Excuse me lads, is there a way for anyone to tell me WHERE actually is the folder of the addon
I can't find it :S
@ StefanM
It's Night skin bug and it is fixed. Update skin with git pull.
moulwxtos Wrote:Excuse me lads, is there a way for anyone to tell me WHERE actually is the folder of the addon I can't find it :S
how is this related to XBMC Subtitles
search please, then post in general section if you are unsuccessful
at least the platform would help :|
Linux:
~/.xbmc/addons
Win:
%APPDATA%\XBMC\addons
or:
%PROGRAMFILES%\XBMC\addons
OSX:
~/Library/Application Support/XBMC/addons
ATV:
/Users/frontrow/Library/Application Support/XBMC/addons
v -1.9.0 is ready. get it from the official repo.
- added: new LegendasTV service, Thanks gfjardim for making it up
Just to let you know SubtitleSource has changed their API so that it can be only used from a web based application. I think that there is no way to work around it, so Amet you can remove the SubtitleSource from XBMC Subtitles. I'll contact them to find a resolution and I'll keep you informed.
This sucks, but I can understand the situation:
http://www.subtitlesource.org/forum/view...?f=3&t=819
Amet Wrote:v -1.9.0 is ready. get it from the official repo.
Amet, besides the BeutifulSoup script addon, I see no changes in the code, am I blind?
gfjardim Wrote:Amet, besides the BeutifulSoup script addon, I see no changes in the code, am I blind?
that and some spaces added in /Portuguese (Brazil)/strings.xml
I am not touching anything in /LegendasTV/ folder
, ask mr_blobby :p
Veron Wrote:Just to let you know SubtitleSource has changed their API so that it can be only used from a web based application. I think that there is no way to work around it, so Amet you can remove the SubtitleSource from XBMC Subtitles. I'll contact them to find a resolution and I'll keep you informed.
This sucks, but I can understand the situation: http://www.subtitlesource.org/forum/view...?f=3&t=819
removed in -v 1.9.1, thanks for letting us know.
this just goest to prove my point, I have been saying that all service inclusions should be cleared with respective websites, it doesnt mean that adding this service to xbmc has overloaded the API, but it probably didnt help the matter.
Cheers,
Zeljko
Hi
Is it possible to add Persian/Farsi subtitle support to this add-on? It would be great. There are many Persian subtitles available and many users.
Thank you
psamim Wrote:Hi
Thank you
sure, I'll look into it in a next few days.
sorry you got overlooked
Love the script/addon.
But I have a huge problem, It won't load when using the OSD button. First time I installed and set it up it worked fine. But after a while it stopped working and the button just kicks me to the system config screen
