hi - great addon
my problem is that it tells me no subtitles found almost on every search i make, it finds a sub for 1 out of 15 shows.
here is my debug log
Debug Log
thanks a lot for your help
logictester Wrote:hi - great addon
here is my debug log Debug Log
something wrong with that pastebin.com link, mind doing it again?
Amet Wrote:something wrong with that pastebin.com link, mind doing it again?
sorry about that, new link
Log
Great, last update broke the addon. Good I can't downgrade... All that happens when I click the Download sub button is I get a window with XBMC Subtitle and nothing happening.
http://pastebin.ca/2005981
What's the point with "local sub available" if there's no quick way to load the sub? Instead I have to quit the addon and browse for the SRT I downloaded using the normal XBMC interface. I don't get why the subtitle is cleared every time you stop the video.
Hinz Wrote:Great, last update broke the addon. Good I can't downgrade... All that happens when I click the Download sub button is I get a window with XBMC Subtitle and nothing happening.
thats not the debug log, you need to enable debug logging
Hinz Wrote:What's the point with "local sub available" if there's no quick way to load the sub? Instead I have to quit the addon and browse for the SRT I downloaded using the normal XBMC interface. I don't get why the subtitle is cleared every time you stop the video.
if the local sub available is displayed that means there is the sub in the folder of the movie.
subtitle is not cleared every time you stop the video, by default it should be saved in the same folder as the movie
there is an issue with the 2.1.7, will fix and upload 2.1.8 in a few minutes
EDIT: 2.1.8 is on the repo, anyone with 2.1.7 please update.
sorry about that
Thanks for the quick fix!
Well, hope this time it´s right:
http://pastebin.com/S3FAd8fd
This is what I did and the log should show:
1) pelisalacarta addon -> Seriesyonkis -> The Vampire diaries -> Low Quality -> SubDivX -> Manual Search "The vampire diaries". Result: "nothing to repeat".
2) pelisalacarta addon -> Seriesyonkis -> The Vampire diaries -> High Quality -> SubDivX -> Manual Search "The vampire diaries s01e10". Six results. Choose first. Freeze on "Downloading Subtitles...".
3) Library -> "The A-Team" -> SubDivX -> Manual Search "The A-Team" -> Several results -> Choose one -> It worked!
TVShack apparently doesn't exist anymore, I was using it to get the series and movies in VO, a shame, but I suppose there are other sites in VO.
I have a problem with addic7ed. it does not provide any results since 2 weeks ago. Anyone else with that problem?
try
2.1.9 and let me know please, you will need to download and install manually via "install from zip file" option
Amet,
Is the log ok? Is it a bug of pelisalacarta? Or you didn't have time to take a look?
lumiden Wrote:Amet,
hi,
jamesonmula will have to look at it as he was the one that created the service.
I am sure he will get to it soon
Arty Wrote:Hi Amet,
Thanks for the plugin, great work! I've just discovered it few days ago and it's working great except I could only find one source with a limited content for my native language.
Would it be possible to add http://divxplanet.com/altyazi/arama/ (preffered) or http://www.turkcealtyazi.org/find.php as a new content source?
Thanks...
if you want to create the new service I'll gladly add it but I have no time to create it or maintain it, sorry
opensubtitles, podnapisi and Sublight has a fairly good Turkish database, have you tried them?
