Veron Wrote:I made couple of changes to SubtitleSource plugin:
- Enabled "sync". Script will compare the filename to releasename from SS. If match is found it will mark it as "sync"
- Added check that at least one of the user selected language is on SS supported languages list
- Changed the way subtitles are sorted. Don't know if my way is the correct one, but it seems to be working (line 9 on ss_utilities.py). Now the subtitles are sorted like this: Sync, Primary, Secondary, Third language.
New codes at pastebin.
service.py: http://pastebin.com/XXRhjtYx
ss_utilities.py: http://pastebin.com/Fbkyfc0v
updated in 1.8.7
Thanks a lot for your contribution!
Zeljko
cannot download the update right now? Add on manager tells me that there is an update to XBMC Subtitles but Downloading progress is stuck on 0% Updating other scripts and download skins works fine. Is there someting dowwn with xbmc subtitles? Thanks for the most useful skin in my matter!
I just updated to latest release, but it is not downloading any subtitles, it cannot connect to any website. It just says that a local subtitle present ! and nothing happens, even though there is no local subtitles. I'm running XBMC_Dharma_33382 on windows 7.
rich710 Wrote:cannot download the update right now? Add on manager tells me that there is an update to XBMC Subtitles but Downloading progress is stuck on 0% Updating other scripts and download skins works fine. Is there someting dowwn with xbmc subtitles? Thanks for the most useful skin in my matter!
I just updated via the repo, no issues here. please post your debug log
Amet Wrote:I just updated via the repo, no issues here. please post your debug log
Here is the log,
http://pastebin.com/12zhi6Zd
thanks for the great work.
kim1406 Wrote:Here is the log,
please try deleting C:\Users\revo\AppData\Roaming\XBMC\cache\sub_tmp and try again
kim1406 Wrote:thanks for the great work.
np, glad you like it
Amet Wrote:please try deleting C:\Users\revo\AppData\Roaming\XBMC\cache\sub_tmp and try again
Thanks, it works after deleting the sub_tmp directory. So, why this happened?
kim1406 Wrote:Thanks, it works after deleting the sub_tmp directory. So, why this happened?
it had an issue with deleting one of the files in there. will relook at that area.
Thanks for the report
Zeljko
For some reason this shit stopped working, any idead on a fix guys?
kraaa Wrote:For some reason this shit stopped working, any idead on a fix guys?
consider yourself warned, no inappropriate language on the forum. if you dont like the addon dont use it.
if you have a problem with it, and want anyone to help you with it, please post a debug log and explain what the issue is, or stay well clear of the addon and this forum thread.
wow take it chill man, i like the script mate, its just not working for some reason and i want to find out why. will check debug log in advanced seeing that normal debug dident say anything...
kraaa Wrote:wow take it chill man, i like the script mate, its just not working for some reason and i want to find out why. will check debug log in advanced seeing that normal debug dident say anything...
you come here with the attitude and tell me to chill
normal debug would have all the needed info, post that if you have it
http://pastebin.com/G6hCXtBi
Well it meant as a joke but i guess its hard to understand that over the internet?
Anyway have deleted the cache and the original subtitle file...
kraaa Wrote:http://pastebin.com/G6hCXtBi
this doesnt show the addon being run at any point, also please dont clip the log, post the full one
kraaa Wrote:Well it meant as a joke but i guess its hard to understand that over the internet?
oh, good one
