loopez Wrote:for people who has problems with subtitles and smb: ( napistrefa ) on pre-eden builds:
i used solution from http://forum.xbmc.org/showthread.php?tid=86435
simply mounted remote folders to local dirs - and as a workaround it is working
atv2/ios cant mount smb locally, for the rest it should be fine
Hi everyone.
I got a "problem".
Yesterday when I was mixing a little bit with my movies and subtitles I encountered a problem.
I'm from sweden so I'm using undertexter.se and swesub.
as my sources.
My movies are named like this (example): Priest.1080p.BluRay.x264-TWiZTED
But the name in XBMC is only Priest so I think that might be the problem?
(But I've changed the settings so it uses the parental folder when searching)
When I browse for subtitles I don't find the subtitle for that release even if I know that, that particular release is avaliable on undertexter.se
And now to the "problem" that would help my girlfriend to be able to use XBMC more frequently when I'm not at home. (not so technical by nature)
Is their anyway for the subtitles to be auto downloaded and the started when then movie starts.
As for now I need to press the square and then choose what subtitle I want to use
Hope you can help me
I'll check in here from time to time when I'm not to b usy at work..
Thanks for all help I can get.
(Hope this is possible to achieve)
Dear Amet,
Since i am new here please excuse me if i didn't follow any forum rule by posting this:
I run the latest XBMC Subtitle addon and all is well. the only problem is that every time i want to search for a subtitle during a movie and when i press the sub button on the right it says:"searching for subtitles" and then "no subtitle found!" somtimes it happens in an instance and sometimes it takes a while. i am using Sratim.co.il service and on the latest XBMC stable (10.1?)
please let me know what i can do to fix this. i am sorry for not posting log file but i tried messing with the debug log addon and got realy confused. so maybe you can provide me with a sulotion without the log file it will be most appreciated! thanks for the Excellent work!
Ami
znavoy Wrote:Dear Amet,
Ami
look in my signature on how to post a debug log
goofux Wrote:Hi everyone.
I got a "problem".
I'm from sweden so I'm using undertexter.se and swesub. as my sources.
if service is not finding the subs and you are sure they exist we need to look at the log file
as for the auto-search option, its not that easy. we would need to add features in xbmc core to call the sub script on movie play. I am not sure thats what we want.
you have the option to download first "sync" file automatically if the service you are using supports "sync" feature, you need to be on eden-pre xbmc though
There seems to be a problem with the ITASA service.
I'm sure I entered the correct username and password, but it always fails to login.
Otherwise the plugin is excellent!
amet Wrote:look in my signature on how to post a debug log
wow seems you are willing to reply to anyone! i apprieciate that.
only problem is i cant seem to manage debug lof addon to work for me.. no log file is sent to my email nor log file in the C: folder (which i set in the add on settings)..
what am i doing wrong..
amet Wrote:if service is not finding the subs and you are sure they exist we need to look at the log file
aah okej
Okey. ill try to post a logfile tomorrow when im able to
(if I succed
But for now ill just have to start on learning the GF on how to load subs and stuff ;P
Today over the phone it worked so I hope it will work the next time to... And after that she's probably able to do it on her own =)
Thanks for this plugin. I LOVE it.
Any chance we can see addic7ed supported in a future update?
coupas Wrote:Thanks for this plugin. I LOVE it.
Oh wow, don't expect you to read the whole thread ... Only the first post will be enough
znavoy Wrote:Hey Amet,
I manage to create a log.
it is a link:
http://pastebin.com/sQ6gZQ2i
hope it will help you.
thanks in advance.
Ami
You need to enable debug logging, go through the links in my signature again
amet Wrote:You need to enable debug logging, go through the links in my signature again
i think there is a missunderstanding between us my friend
i did manage to create a log! i saw a bunch of errors there so i believe it what you are looking for. any way here it is again:
znavoy Wrote:i think there is a missunderstanding between us my friend
I know you did, I am not blind , I am asking you to enable
debug logging so that errors will be saved to the log.
As I said, look in my sig or how to do it
properly
