Hi All, I hope somebody can help me. I had TV Headend working wonderfully and then it suddenly stopped working a few days ago. I hadn't made any changes to the system.
The TV Backend is reachable from outside the XBMC box (over the network), yet when i try and connect to the previously working source it does not work. I have tried entering the following soure URLS:
htsp://user:
[email protected]:9982
htsp://user:pass@localhost:9982
htsp://user:
I have also tried the URLs without any sort of password/Username. The error message remains the same: Network is not connected.
Does any have any ideas as to what the cause of this could be? Which logs should I post or how would I enable any debugging logging necessary.
Here is a pastebin of my xbmc.log from some sample tests:
http://pastebin.com/UwE2Twr4
Thanks for any help that can be provided, googling and other searching hasn't gotten me any further.
I'm having problems with the repository,
xbmc@xbmc:~$ sudo apt-get update
Get:1 http://www.lonelycoder.com hts Release.gpg [197B]
Ign http://www.lonelycoder.com hts/main Translation-en_US
Hit http://security.ubuntu.com jaunty-security Release.gpg
Hit http://us.archive.ubuntu.com jaunty Release.gpg
Hit http://ppa.launchpad.net jaunty Release.gpg
Ign http://security.ubuntu.com jaunty-security/main Translation-en_US
Get:2 http://www.lonelycoder.com hts Release [1782B]
Ign http://www.lonelycoder.com hts Release
Ign http://security.ubuntu.com jaunty-security/restricted Translation-en_US
Ign http://ppa.launchpad.net jaunty/main Translation-en_US
Ign http://www.lonelycoder.com hts/main Packages
Ign http://us.archive.ubuntu.com jaunty/main Translation-en_US
Ign http://security.ubuntu.com jaunty-security/universe Translation-en_US
Get:3 http://www.lonelycoder.com hts/main Packages [693B]
99% [3 Packages gzip 0] [Waiting for headers] [Waiting for headers] [Waiting for headers]
gzip: stdin: not in gzip format
Err http://www.lonelycoder.com hts/main Packages
Sub-process gzip returned an error code (1)
xbmc@xbmc:~$ ls /var/lib/apt/lists/partial/
www.lonelycoder.com_debian_dists_hts_Release www.lonelycoder.com_debian_dists_hts_Release.gpg
I've tried deleting the partial files and re running apt-get update with the same result.
Is it the repository or is it me?
sources.list
#hts-tvheadend
deb http://www.lonelycoder.com/debian/ hts main
Checked out the SVN and compiled....
hotlobster
If you find an easy way of reading the current channel list and epg for 'now' then please let us know.
I asked on IRC yesterday as I am hoping to make an Android client for tvheadend, but unfortunately not many of the guys were around to answer, and I couldn't hang around for too long..
@Canuckde:
please provide a
full debug log, not just pieces of it.
what version/branch of xbmc are you using?
@redstorm:
andoma might be updating his packages because he labeled v2.12. try again later or use the packages from the ppa in my sig.
@Swifty:
it's documented on
http://trac.lonelycoder.com/hts/wiki/htsp
@dushmaniac
Did you plan update your packages for tvheadend 2.12.
@dushmaniac
Thanks, I was hoping for some kind of web request to simply get the 'now' epg, since I don't think my skills are up to making htsp protocol for Android :p
As currently as long as the channel number is known, then actually launching it is simply a matter of passing the relevant url to the player, so EPG really is the only tricky bit.
@Schumi:
I'll publish them somewhere today, but there are no functional changes since the last package, just the code to get the CaID for a channel changed a tiny bit.
dushmaniac Wrote:@Canuckde:
please provide a full debug log, not just pieces of it.
I'll get a full log tonight, xbmc.log is the correct log file though?
I'm using XBMCfreak's liveCD 9.11 installed onto an SSD, I'll grab the exact version when I'm home tonight as well.
In that case, please use the official source or the one from my sig or I (or anyone else here) can't provide any support. I have no idea what they changed and packaged.
xbmc.log is the correct file (and enable debugging)
In case you still like taking a quit look, here's the pastebin.
http://pastebin.com/278GhZnt
I'll go try and track down the xbmcfreak forums. I tried posting here because I found the install guide on the forums here as well.
Swifty Wrote:If you find an easy way of reading the current channel list and epg for 'now' then please let us know.
Make a POST request to
http://ip:9981/epg with "limit=30&start=$i" as parameter and you'll get the epg information as JSON string.
POST
http://ip:9981/channeltags with "op=listTags" and you'll get the channeltags
POST
http://ip:9981/channels with "op=list" and you'll get the channels
Works very easy...
@hotlobster: Looking forward to see your iPhone client...
Damn easy, thanks Xoox!
This should be documented on tvheadend manual.
edit: ok tested, but it crashes tvheadend when receive the http query:
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: Signal: 11 in PRG: /usr/bin/tvheadend (2.12) [7e4eb3f2d5c93b097decc0a987d6332f097e174e] CWD: /
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: Fault address (nil) (Address not mapped)
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: Loaded libraries: /lib/i686/cmov/librt.so.1 /lib/i686/cmov/libdl.so.2 /lib/i686/cmov/libcrypt.so.1 /usr/lib/libavahi-common.so.3 /usr/lib/libavahi-client.so.3 /lib/i686/cmov/libpthread.so.0 /lib/i686/cmov/libm.so.6 /lib/i686/cmov/libc.so.6 /lib/ld-linux.so.2 /lib/libdbus-1.so.3 /lib/i686/cmov/libnss_compat.so.2 /lib/i686/cmov/libnsl.so.1 /lib/i686/cmov/libnss_nis.so.2 /lib/i686/cmov/libnss_files.so.2
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: Register dump [19]: 00000033 00000000 0000007b 0000007b 080976e7 00000000 b17fa858 b17fa3e0 00000000 00001339 00000005 00000000 0000000e 00000004 0807d47b 00000073 00010246 b17fa3e0 0000007b
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: STACKTRACE
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x80683c9
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: __kernel_rt_sigreturn+0x0 ()
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x804eaa9
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x804eaf5
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x804ecce
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x804f129
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x804f224
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /usr/bin/tvheadend 0x804d7e3
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: /lib/i686/cmov/libpthread.so.0 0xb779f955
Dec 3 12:33:27 mediacenter tvheadend[4893]: CRASH: clone+0x5e (/lib/i686/cmov/libc.so.6)
Dec 3 12:33:27 mediacenter kernel: [15256.197027] tvheadend[4921]: segfault at 0 ip 0807d47b sp b17fa3e0 error 4 in tvheadend[8048000+1a6000]
I'm uploading a coredump here:
http://xmltv.free.fr/core.5095 ( will be finished in 15 mn )
Great, thanks for the info xoox - I won't clutter this thread with any more of this now
