What would be the command to run this script from a remote button? In the old days it would be RunScript(/path/to/script.py) but what would it be with the new addon structure?
So in principale I am looking for the right command for remote.xml
runscript(addonid). although the old one will work a well (obviously need to replace the path)
mr_blobby Wrote:New version 1.7.5 is available:- Added support for Ondertitel.com (Movies and Dutch subtitles only)
- Added support for Undertexter.se (Swedish and English subtitles only)
- Improved Subscene.com support:
- added tv show support
- added support for subtitles files that are in 'rar' format
That is freakin fantastic! thanks for undertexter.se support!
EDIT: Too bad I can't update or install it
12:38:55 T:6084 M:576528384 DEBUG: ------ Window Init (DialogAddonInfo.xml) ------
12:38:55 T:6084 M:576528384 INFO: Loading skin file: DialogAddonInfo.xml
12:38:55 T:6084 M:576512000 DEBUG: Load DialogAddonInfo.xml: 6.37ms
12:38:55 T:6084 M:576512000 DEBUG: Alloc resources: 7.53ms (6.42 ms skin load)
12:38:55 T:312 M:574353408 DEBUG: CTextureCache::GetImageHash - unable to stat url http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/fanart.jpg
12:38:55 T:312 M:574353408 DEBUG: FileCurl::Open(06943258) http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/fanart.jpg
12:38:55 T:312 M:574345216 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
12:38:55 T:312 M:574345216 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
12:38:55 T:312 M:574345216 DEBUG: FileCurl::Close(06943258) http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/fanart.jpg
12:38:55 T:312 M:574345216 DEBUG: msg: PICTURE::LoadImage: Unable to open image: http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/fanart.jpg Error: (203)
12:38:55 T:312 M:574345216 ERROR: Texture manager unable to load file: http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/fanart.jpg
12:38:56 T:6084 M:574205952 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 0
12:38:56 T:6084 M:574205952 DEBUG: CApplication::OnKey: 61453 pressed, action is Select
12:38:56 T:6084 M:574205952 WARNING: ADDON: cpluff: 'Could not return information about unknown plug-in script.xbmc.subtitles.'
12:38:56 T:4936 M:574205952 DEBUG: FileCurl::Open(06943258) http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/script.xbmc.subtitles-1.7.3.zip
12:38:56 T:6084 M:574201856 DEBUG: CGUIMediaWindow::GetDirectory (addons://all/xbmc.python.subtitles)
12:38:56 T:6084 M:574197760 DEBUG: ParentPath = [addons://all/xbmc.python.subtitles]
12:38:56 T:312 M:574197760 DEBUG: CGetDirectory::DoWork retrieving addons://all/xbmc.python.subtitles
12:38:56 T:312 M:574197760 WARNING: ADDON: cpluff: 'Could not return information about unknown plug-in script.xbmc.subtitles.'
12:38:56 T:312 M:574197760 DEBUG: CGetDirectory::DoWork retrieving addons://all/xbmc.python.subtitles succeeded
12:38:56 T:312 M:574197760 DEBUG: CGetDirectory::OnJobComplete called
12:38:56 T:6536 M:574107648 DEBUG: thread start, auto delete: 0
12:38:56 T:4936 M:574287872 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
12:38:56 T:4936 M:574287872 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
12:38:56 T:4936 M:574287872 DEBUG: FileCurl::Close(06943258) http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/script.xbmc.subtitles-1.7.3.zip
12:38:56 T:4936 M:574287872 DEBUG: FileManager: copy http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/script.xbmc.subtitles-1.7.3.zip->special://home/addons/packages/script.xbmc.subtitles-1.7.3.zip
12:38:56 T:4936 M:574287872 DEBUG: FileCurl::Open(06943258) http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/script.xbmc.subtitles-1.7.3.zip
12:38:56 T:6536 M:574320640 DEBUG: Thread 6536 terminating
12:38:56 T:4936 M:574349312 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
12:38:56 T:4936 M:574349312 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
12:38:56 T:4936 M:574349312 DEBUG: FileCurl::Close(06943258) http://mirrors.xbmc.org/addons/dharma-pre/script.xbmc.subtitles/script.xbmc.subtitles-1.7.3.zip
12:38:56 T:6084 M:574349312 DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
12:39:01 T:6084 M:582414336 DEBUG: CWinEventsWin32::WndProcWindow is active
12:39:01 T:6084 M:582414336 DEBUG: CWinEventsWin32::WndProcWindow lost focus
12:39:16 T:6084 M:577900544 DEBUG: CWinEventsWin32::WndProcWindow is active
12:39:16 T:6084 M:577900544 DEBUG: CWinEventsWin32::WndProcWindow gained focus
12:39:18 T:6084 M:577896448 DEBUG: CWinEventsWin32::WndProcWindow is active
12:39:18 T:6084 M:577896448 DEBUG: CWinEventsWin32::WndProcWindow lost focus
12:39:26 T:6084 M:574406656 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
12:39:26 T:6084 M:574406656 DEBUG: Win32DllLoader::Unload ImageLib.dll
12:39:26 T:312 M:573075456 DEBUG: Thread 312 terminating (autodelete)
12:39:26 T:4936 M:573149184 DEBUG: Thread 4936 terminating (autodelete)
12:39:27 T:6084 M:573288448 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://mirrors.xbmc.org (easy=02A9DA68, multi=002F7D60)
12:39:27 T:6084 M:573288448 DEBUG: FreeLibrary(secur32.dll) -> 0687B430
12:39:27 T:6084 M:573288448 DEBUG: Win32DllLoader::Unload secur32.dll
All other scripts/plugins installs just fine.
mindweaver Wrote:That is freakin fantastic! thanks for undertexter.se support!
From your log, it looks like the update process is broken.
It's looking for fanart that doesn't exist and an older version of the addon (script.xbmc.subtitles-1.7.3.zip).
Yesterday I had no problems installing the addon (using xbmc revision r31616 , 04-Jul on Win7).
You could install the addon manually by downloading and unpacking the
zipfile and place it in the addons folder.
Hey Amet,
Great addon man, been using for a long time already and I'm very happy with it!!!
I have just been waiting for 1 extra feature: Support for 2 cd (or multi cd) movies.
I've read in the OpenSubtitles thread that you don't have those and I understand it not a priority for you
But could you please move this up on your to-do-list, cause it would make this addon perfect for the people who have 2 cd movies
I hope you can think of a solution!
Grz, LoL
I will see what we can do, no promises though
Hey Amet!
I have a problem because i can't find "Official XBMC.org Add-on Repository under Subtitles subsection".
OpenSubtitles OSD is not working with podnapisi for me.
Help please
Mare26 Wrote:Hey Amet!
Help please
not sure I understand
If you are using the nightly builds, go to "XBMC.org Add-on Repository" and look for "Subtitles", in there you will find XBMC Subtitles
if you are on Camelot or builds that are pre addon merge, you will have to use OpenSubtitles_OSD that unfortunately has issue with podnapisi service in some cases. That has been fixed in XBMC Subtitles.
Cheers,
Zeljko
I dont know what nightly means
i downloaded 31349 now
I did that, thanks!
I was asking because on the other computer we have xbmc 9.11 and xbmc subtitles is not working.
So i don't understand these numbers 31349 i 9.11
Mare26 Wrote:I did that, thanks!
XBCM Subtitles will only work on Nightlies, OpenSubtitles_OSD is for 9.11
Mare26 Wrote:So i don't understand these numbers 31349 i 9.11
31349 is the XBMC build from the SVN, look
here for changes
9.11 is a stable release, codename Camelot. 9.11 = 9 (year 2009).11(November)
next stable release will be called Dharma and it will be 10.05
