDialog does not usually open. When disabled, selecting a widget often lags and sometimes does not work.
- Trailers do not play from the InfoDialog/Spotlight in either home layout.
- The "Enable blur" option does not allow for selection.
- The search list does not work.
- Auto close OSD controls does not work.
I have a few additional feature suggestions in mind for Horizontal home layout that would be really great as well.
- Add widget labels directly above the rows.
- Add option for Text only menu style in horizontal.
- Add the same layout as Prime with ClearArt at the top left with the option for FanArt and trailers in the top right, but with the same spacing of widget rows (shows the top of row below) and no box color.
- Add option to display which apps the video is available on/watch options (Netflix, Hulu, etc.) and the option to select which apps to display from. I know that AH2 has this feature, but I'm not sure where they pull this info from. My best guess is Trakt because they do provide this info on their website, but IMDb also has this info with different results.
Before I forget, I'd also like to suggest adding the option to increase the size of the OSD controls.
Is it possible to make this skin look like Disney+?
Hey guys,
I'm using Kodi+Cosmic with a raspberry pi 4. I love the look and feel! Sadly I'm getting huge cpu spikes, idle load of ~25% and frequent crashes. Anyone else?
I'm using Kodi 20.1 (LibreELEC 11.0.1)
(2023-06-16, 15:29)Raistlin666 Wrote: [ -> ]Hey guys,
the developer is on hiatus so this isn't being worked on currently - https://forum.kodi.tv/showthread.php?tid...pid3136257
(2023-06-16, 15:38)jepsizofye Wrote: [ -> ]
I think the skin is not going to have more support or development, the repository does not work and the github page no longer exists.
(2023-08-25, 16:55)zecabra Wrote: [ -> ]
you would be quite right https://github.com/heppenowski/ is no longer working
i wonder if the OP or a mod would see fit to set the status of this thread to Deprecated or add a [No Longer Maintained] flag to the title
can anybody share latest version? im still on ver 1.0.19
I really like this skin but looks like its development its over
can't update
(2023-08-27, 23:18)GreGORE Wrote: [ -> ]can anybody share latest version? im still on ver 1.0.19
can't update
I found this page on Github with the version 1.0.63
https://github.com/wreckshot/skin.cosmic
Heppen
Do you continue your work on Cosmic, Blue twilight skin?
(2023-09-16, 12:15)chitridang Wrote: [ -> ]Heppen
The answer is simply no. The reason is there: https://forum.kodi.tv/showthread.php?tid...pid3166209
I'm done with skinning for a while.
Does the skin still work well despite stopping development? On light devices?
Where can i download or link to set this in kodi?
Good morning,
I know that the development of this skin is stopped but do you know how to reactivate Kodi Favorites when the skin is under Kodi 21 rc 2 ?
Thanks to my savior
If I have free time I will update the skin a little bit.. It's so close to the look of Titan Bingie mod. I have a few ideas.. It's not a sure thing though..
