I'll make the addon less verbose later.
edit:
removed the log entries for demux packets in the development version. will backport it to the dharma-pvr branch later.
dushmaniac Wrote:I'll make the addon less verbose later.
That would be perfect. The log shouldent wright everything in the future I think. When you fore example play a movie ore tvshow it dont log anything exept when something fails.
I am using tvheadend now but i got very choppy picture on some of my channels. How can i see how good signal i have from my tv-network?. I wonder if a RF amplifier could help.
go to the tvheadend web interface and go to configuration -> tv adapters and select your adapter. enable "monitor signal quality", click save and go to the multiplexes tab. could take a bit of time till all muxes are updated.
dushmaniac Wrote:go to the tvheadend web interface and go to configuration -> tv adapters and select your adapter. enable "monitor signal quality", click save and go to the multiplexes tab. could take a bit of time till all muxes are updated.
Thanks. I have bad signal on few of them.
ASRock ION330HT setup from XBMC Live (XBMC Freak version 9.11.14). In the meantime upgraded to Dharma.
Live TV support via ppa:lars-opdenkamp/xbmc-pvr with TVheadend and USB-DVBS2 device Tevii S660
Folks,
I have Live TV in the above combination working however I have to boot twice.
When I power up all devices the first time XBMC (tvheadend) tells me "no device present".
When I power cycle XBMC (leaving the Tevii with power!) it comes up properly.
I captured an "uname -a", "lsusb", "dmesg | grep usb" output into two files to compare the differences. Here it is:
xbox@XIon:~$ diff Tev1.txt Tev2.txt
2c2
< Bus 001 Device 006: ID 9022:d660
> Bus 001 Device 005: ID 9022:d660
13a14
> usb 1-6: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 2
35d35
< usb 1-6: USB disconnect, address 5
38,39c38
< dvb-usb: MAC address reading failed.
< dvb-usb: no frontend was attached by 'TEVII S660 DVBS2 USB2.0'
> dvb-usb: MAC address: 00:18:bd:5c:4a:f0
44,57d42
< dvb-usb: TEVII S660 DVBS2 USB2.0 successfully deinitialized and disconnected.
< usb 1-6: new high speed USB device using ehci_hcd and address 6
< usb 1-6: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 2
< usb 1-6: configuration #1 chosen from 1 choice
< dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in cold state, will try to load a firmware
< usb 1-6: firmware: requesting dvb-usb-teviis660.fw
< dvb-usb: downloading firmware from file 'dvb-usb-teviis660.fw'
< dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in warm state.
< dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
< dvb-usb: MAC address: 00:18:bd:5c:4a:f0
< input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:04.1/usb1/1-6/input/input9
< dvb-usb: schedule remote query interval to 150 msecs.
< dvb-usb: TEVII S660 DVBS2 USB2.0 successfully initialized and connected.
I spot the message "MAC address reading failed" during the first boot sequence, but have neither an idea why this happens nor how to overcome this.
While working on my Sheevaplug Debian system I ran across the following
blog entry, but I don't think my device is as spoiled as this?!
why wouldn't it show the same behaviour as the one on the page you linked? it is the same device, isn't it?
I've installed tvheadend as a replacement to mythtv and I must say dushmaniac had done a sterling job, it really come along way in the last few months.
I have really quick channel changes, smooth playback, superb quality!
I have modifeld the keymapping to suit my needs and I'm really enjoying it.
A couple of things I'm not sure on:
I can't cancel timers.
I can't properly delete recordings from within xbmc
Pause, rewind live tv not working.
Any way to schedule season pass or multiple recordings from within xbmc.
Search from within xbmc. Find similar works but not direct searches.
Using the tvheadend webserver from an ipad is difficult as the drop down boxes can't be scrolled.
All in all it's very useable now and I am actually concidering switching to use it full time.
I can't believe how well remote frontend stream and how fast the channel changes are!
Thanks to everyone who works on the pvr stuff, it's really coming to fruition now and looks very promising for the future.
If anyone can offer advice to my above points I would appreciate it.
dushmaniac Wrote:why wouldn't it show the same behaviour as the one on the page you linked? it is the same device, isn't it?
IMO not exactly!? As I read his blog his devices' FW got erased and "ever since the device was not being recognized as 'tevii s660' anymore but only its basic circuit board "EZ-USB""
Mine still shows the proper device id and product id, also during the first boot sequence. But TVHeadend doesn't seem to find it until the next reboot.
1st boot sequence
Linux XIon 2.6.31-22-generic #70-Ubuntu SMP Wed Dec 1 23:51:13 UTC 2010 i686 GNU/Linux
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 004: ID 05e3:1205 Genesys Logic, Inc. Afilias Optical Mouse H3003
Bus 002 Device 003: ID 0518:0001 EzKEY Corp. USB to PS2 Adaptor v1.09
Bus 002 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
[ 0.480147] usbcore: registered new interface driver usbfs
[ 0.480147] usbcore: registered new interface driver hub
[ 0.480148] usbcore: registered new device driver usb
[ 1.432198] usb usb1: configuration #1 chosen from 1 choice
[ 1.490150] usb usb2: configuration #1 chosen from 1 choice
[ 1.969535] usb 1-6: new high speed USB device using ehci_hcd and address 5
[ 2.104828] usb 1-6: configuration #1 chosen from 1 choice
[ 2.420040] usb 2-1: new full speed USB device using ohci_hcd and address 2
[ 2.820370] usb 2-1: configuration #1 chosen from 1 choice
[ 3.124035] usb 2-3: new low speed USB device using ohci_hcd and address 3
[ 3.373378] usb 2-3: configuration #1 chosen from 1 choice
[ 3.394397] usbcore: registered new interface driver hiddev
[ 3.401712] input: Composite USB PS2 Converter USB to PS2 Adaptor v1.12 as /devices/pci0000:00/0000:00:04.0/usb2/2-3/2-3:1.0/input/input3
[ 3.401859] generic-usb 0003:0518:0001.0001: input,hidraw0: USB HID v1.10 Keyboard [Composite USB PS2 Converter USB to PS2 Adaptor v1.12] on usb-0000:00:04.0-3/input0
[ 3.410970] input: Composite USB PS2 Converter USB to PS2 Adaptor v1.12 as /devices/pci0000:00/0000:00:04.0/usb2/2-3/2-3:1.1/input/input4
[ 3.411159] generic-usb 0003:0518:0001.0002: input,hidraw1: USB HID v1.10 Mouse [Composite USB PS2 Converter USB to PS2 Adaptor v1.12] on usb-0000:00:04.0-3/input1
[ 3.411206] usbcore: registered new interface driver usbhid
[ 3.411213] usbhid: v2.6:USB HID core driver
[ 3.681045] usb 2-5: new low speed USB device using ohci_hcd and address 4
[ 3.896419] usb 2-5: configuration #1 chosen from 1 choice
[ 3.906697] input: USB Mouse as /devices/pci0000:00/0000:00:04.0/usb2/2-5/2-5:1.0/input/input5
[ 3.906881] generic-usb 0003:05E3:1205.0003: input,hidraw2: USB HID v1.10 Mouse [USB Mouse ] on usb-0000:00:04.0-5/input0
[ 9.473009] usbcore: registered new interface driver btusb
[ 9.475185] dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 9.475221] usb 1-6: firmware: requesting dvb-usb-teviis660.fw
[ 9.622689] dvb-usb: downloading firmware from file 'dvb-usb-teviis660.fw'
[ 9.622701] usb 1-6: firmware: requesting dvb-usb-teviis660.fw
[ 9.745254] usb 1-6: USB disconnect, address 5
[ 9.834744] dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in warm state.
[ 9.834876] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 9.834966] dvb-usb: MAC address reading failed.
[ 9.897467] dvb-usb: no frontend was attached by 'TEVII S660 DVBS2 USB2.0'
[ 9.897679] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:04.1/usb1/1-6/input/input7
[ 9.897809] dvb-usb: schedule remote query interval to 150 msecs.
[ 9.897821] dvb-usb: TEVII S660 DVBS2 USB2.0 successfully initialized and connected.
[ 9.897891] usbcore: registered new interface driver teviis660
[ 9.966062] dvb-usb: TEVII S660 DVBS2 USB2.0 successfully deinitialized and disconnected.
[ 11.517542] usb 1-6: new high speed USB device using ehci_hcd and address 6
[ 11.649477] usb 1-6: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 2
[ 11.650061] usb 1-6: configuration #1 chosen from 1 choice
[ 11.654834] dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 11.654852] usb 1-6: firmware: requesting dvb-usb-teviis660.fw
[ 11.707276] dvb-usb: downloading firmware from file 'dvb-usb-teviis660.fw'
[ 11.707292] usb 1-6: firmware: requesting dvb-usb-teviis660.fw
[ 11.893238] dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in warm state.
[ 11.893379] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 12.228523] dvb-usb: MAC address: 00:18:bd:5c:4a:f0
[ 12.286649] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:04.1/usb1/1-6/input/input9
[ 12.286779] dvb-usb: schedule remote query interval to 150 msecs.
[ 12.286791] dvb-usb: TEVII S660 DVBS2 USB2.0 successfully initialized and connected.
2nd boot sequence
[ 0.480142] usbcore: registered new interface driver usbfs
[ 0.480142] usbcore: registered new interface driver hub
[ 1.428198] usb usb1: configuration #1 chosen from 1 choice
[ 1.486147] usb usb2: configuration #1 chosen from 1 choice
[ 1.965540] usb 1-6: new high speed USB device using ehci_hcd and address 5
[ 2.100613] usb 1-6: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 2
[ 2.101128] usb 1-6: configuration #1 chosen from 1 choice
[ 2.412062] usb 2-1: new full speed USB device using ohci_hcd and address 2
[ 2.812268] usb 2-1: configuration #1 chosen from 1 choice
[ 3.116034] usb 2-3: new low speed USB device using ohci_hcd and address 3
[ 3.333264] usb 2-3: configuration #1 chosen from 1 choice
[ 3.354200] usbcore: registered new interface driver hiddev
[ 3.361589] input: Composite USB PS2 Converter USB to PS2 Adaptor v1.12 as /devices/pci0000:00/0000:00:04.0/usb2/2-3/2-3:1.0/input/input3
[ 3.361735] generic-usb 0003:0518:0001.0001: input,hidraw0: USB HID v1.10 Keyboard [Composite USB PS2 Converter USB to PS2 Adaptor v1.12] on usb-0000:00:04.0-3/input0
[ 3.370828] input: Composite USB PS2 Converter USB to PS2 Adaptor v1.12 as /devices/pci0000:00/0000:00:04.0/usb2/2-3/2-3:1.1/input/input4
[ 3.371029] generic-usb 0003:0518:0001.0002: input,hidraw1: USB HID v1.10 Mouse [Composite USB PS2 Converter USB to PS2 Adaptor v1.12] on usb-0000:00:04.0-3/input1
[ 3.371067] usbcore: registered new interface driver usbhid
[ 3.371082] usbhid: v2.6:USB HID core driver
[ 3.645043] usb 2-5: new low speed USB device using ohci_hcd and address 4
[ 3.859261] usb 2-5: configuration #1 chosen from 1 choice
[ 3.869542] input: USB Mouse as /devices/pci0000:00/0000:00:04.0/usb2/2-5/2-5:1.0/input/input5
[ 3.869721] generic-usb 0003:05E3:1205.0003: input,hidraw2: USB HID v1.10 Mouse [USB Mouse ] on usb-0000:00:04.0-5/input0
[ 9.707342] usbcore: registered new interface driver btusb
[ 9.767294] dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 9.767310] usb 1-6: firmware: requesting dvb-usb-teviis660.fw
[ 9.795735] dvb-usb: downloading firmware from file 'dvb-usb-teviis660.fw'
[ 9.795752] usb 1-6: firmware: requesting dvb-usb-teviis660.fw
[ 9.945654] dvb-usb: found a 'TEVII S660 DVBS2 USB2.0' in warm state.
[ 9.945799] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 10.130256] dvb-usb: MAC address: 00:18:bd:5c:4a:f0
[ 10.206868] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:04.1/usb1/1-6/input/input7
[ 10.207004] dvb-usb: schedule remote query interval to 150 msecs.
[ 10.207015] dvb-usb: TEVII S660 DVBS2 USB2.0 successfully initialized and connected.
[ 10.207086] usbcore: registered new interface driver teviis660
dubstar_04 Wrote:I can't cancel timers.
1) if you mean while recording yeah I found that too but delete does work from the context menu
2) Thats a tvheadend issue because it wont let you delete the files just the timer for the file
3) Live Tv pause not in XBMC yet
4) Not yet
5) Yeah I found that too
6) Thats a tvheadend issue best ask them
Hi dushmaniac,
dushmaniac Wrote:like I said in my previous post, I'll make a new howto post that explains it all properly. didn't have time for it today, so I'll do it tomorrow.
all it takes to install tvheadend + xbmc is installing 2 packages from a ppa and a few actions to do the initial setup.
Did you get a chance to create new HOWTO. (no pushing)
Hi
Is the xbmc-pvr branch still working with the newest version of tvheadend v2.12? - I can't seem to get a connection.
FlexyZ
Hi
Is NDS CAID 09f0 not supported by the CWC?
I also have some channels on Conax CAID : 0B00 that are not working, it shows the first frame and the freezes
cwc: Obtained key for for service xxxxx is present in the log
FlexyZ
ErAzOr2k Wrote:same issue here since today :/
Have you managed to get to the bottom of this yet, I haven't unfortunately and it's a real pain!
Jezz_X Wrote:1) if you mean while recording yeah I found that too but delete does work from the context menu
4) Not yet
Thanks for your reply.
I can delete timers from the context menu like you say, I think i may remap the windows mce keys to work a little more logically when using the pvr section.
I went on the HTS irc channel to ask about touch support for the webserver but i havent seen anyone in there yet to ask.
I have been testing skins for the pvr branch, namely conflunce and Slik.
do you intend on doing anymore work on the confluence skin?
It would be amazing if you could use the genre style from slik in confluence. you know the thin bar of colour in the guide grid rather than the whole segment coloured.
Thanks,
Dubstar_04
