Tried to search with my default service Addi7ed for Burn.Notice episode. The scipt gives me an error, which is not shown in the log, but says: error:u'Chinese(Traditional)' where i expect the search result e.g. "found subtitles". Here's my log. Other services are fine.
http://pastebin.com/iuQJxGjA
Amet Wrote:feel like testing this one -v 2.0.9?
thx for letting me know
Zeljko
Works like a charm!
Do you know why this happend? I wasn't using any Chinese characters?
rvrutten Wrote:Works like a charm!
I know you didnt
website returns all the subs that exist for Burn Notice S04E04 and we filter the desired languages, there was Chinese result and script didnt know what to translate it to, look
here.
Amet Wrote:I know you didnt
website returns all the subs that exist for Burn Notice S04E04 and we filter the desired languages, there was Chinese result and script didnt know what to translate it to, look here.
That makes sense. Thanks for the quick follow up!
Not sure which movie it was, but it were a parted one. Experienced a problem that the CD2 sub where downloaded and it gave no text for the CD1 part.
Has this been an issue before, or were I just unlucky when it came to that single movie? Will try some more movies which are CD1/CD2.
MindTooth Wrote:Not sure which movie it was, but it were a parted one. Experienced a problem that the CD2 sub where downloaded and it gave no text for the CD1 part.
there is no support for 2cd movies
Amet Wrote:there is no support for 2cd movies
Really? I have been struggling with this for a while on subdivx.com script, but it won't work. I have seen the # of files field on the subtitles_list tuple (ie on Undertexter script) but, you are right, the rename files is not working.
Do you know if there's any script that supports 2 CDs? any chance to make it work soon? There is still a number of movies distributed in this format.
Thanks for the recent updates!
The addon randomly results in a runtime error once the subtitle has been downloaded and extracted. This error results in XBMC crashing and I have to forcibly shut it down.
The subtitle that was downloaded is being used without problems when i resume the video after reopening XBMC.
Here is the debug log:
http://pastebin.com/jXD36rhS
Orbi Wrote:The addon randomly results in a runtime error once the subtitle has been downloaded and extracted. This error results in XBMC crashing and I have to forcibly shut it down.
Here is the debug log: http://pastebin.com/jXD36rhS
is "Y:\" an smb:// drive?
try disabling hash search under addon settings and see if that helps.
are subtitle searched in a different way if it's a tvshow or a film ?
i'm using a streaming addon, that allow me to watch movies or tvshow, when i use the subtitle during play, seems that he try to search for a movie, not a tvshow, i've got more choice when using on same episode from libraory.
