gabrielsturmer Wrote:Now in version 3.0 it keeps hanging after te download of the subtitle in Legendas.tv and Sublight.si, and looks like it can't find any subtitles in OpenSubtitles.
http://www.pastebin.com/dRnK0Pva
I take that back, it's working even with Legendas.tv and OpenSubtitles.
Thank you very much, Amet. Your work and quick response is apreciated
timmeh604 Wrote:i hope i got it right....took me a while figuring out i had to go to programs and start the debugger not only just install it...
sorry but i'm new to xbmc... still got to figure out a lot.
hxxp://pastebin.com/xVMiFCZ8
edit: i just read your post above...
should I also enable debug logging in the System>System>Debugging menu? I left it disabled now
does anybody know what i'm doing wrong?
i can not download subs from bierdopje.nl
even if i my vid files have the exact same name as the srt files on the website...
EDIT: i got it working now...i dont know what the problem was
Hi Amet,
After 2.3.0 i have a problem using the Bierdopje subtitle service. (using Openelec)
I get an error:
Error no susch file or directory:
'Special://profile/addon_data/script.xbmc.subtitles/bierdopje_show_ids.txt'
I have looked at the debugging and there is no useful info rather than:
NOTICE: special://masterprofile/ is mapped to: /storage/.xbmc/userdata
NOTICE: special://profile/ is mapped to: special://masterprofile/
I looked at the service.py and made the following change and it worked:
#showids_filename = os.path.join( __settings__.getAddonInfo('profile') ,"bierdopje_show_ids.txt" )
showids_filename = "/storage/.xbmc/userdata/addon_data/script.xbmc.subtitles/bierdopje_show_ids.txt"
As far as i can see it refers to the same location but if i harcode it it works?
Any idea?
Thanx in advance!
deraaij Wrote:Hi Amet,
I get an error:
Any idea?
Thanx in advance!
The line probably needs to be changed to:
xbmc.translatePath( __settings__.getAddonInfo('profile')
),"bierdopje_show_ids.txt" )
I'll check it when I'm at home and will create a patch for Amet to include in a new version.
Oops I just read your first post never mind
amet Wrote:mind trying 2.3.1? Thanks
Works! Thnx à 1000 times!
I'm using XBMC Dharma, XBMC Subtitles 2.3.1, I don't get any results from titlovi.com and podnapisi.net. I tried almost everything, automatic search, manual search, I tried every option but there were no results. My languages are serbian, croatian and bosnian.
What am I doing wrong?
dicki767 Wrote:I'm using XBMC Dharma, XBMC Subtitles 2.3.1, I don't get any results from titlovi.com and podnapisi.net. I tried almost everything, automatic search, manual search, I tried every option but there were no results. My languages are serbian, croatian and bosnian.
debug log please, read my signature for how-to
Is it possible to show the filename inside the donwload window?
the sync information is good, but the filename would help a lot to choose the right sub...
thx
Is there any way to change the subtitle offset more than 10.s .. because sometimes I get some subs which needs more than 10s to get synched well!
any idea how?
thanks
kabrumbs Wrote:Is it possible to show the filename inside the donwload window?
thx
in addon settings, "show file name"
costa Wrote:Is there any way to change the subtitle offset more than 10.s .. because sometimes I get some subs which needs more than 10s to get synched well!
any idea how?
thanks
not in XBMC Subtitles, its in core XBMC. look for advancedsettings.xml instructions
