(2014-05-19, 23:23)davematt0709 Wrote: [ -> ] (2013-10-06, 11:22)CutSickAss Wrote: [ -> ] (2013-10-04, 21:18)CutSickAss Wrote: [ -> ]Is it just me not seeing the movies MPAA ratings (PG-13, R, etc) on the lower left side? The TV ratings appear fine, by the way.
I'm sure others have experienced this issue, and it is probably caused by the scraper, in my case the universal scraper. Basically the MPAA rating that is fetched is not expressed exactly as expected, so no icon appears on the bottom left side. The solution is to open IncludesVariables.xml, and replace the US ratings under value_mpaa (the six first lines below it) with these:
<value condition="SubString(ListItem.Mpaa,Rated NR) | SubString(ListItem.Mpaa,Rated: NR) | StringCompare(ListItem.Mpaa,NR)">flags/mpaa/MPAA_NR_Certificate_US.png</value>
<value condition="SubString(ListItem.Mpaa,Rated G) | SubString(ListItem.Mpaa,Rated: G) | StringCompare(ListItem.Mpaa,G)">flags/mpaa/MPAA_G_Certificate_US.png</value>
<value condition="[SubString(ListItem.Mpaa,Rated PG) | SubString(ListItem.Mpaa,Rated: PG) | StringCompare(ListItem.Mpaa,PG)] + !SubString(ListItem.Mpaa,Rated PG-13) + !SubString(ListItem.Mpaa,Rated: PG-13)">flags/mpaa/MPAA_PG_Certificate_US.png</value>
<value condition="SubString(ListItem.Mpaa,Rated PG-13) | SubString(ListItem.Mpaa,Rated: PG-13) | StringCompare(ListItem.Mpaa,PG-13)">flags/mpaa/MPAA_PG-13_Certificate_US.png</value>
<value condition="SubString(ListItem.Mpaa,Rated R) | SubString(ListItem.Mpaa,Rated: R) | StringCompare(ListItem.Mpaa,R)">flags/mpaa/MPAA_R_Certificate_US.png</value>
<value condition="SubString(ListItem.Mpaa,Rated NC-17) | SubString(ListItem.Mpaa,Rated: NC-17) | StringCompare(ListItem.Mpaa,NC-17)">flags/mpaa/MPAA_NC-17_Certificate_US.png</value>
Similarly replace the first six lines under value_mpaa_fs with these:
<value condition="SubString(Videoplayer.Mpaa,Rated NR) | SubString(Videoplayer.Mpaa,Rated: NR) | StringCompare(Videoplayer.Mpaa,NR)">flags/mpaa/MPAA_NR_Certificate_US.png</value>
<value condition="SubString(Videoplayer.Mpaa,Rated G) | SubString(Videoplayer.Mpaa,Rated: G) | StringCompare(Videoplayer.Mpaa,G)">flags/mpaa/MPAA_G_Certificate_US.png</value>
<value condition="[SubString(Videoplayer.Mpaa,Rated PG) | SubString(Videoplayer.Mpaa,Rated: PG) | StringCompare(Videoplayer.Mpaa,PG)] + !SubString(Videoplayer.Mpaa,Rated PG-13) + !SubString(Videoplayer.Mpaa,Rated: PG-13)">flags/mpaa/MPAA_PG_Certificate_US.png</value>
<value condition="SubString(Videoplayer.Mpaa,Rated PG-13) | SubString(Videoplayer.Mpaa,Rated: PG-13) | StringCompare(Videoplayer.Mpaa,PG-13)">flags/mpaa/MPAA_PG-13_Certificate_US.png</value>
<value condition="SubString(Videoplayer.Mpaa,Rated R) | SubString(Videoplayer.Mpaa,Rated: R) | StringCompare(Videoplayer.Mpaa,R)">flags/mpaa/MPAA_R_Certificate_US.png</value>
<value condition="SubString(Videoplayer.Mpaa,Rated NC-17) | SubString(Videoplayer.Mpaa,Rated: NC-17) | StringCompare(Videoplayer.Mpaa,NC-17)">flags/mpaa/MPAA_NC-17_Certificate_US.png</value>
Hi guys. First, this is just the best skin going for XBMC. The new MQ5 interface is just incredible. Many thanks for the hard work.
OK, after I installed the most recent version of Gotham and the Azraelomega modded script.extendedinfo to show movie set info, I then checked that everything was working OK using Confluence skin. Then I installed Aeon MQ5 DSMOD that has the colour mods by devilshura (v6.0.2; love colour icons) and program add-on AeonMQ5 ExtraPack 1.1.0. However, I noticed that when I switched to MQ5 I lost the majority of my MPAA ratings (set up to display UK ratings taken off IMDB). The odd things is that of the 600 movies I have in my database only around 20 are displaying the MPAA ratings! If I switch back to Confluence skin they all reappear!! Not sure why this happems or how I get them to display correctly, but I note that the above post by CutSickAss reported the same issue for US ratings. The posted solution for the US ratings in IncludesVariable.xml is what is already in this file, but this is for US ratings. What is the solution for UK ratings? Anyone else with this problem and how is it fixed? Thanks
Hi guys. Does no one else have a problem with mpaa ratings for the UK? Any help in sorting this out would be gratefully received. If it helps here are the equivalent files mentioned by CutSickAss, showing US and UK ratings only. Thanks for any help.
Location of file: AppData/Roaming/XBMC/Addons/skin.aeonmq5/720p/IncludesVariables.xml
-<variable name="value_mpaa">
<value condition="[SubString(ListItem.Mpaa,Rated PG) | SubString(ListItem.Mpaa,Rated: PG) | StringCompare(ListItem.Mpaa,PG)] + ![SubString(ListItem.Mpaa,Rated PG-13) | SubString(ListItem.Mpaa,Rated: PG-13)]">flags/mpaa/MPAA_PG_Certificate_US.png</value>
<value condition="SubString(ListItem.Mpaa,UK:U)">flags/mpaa/BBFC_U_Certificate_UK.png</value>
<value condition="SubString(ListItem.Mpaa,UK: PG)">flags/mpaa/BBFC_PG_Certificate_UK.png</value>
<value condition="SubString(ListItem.Mpaa,UK:12) + !SubString(ListItem.Mpaa,UK:12A)">flags/mpaa/BBFC_12_Certificate_UK.png</value>
<value condition="SubString(ListItem.Mpaa,UK:12A)">flags/mpaa/BBFC_12A_Certificate_UK.png</value>
<value condition="SubString(ListItem.Mpaa,UK:15)">flags/mpaa/BBFC_15_Certificate_UK.png</value>
<value condition="SubString(ListItem.Mpaa,UK:18)">flags/mpaa/BBFC_18_Certificate_UK.png</value>
-<variable name="value_mpaa_fs">
<value condition="[SubString(Videoplayer.Mpaa,Rated PG) | SubString(Videoplayer.Mpaa,Rated: PG) | StringCompare(Videoplayer.Mpaa,PG)] + ![SubString(Videoplayer.Mpaa,Rated PG-13) | SubString(Videoplayer.Mpaa,Rated: PG-13)]">flags/mpaa/MPAA_PG_Certificate_US.png</value>
<value condition="SubString(Videoplayer.Mpaa,UK:U)">flags/mpaa/BBFC_U_Certificate_UK.png</value>
<value condition="SubString(Videoplayer.Mpaa,UK: PG)">flags/mpaa/BBFC_PG_Certificate_UK.png</value>
<value condition="SubString(Videoplayer.Mpaa,UK:12) + !SubString(Videoplayer.Mpaa,UK:12A)">flags/mpaa/BBFC_12_Certificate_UK.png</value>
<value condition="SubString(Videoplayer.Mpaa,UK:12A)">flags/mpaa/BBFC_12A_Certificate_UK.png</value>
<value condition="SubString(Videoplayer.Mpaa,UK:15)">flags/mpaa/BBFC_15_Certificate_UK.png</value>
<value condition="SubString(Videoplayer.Mpaa,UK:18)">flags/mpaa/BBFC_18_Certificate_UK.png</value>
-<variable name="value_mfmpaa">
<value condition="SubString(Container(510).ListItem.Property(Mpaa),Rated NR) | SubString(Container(510).ListItem.Property(Mpaa),Rated: NR) | StringCompare(Container(510).ListItem.Property(Mpaa),NR)">flags/mpaa/MPAA_NR_Certificate_US.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),Rated G) | SubString(Container(510).ListItem.Property(Mpaa),Rated: G) | StringCompare(Container(510).ListItem.Property(Mpaa),G)">flags/mpaa/MPAA_G_Certificate_US.png</value>
<value condition="[SubString(Container(510).ListItem.Property(Mpaa),Rated PG) | SubString(Container(510).ListItem.Property(Mpaa),Rated: PG) | StringCompare(Container(510).ListItem.Property(Mpaa),PG)] + ![SubString(Container(510).ListItem.Property(Mpaa),Rated PG-13) | SubString(Container(510).ListItem.Property(Mpaa),Rated: PG-13)]">flags/mpaa/MPAA_PG_Certificate_US.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),Rated PG-13) | SubString(Container(510).ListItem.Property(Mpaa),Rated: PG-13) | StringCompare(Container(510).ListItem.Property(Mpaa),PG-13)">flags/mpaa/MPAA_PG-13_Certificate_US.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),Rated R) | SubString(Container(510).ListItem.Property(Mpaa),Rated: R) | StringCompare(Container(510).ListItem.Property(Mpaa),R)">flags/mpaa/MPAA_R_Certificate_US.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),Rated NC-17) | SubString(Container(510).ListItem.Property(Mpaa),Rated: NC-17) | StringCompare(Container(510).ListItem.Property(Mpaa),NC-17)">flags/mpaa/MPAA_NC-17_Certificate_US.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),UK:U)">flags/mpaa/BBFC_U_Certificate_UK.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),UK: PG)">flags/mpaa/BBFC_PG_Certificate_UK.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),UK:12) + !SubString(Container(510).ListItem.Property(Mpaa),UK:12A)">flags/mpaa/BBFC_12_Certificate_UK.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),UK:12A)">flags/mpaa/BBFC_12A_Certificate_UK.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),UK:15)">flags/mpaa/BBFC_15_Certificate_UK.png</value>
<value condition="SubString(Container(510).ListItem.Property(Mpaa),UK:18)">flags/mpaa/BBFC_18_Certificate_UK.png</value>
